Question about HP DeskJet F380 All-In-One Printer
My HP Deskjett F2200 printer, copier, and scanner will not print, but it will copy. It tells me it's offline.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
Sharp MX4100 maintenance code vk
Check out this little walkthrough I have put together. Adjusting the printer port settings on your computer should take care of it. Sharp Printer Offline Solution
Feb 20, 2014 | Sharp "MX-4100N Copier, Printer, Scanner...
How do i override incompatible cartridge error message on my HP deskjet F2200
The ink cartridge is likely electrically damaged, to verify nozzle/electrical health run the 'Tap 41' diagnostic procedure:
http://www.youtube.com/watch?v=16uXSBwTan8
inkjet411 team
Mar 05, 2013 | HP Office Equipment & Supplies
My printer status show offline eventhoungh i'm online.It can copy(photostat) the document but it cannot print.I alrerady change the printer port but it still offline.My printer is HP Deskjet...
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Dec 26, 2010 | HP Deskjet F340 All-In-One Printer
I have 3 computers connected by router. All 3 have been using the hp 6310 all in one printer for a long time. Now all of a sudden when we try to print is says printer is off line. I have tried turning...
Hi! you can try this. rightclick to open all active printers in right downcorner there click the printer section and remove the x mark in use the printer in offline. you can allso check that your default printer is right not example the hpxxxxxxx (copy 1)
Aug 03, 2010 | HP OfficeJet 6310 All-in-One Printer...
Hp 5610 all in one printer, cartridge error, will not print
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
abdsf17
Aug 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Offline printer
unplug the USB lead and plug it back in...if no response try another USB port, if still no response use a different lead or put a gentle bend in the one you have to make the connection tighter....make sure the printer is on of course
Aug 02, 2009 | HP DeskJet F380 All-In-One Printer
My Hp Officejet 6300 All-In-One printer will not copy
printer is offline yet cables are connected and printer was working a day or so ago!
Jan 19, 2009 | HP OfficeJet 6310 All-in-One Printer...
NOT ABLE TO GET PRINTER TO PRINT
If you open up the printer (start => settings => printers and faxes..), and look under the "printer" menu, is "use printer offline" checked? If it is, un-check it.
Feb 17, 2008 | Office Equipment & Supplies
HP DeskJet F380 All-In-One Printer Logo
223 people viewed this question
Ben Johnson
