Question about Saws
Rockwell 34410 table saw blade alignment - Saws
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
  • 15 Answers
SOURCE: truing craftsman table saw blade
Use a carpenter square to allign the blade both vertically and horizontally with your guide. This works very well.
Posted on Jan 28, 2009
  • 59 Answers
SOURCE: old craftsman table saw parts?
most sears stores have a dept. that refurbishes and sells these tools. if it can be had, they can help.
Posted on Apr 25, 2009
SOURCE: How do I change the blade on my Ryobi 10" table saw?
The manual is posted on line. Changing the blade does not require turning the saw over, blocks of wood or vice grips. The advice listed above is potentially damaging to your equipment.
http://www.raygirling.com/ryobi/ryobi.htm#settadj
Posted on Sep 24, 2009
FixYaSteve
  • 57 Answers
SOURCE: Looking for a manual for a Rockwell Model 8
Exploded parts diagram is here.
They don't have the operator's instruction manual online, unfortunately.
If you need an operator's manual, the Delta 34-410 is a 10" contractors saw that's reasonably close. Please bear in mind that this is more for table saw safety and operations than specifics of setup. The 34-410 operators manual is here.
If this answer helped, please vote for it. Thanks!
Posted on Jun 13, 2010
Table saw blade alignment
Are you referring to the table top or rip fence alignment? The blade itself is not aligned. We adjust the table to parallel with blade and the rip fence should toe away from blade 0.01mm over the length of the rip fence to prevent binding.
Jan 14, 2014 | Delta Saws
12" vintage Rockwell table saw Model# 34-388 I need a manual
Check vintagemachinery's website. You might be able to find some information there about your saw. Or make a quick google search , several threads will show up upon search that could help you. If you need band saw blades, I suggest you to visit sawblade.com .
Sep 13, 2013 | Delta Rockwell 34-450 10" Tilting Arbor...
Rockwell 34 345
I have a band saw and I am using a sawing fluid for blade lubrication. Try looking at lowes . You can ask them how to lubricate and what lubricant to use. Watch this video .
Apr 26, 2013 | Saws
I need an owner's manual for a Rockwell 34-660 model table saw. I want to replace the blade but the entire shaft turns when I try to remove the shaft nut from the shaft.
You might be able to find a manual here.
You need to lock the blade in place so it doesn't rotate when you loosen the arbor nut. Many older rockwell saws actually had a detent ground in the shaft behind the blade that allow the use of a second wrench to hold the shaft from spinning while the nut is loosened. It takes a special thin wrench to get in there, and the ones that came with the saws were bent just behind the head of the wrench to get around the blade and out the throat, but if you know anyone with a delta tablesaw they may have one you can borrow, or perhaps you can grind down an old cheapy that fits.
If that's not the case, try the instructions I gave in this link.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 05, 2011 | Saws
I have an old rockwell 14" bandsaw and am having
Follow these instructions, but before adjusting the guides see the link below.
It sounds like you have not correctly adjusted the guide blocks that ride on either side of the blade, both above and below the table. These small rectangular blocks can be adjusted by loosening the allen set screw in the guide that holds them in place. They should be pressed in against the blade lightly, without deflecting the path of the blade out of square to the table. (You may first have to sand the ends of the guide blocks square if they are grooved from use. Use a belt sander and a pair of vise grips to hold the blocks while you square them off.) Anyway, the guide blocks should allow the blade to run smoothly, (you might hear a tick tick of the weld passing through the blocks), but will not allow the blade to deflect from side to side. Correctly adjusted, they keep the blade aligned with the bearing behind it, and prevent the problem you describe.
Only after you have correctly adjusted these guides just behind the set of the teeth, and the blade is turning freely by hand when you spin the upper wheel, do you bring the bearings in to kiss the back edge of the blade. Make sure the bearings are lubed to spin freely with a little bearing lube or wd40, then bring both the uppper and lower bearings in until they almost spin or just barely spin when the blade is turned by hand. When you exert a little pressure during cutting they will then hold the blade in place between the guide blocks, so the blocks don't wear the teeth away. Please see this link for detailed instructions I gave another user. (possibly also here) They will apply to your saw as well. If you have any questions or further probelms, write back. You may also wish to check here for a pdf manual for your saw.(check both rockwell and delta).
If you take some care to properly tune the saw, you will get much beter cuts and the saw will be a joy to use.
Nov 26, 2010 | Delta Woodworking Delta Rockwell 14 Inch...
Looking for owners manuals for 2 saws
Your Delta radial arm saw (RS830) manual is here. Exploded diagram for parts, etc is here.
I'm not sure on the Rockwell, but here's a link to a manual for a Rockwell-Delta 10" Tilting Arbor Unisaw, circa 1969 which seems about right for a 34-466.
If that's not quite right, there a couple other manuals for old Rockwell saws here.
If this answer helped, please vote. Thanks!
May 19, 2010 | Delta Saws
Wood like to clean & update my rockwell model 14 band saw need a download of this saw
try there web sight, if I'm not mistaken, Delta bought out rockwell and they should be able to help. I had an old rockwell table saw and the man shaft that the blade attached to was missing.I contacted delta with the model number of the saw and they faxed me a blue print of the shaft and we machined a new one and the saw still works great.
Jan 18, 2009 | Delta 28-060 14'' Band Saw Blade 93-1/2''...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
