Question about Emerson MW8168B Microwave Oven
The metal plate on the right had side of oven has a hole burned in it
  • Emerson Master
  • 9,047 Answers
That's the waveguide cover (also called a spatter shield) is usually about the size of a playing card and sometimes held in place by a plastic rivet.
If your waveguide cover is burned or damaged, it will need to be replaced.
It provides critical protection for the magnetron.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Oct 26, 2012
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My 900W microwave oven (model
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';';';';';';';';';';
Posted on May 20, 2011
Sharp carousel R 430 EK 1200 watts
This is not good, the magnetron is arcing because metal is exposed, this will eventually destroy the magnetron making the oven useless. I strongly suggest it get looked at for safety and potential fire hazard.
Mar 05, 2012 | Sharp Carousel R530EST Microwave Oven
Electrical arching between top metal plate and shell?
i would imagine its a shield but iam not completely sure without a good look
Nov 20, 2011 | GE XL1800 1100 Watts Microwave Oven
I have a Sylvania Microwave oven Model # SM81004/SM81001 1.0 cu.ft. It started sparking during reheating a plate of food only after about 1 Minute. The metal plate on the right side looks like it has a...
You should replace the waveguide cover, the plate you refer to. They are fairly cheap and easy to replace.
www.espares.co.uk or www.cpc.co.uk most appliance repair services can get them.
Mar 08, 2011 | Sharp R-820B Convection/Microwave Oven
Arcing from the metal plate on the right side of the oven when anything solid is place in it - such as frozen foods or a cold stick of oleo or frozen biscuit. Goes off when I open the door.
That metal plate is probably the waveguide cover. It is made of Mica and must be kept clean otherwise it will arc and burn. The reason it arcs more when solid/frozen food are placed in the oven is because solid/frozen foods do not absorb as much energy as wet foods.
Replace it if it is burnt.
Dec 20, 2010 | GE Microwave Ovens
The silver fiberglass plate on the right side of the inside of my microwave has gotten a hole in it, causing the microwave to spark. Is it possible to replace this part? I have had the microwave less than...
yes you can buy a sheet and cut it to size-just ensure that any bare metal inside the microwave caused by the sparking isrubbed down and painted with two coats of ,hammerite metal paint otherwise its back to square one
Feb 25, 2010 | Emerson MW8107WA Microwave Oven
Burnt hole in metal plate inside microwave oven
Ok stop useing oven and unplug! THIS CAN BE FIXED!!! Go to a home improvment store and buy a small bottle of white liquid enamal....Clean up the area that is missing and flakeing and then apply the enamel over the hole and let dry overnight! now that the exposed metal is covered back up it is safe to use and will not spark or cause any more soot!
PLEASE rate my response to your question!
THANK YOU!
Jan 08, 2009 | Microwave Ovens
We have a JE1860CB001 built-in microwave that has on several occasions sparked very brightly from the square plate on the inside right of the cavity covering the opening to the microwave tube. It has...
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 06, 2008 | Microwave Ovens
Buzzing noise and flashing
Some units have a silica plate covering the waveguide opening. If it get burn spots on it, it'll do that. Remove the plate and try the unit. If it's OK, go to your MW repair shop and order a new plate.
Remember... always cover your food...
Geno
Mar 10, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson MW8168B Microwave Oven Logo
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
