Question about Kenwood DDX419 2-DIN 6.1 LCD DVD Receiver with Bluetooth
Kenwood ddx419 rear speaker not working
Seem like it is shorted. How do I fix this?
2 Suggested Answers
SOURCE: Got the Kenwood ddx419 working good but when I try
Incorrect, you only need the special cable to be able to play video. The default AV In setting is set to require the special cable for sound, but it is not required. All you need to do is rest the deck (press the little red triangle on the face) and then in the setup change the AV setting from ipod to AV IN and it will work
Posted on Sep 24, 2012
Kenwood DDX419 cars stereo that powers up put does not work
www.kenwoodusa.com/support
www.kenwoodusa.com/contact
www.kenwoodusa.com/support/car_entertainment/
Files specific to your model can be found by navigating to the product page, and then clicking on the appropriate Tab; Manuals for the Owner's Manual and ...
Sep 07, 2014 | Kenwood DDX419 In-Dash Receiver
Kenwood ddx419 dvd problems
Jun 12, 2014 | Kenwood DDX419
I have no sound for my kenwood ddx419
SOUNDS LIKE A SPKR GROUNDING OUT check all spkrs for mis-mounting or failure.GOOD LUCK
Jan 27, 2013 | Kenwood DDX419
Kenwood ddx419 manual
You may download a copy of the manual here.
Aug 29, 2012 | Kenwood DDX419 - 6.1" WVGA In-Dash Video
Kenwwod KDC MP 543u Protect mode problem
This indicates a short in one of the speakers, or possibly the speakers are not wired correctly. Please see my tip at http://www.fixya.com/support/r9389300-stereo_says_protect_or_clicks_off_when .
Correct wiring for 95 Corolla is as follows:
1995 Toyota Corolla Wiring harness, Kenwood wire color
Radio Constant 12V+ Wire: Blue/Yellow, yellow
Radio Switched 12V+ Wire: Gray, red
Radio Ground Wire: Brown, black
Radio Illumination Wire: Green, not used by Kenwood--please tape off
Radio Antenna Trigger Wire: Black/Red, blue
Left Front Speaker Wire (+): Pink, white
Left Front Speaker Wire (-): Purple, white/black
Right Front Speaker Wire (+): Light Green, gray
Right Front Speaker Wire (-): Blue, gray/black
Left Rear Speaker Wire (+): Black, green
Left Rear Speaker Wire (-): Yellow, green/black
Right Rear Speaker Wire (+): Red, purple
Right Rear Speaker Wire (-): White , purple/black
Dec 29, 2011 | Kenwood Car Audio & Video
After driving for about thirty minutes my amp will just cut off, it seems a little hot and then it will turn back on in about 10 minutes. I'm not playing my music loud at all and I have all kenwood...
sounds like your speaker is either the wrong resistance for your amp ie your amp may state 4 ohms and your speaker is 2 ohms which means that the speaker is shorting out the amp and its going into protection mode or the speaker could be burning out and shorting out the amp
May 30, 2011 | Car Audio & Video
Kenwood kdc-x769.everything works on the deck just fine other than no sound at all-not even static. did a full and proper install into vehicle and cant get anything to come through the speakers-any help or...
you may want to check and make sure none of the speaker wires or speaker terminals are shorting out. it just takes one shorted speaker or speaker wire to shut off the entire audio.
Jul 13, 2010 | Kenwood eXcelon KDC-X769 CD Player
HAVING AUDIO ISSUES, THE SUB CHANNEL WORKS GREAT, BUT ALL THE SUDDEN THE MIDS NO LONGER WORK. I TOOK TOP OFF AND CHANNELS SEEM TO BE IN TACT. ANY IDEAS
try resetting it if it has a reset button see if that works. also, disconnect one of the speaker wires(like green, and green w/black stripe) from behind the unit and try connecting it direct to a speaker that you know is working. if it works your stereo is fine and the issue might be an amp or a short in the wires. If you try all that and all fails, your signal processor chip inside the stereo might have shorted. thats the one that gets bolted to the rear of the stereo(inside) against the chasis. it will have some thermal paste on it when you remove the housing. just telling you this in case you want to try and fix it yourself. now, make sure you don't erase or fudge the processor(chip) model number. go here and see if they have it before you take it off(if you want to try and fix yourself). www.pacparts.com, these guys have everything pioneer, jvc, and kenwood...i mean everything.
Mar 22, 2010 | Kenwood eXcelon KDC-X769 CD Player
My kenwood kdcmp4380 is in protect how do i fix it
There is a short going on, disconnect your speakers one by one and when the unit comes out of protect mode trace the wires and isolate the short.
Oct 09, 2009 | Kenwood KSC-310CCS Center Channel Speaker...
Kenwood DDX419 2-DIN 6.1 LCD DVD Receiver with Bluetooth Logo
65 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
