Question about Frigidaire ATF6000ES Front Load Washer
E-10 code Screens on the intake hoses are plugged. How do they come out?
  • Official Brand Answer
  • 4,342 Answers
Hello - Typically error code E10 indicates that it takes too long for water to fill. Contact a professional to run multiple tests to verify that the incoming water flow is normal and to check the electronic pressure sensor. Possibly might need to replace the main control board. Hi - Typically error code E10 indicates that water takes too long to fill. Contact a professional to run multiple tests to verify the incoming water flow is normal and to check the electronic pressure sensor. Depending on the results, washer may possibly have a faulty water inlet valve assembly, pressure sensor/switch or main control board.
Posted on Oct 26, 2012
Nf code, new cold water valve, cleaned screens, drain good, uplugged and pluged back in still no cold water
trying turning the water off. disconnecting the hose at the valve and hooking it up again.
Feb 02, 2015 | Washing Machines
Code ie machine fills with water but does not spin.
code ie + Inlet Error. Either the washer is taking too long to fill, or at least one of the inlet screens (usually the cold) is plugged. Turn off house supply valves so you can remove hoses from the back of the machine and then pull the screens out to clean them out. Replace the screens, re-connect hoses, turn valves back on and test.
Feb 07, 2011 | LG WM-2277HW Front Load Washer
The water is coming in very slowly. The screens are not plugged. Could the problem be the intake valve?
Hi.
Yes it could be the valve. or possibly low water pressure, also make sure the hose/s are not kinked or restricted in any way.
Feb 06, 2011 | Washing Machines
E 10 code what do u do
I'm assuming your washer is a Kenmore or Frigidaire front loading washer. E10 error code is an indication of a slow fill, took to long to fill, no fill or the fill water could be siphoning out the drain hose as it's filling with water.
Check to make sure that the drain hose is not stuck too far down the stand pipe and causing the water to siphon out. Check the cold and hot water supply to the washer for any restrictions. If you have a slow fill remove the hoses from the washer and check for restricted filter screens in the water inlet valve. Check for any restricted hose screens too.
Jan 10, 2011 | Frigidaire ATF6000ES Front Load Washer
Getting code that says low or no water intake. Trouble shooter says change filters in water hoses. Filters are not in water hoses but seem to be stuck in the blue connections on back of machine. Can I take...
yes you can use needlenose to remove the screens. Check both ends of the hoses for screens. If after cleaning the problem persist you will need to replace the water inlet valve assembly. These are usually inexpensive and easy to replace. Here is a couple links depending on type of washer http://appliancehelponline.com/topwaterinletvideo.html
http://appliancehelponline.com/washerwaterinlet.html
Jun 28, 2010 | Washing Machines
89 chevy S-10 with 2.5L engine misfiring, when I ran the diagnostic test it showed code 25 or two flashes pause five flashes, what's the problem
Intake air temperature sensor or circuit shorted. Look for sensor popped in on intake hose from air filter. If not connected or wires broken find & repair connection or sensor is bad. Replace.
Jun 06, 2010 | 1988 Chevrolet S-10
Washing machine will spin on all of the spin cycles; but will not fill with water when put on any of the wash cycles. Could the fuse on the lid switch be the problem?
it is not cycling. Water is turned on correct? Check to make sure that the filter screens are not plugged on intake and hoses. Wig wag possibly not working to allow intake to open
Mar 08, 2010 | Washing Machines
Tub filling very slow. Checked both hoses and they are not stopped up. what else can I do?
Did you check the screens that cover the intake tubes where you hoses connect up to see if there is any sand or grit covering the screens? A lot of times over time there are small amounts of sand or grit that comes through the water lines and it plugs off the screens where the hoses screw on.
Sep 08, 2009 | Amana Washing Machines
2000 BMW 323i Check Engine Light Problem-10 codes!!! Help!
I would first check for a vacuum leak. Common areas of intake leaks are: 1. The crankcase vent valve located under the intake. 2.Check the intake boot at the throttle housing. You will find that there is an elbow where a small hose goes to your idle valve. Using your hand feel in the elbow area for a hole in the rubber. Your tech can use brake cleaner and spray the intake to check for leaks or use a smoke tester. 3.Possible failing Mass Air Meter.At idle, in park, and a/c not on the meter reading should be appr. 18-22 hz
Mar 06, 2009 | 1999 BMW 323 Series
Lf what does it mean?
Lf means long fill make sure your taps are on. or your filters in the hoses arn,t plugged in other words it is taking longer than 10 minutes to fill
Dec 11, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
61 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
