Question about LG LSC121PMA Split System Air Conditioner
C6 error code on LG art cool
Outside unit will not start,fan will spin if you kick start so it seems to be a cap. at fault? the start up caps. seems to be part of pcb,can these be changed or is it a new board? fan for outside unit when spinning is very slow,runs 20 mins then c6 again.. can i check voltage to compressor,or windings resistance. any help on this would be great,thanks phil.
  • Anonymous Jan 30, 2009
    same problem here :P
  • 3 Answers
Condenser fan windings are rooted. No capacitor due to multi speed. Replace condenser fan motor they just clip on pcb.
Posted on Feb 08, 2011
Try turning the power off at the fuse box, waiting 5 minutes turning the system back on and spray some water on the vents on the side of the outside condenser. If the fan isnt spining get a twig and spin it in an anti-clockwise direction after 1 or 2 spins it should start spinning on its own. continue to hose the vents with water for another 5 minutes. Its important to have the fan spinning as it extracts the heat from the condenser box.
Posted on Jan 31, 2009
Error code 10
Check to see if condenser fan (condenser is the outdoor unit) is spinning freely
Aug 08, 2014 | LG Art Cool LA181CNW Split System Air...
No heat but fan keeps running
If the air conditioner compressor runs all the time the main control board might be defective. The main control board provides the voltage to the fan motor and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Nov 25, 2013 | LG LAN186HV / LAU186HV 18,000 BTU 15 SEER...
Rheem condenser fan don't spin up under it'sown power.
If you have a multimeter that tests "uf" or "mfd" that is microfarads. That will test the capacitor. Turn off power to unit, touch top of cap with insulated screwdriver across terminals to discharge and remove fan and common. MARK WHICH WIRES GO WHERE. Or if no mfds on multimeter, amps×2650÷volts=mfd. Amp draw on fan wire off of cap times 2650 divided by the volts between common and fan on the cap. If cap is good it's likely the motor.
Apr 12, 2017 | Heating & Cooling
My Armstrong Concept 1200 stopped working yesterday (model EFC14MAA-1A, Serial # 6099F44101, 42000 BTUs). All breakers are OK. On the outside compressor unit, I can depress the relay and the fan and...
sounds like your problem is in the air handler. Sounds like the fan is not kicking on in the air handler this could be the board or the cap or fan motor you can run a micro farad test on the cap that goes to your evap motor be sure you take the leads off the cap and the mf are written on the cap itself. does the outside suction line which is the big line starting to freeze up? you can check your motor winding by running an ohms test across the motor winding. You do this by reading on the motor which wires goes to your start and run windings. You should get and ohms reading and if they are bad you will get infinity.
Jul 31, 2011 | Heating & Cooling
LG air conditioner 24awn error code message Ch 6 inside fan runs outside unit not working
CH-06 REFERS Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor. THANKS.
Dec 13, 2010 | LG Art Cool LA121HNP Split System Air...
Fan does not spin
Window unit or outside unit? Start and run caps are large problems,especially after several years operation or a lightning storm. Post more info. A humming sound in a fan or compressor that won't start usually means the capacitor got blown out.. It cost less than $30. (plus service call). LOL
Dec 10, 2010 | Heating & Cooling
The fan on the Ruud furnice unit runs all the time but the Ruud ac unit is not kicking on . I know nothing about any of this but would like some Ideas what I might check. I went outside and could not find...
Some Ruuds have a red rubber cap reset button on the bottom of the unit or inside. Usually the fan quits and trips the switch. Or look at the metal run cap with 3 leads on it, if it looks bulged(concave on top) and not flat and sunk in, replace that and ur good to go. Let me know. Please pull the power disconnect if you attack the cap, and write down what leads come off which terminals. azeddysac@yahoo.com
Aug 14, 2010 | Ruud Central System Air Conditioner
LG Art Cool Error Code CA
Compressor discharge sensor fault. Disconnect from PCB measure resistance 237 kOhm at 20°C, 168 kOhm at 30C. Replace sensor.
May 04, 2010 | LG Art Cool LA181CNW Split System Air...
Heating & Cooling Logo
1,011 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
