Question about Cell Phones
Samsung J1255AV service manual
Door handle
Samsung French door fridge freezer handle came loose. The ***** on the right side fell into the back of the handle attachment so it won't go flush with the fridge.
Hello Marilyn;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number which is located on a label on the inside liner of your fresh food section.
Usually the door handles are held on in one of two ways.
1.) Inspect the sides of the door handles. Are there small allen wrench screws - tighten them.
2.) Ok, no screws on the side. There are mounting brackets screwed onto the door. At times the screws become loose. Use a little muscle and pull the handle up hard to release from the bracket. Tighten the screws on the bracket to the door. Position the handle back on the bracket and pull the handle down hard until secure.
Mar 03, 2016 | Samsung Refrigerators
How to install left front door handle on 2007 suzuki xl7
remove door skins, card.
remove handle rods.
remove handle screws
remove handle.
or
RTM?
https://suzukipitstopplus.com/Products/10182-2007-xl7-service-manual.aspx
$4 dirt cheap, and does blow by blow, steps.
Mar 18, 2015 | Suzuki XL7 Cars & Trucks
Door handle loose
The service manuals for Samsung model SMH9187ST are here and here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 05, 2012 | Samsung SMH9187ST Microwave Oven
The door handle on my samsung RSH1NHMH freezer is loose how do I tighten it
You will see a small hole on the underside of the handle at the two points that the handle touch the fridge door,put a small straight nose screwdriver in this hole and turn 90deg which will expand the metal clip inside at the same time pull the handle away from the door and it will come off.You can then screw the handle holding clip into the fridge door and then push the handle back on.
Oct 18, 2010 | Samsung Refrigerators
I need a schematic for an over the range microwave door in order to replace the handle. A samsung model SMH7187STG
Do you have the new handle already? I need a whole new door due to a scratch and will have a new handle from the scratched door that I wont need........
Oct 25, 2009 | Samsung Microwave Ovens
2000 dodge intrepid driver door latch broken. When we take the door apart, there is a plastic piece that broke that attaches the handle to the rod that pulls the latch. It does not look like there is an...
We purchased a door latch to replace ours from Dodge. It came with instructions as follows:
Instruction Sheet
Front Door Handle/Bezel Replacement for LH
1. Remove the front door trim panel using the procedures outlined in Section 23 of the appropriate service manual.
2. Place door trim panel on a clean work surface. Drill the mounting bosses' heat stakes, which attach the existing door handle/bezel to the panel, with a 21/64-drill bit. Take extra care to only drill in the center of each heat stake.
3. Remove existing handle/bezel from trim panel.
4. Clean the back of the trim panel of plastic fillings.
5. Seat the new handle/bezel into location.
6. Place the push nuts onto the handle/bezel bosses.
7. Use a 10 mm socket to install the push nuts all the way down on the mounting bosses to secure the handle/bezel onto the door trim panel. Using a wiggling side-to-side motion may be helpful.
8. Install the lock switch from the original handle/bezel to the new door handle/bezel.
9. Reinstall the door trim panel using the procedures outlined in Section 23 of the appropriate service manual.
Hope this helps.
Jul 02, 2009 | 2000 Dodge Intrepid
My passenger door hadle was pulled off when I pulled it to open it. I am trying to find a manual that explains to me how to change it. Can anyone point me in the right direction??? It's a Hyundai Tiburon...
These are the procedures outlined in the shop manual (without pictures). If you want the pictures too, go to http://www.hmaservice.com/ and register (by Vehicle VIN). Then you can navigate through the service manuals to find the info you're looking for. (You'll also have access to wiring diagrams, service bulletins, etc.)
1. Remove the grip handle using a remover.
2. Remove the inside handle housing.
3. Remove the tweeter speaker using a remover.
4. Remove the mounting screws and remove the door trim panel.
Disconnect the wire connectors.
5. Remove the door grip handle mounting bracket, speaker and door trim seal.
6. Remove the door tooling hole cover.
7. Remove the door glass stopper catch.
8. Remove the door delta chassis.
9. Remove the glass stopper bolts, remove the window glass.
10. Remove the door side weather strip.
11. Loosen the mounting nuts and remove the regulator assembly.
12. Disconnect the cable, after loosening the inner handle mounting screw, push the inner handle toward the direction shown in the illustrationand remove it.
13. Remove the door outside belt.
14. Remove the door outside handle and key cylinder.
15. Remove the door latch assembly mounting screws and remove the door latch assembly.
May 03, 2009 | 2003 Hyundai Tiburon
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
