Question about Seagate Technology 500GB Pipeline HD SATA 3Gb/s Internal Hard
Will a seagate pipeline 500 gb hdd from a lorax dvr work in a pc?
My main hdd is ide, but i run sata for storage. if this pipeline is advisable i would convert over to all sata.
  • 4 Answers
Yes it will work in a PC. All 3.5" sata drives are standardized. Connect it via a SATA cable and you will need to format the drive to work with windows. To do this:
1) Right-click on my computer
2) Click on "Manage"
3) Click yes to allow if any dialogue's pop up.
4) When the menu pops up look at the left side menu and click on "Disk Management"
5) Look for your drive in the list when it populates. It should show a 500GB drive and it may show an error on it since it is not formatted for windows.
6) Be sure this is the correct drive you want to use! Formatting it will erase EVERYTHING on the drive.
7) Right click on the drive in the bottom list and select the Format option.
8) Give it whatever name you want, make sure the format is set to NTFS, check the box for quick format.
9) Let it format, this should only take a few minutes. After that it will show up as a blank drive in My Computer!
Posted on Oct 28, 2012
  • martin kirkman Dec 07, 2012
    thanx again for your input. ive been using this drive to sore movies, and it is awesome. i divided it up into 100 gb partitions thinking i would never use that much space, but movies and games take massive space. im already wantin a couple tb's now.
    pardon the typos
    Genius:
  • 1,552 Answers
Note that the disk-drive is 5900 RPM -- a little faster than the "usual" 5400 RPM, but not as fast as a brand-new 7200 RPM disk-drive.
Posted on Mar 10, 2015
Seagate pipeline hdd 500 gb. can I remove it from a lorex dvr, and put it in my pc?
Any drive will work - but you have to make sure that its physical configuration matches your pc and that you reformat the drive since the format used for dvr use is not compatible .
Sep 21, 2017 | Seagate Barracuda 7200.10 ST3250310AS SATA...
Can i just hook it up and run the disk wizard? or is there another formatting ,partitioning tool I should get?
Use Disk Wizard. No 3rd party tools are required at all.
Scenario: 1 Pipeline SATA. 1 Barracuda SATA. 1 IDE drive with current OS. Is this correct?
Just treat the Pipeline from the DVR as an extra drive by formatting it, and moving the files over. You then can remove the IDE and Pipeline for peace of mind, but the OS advance setup should give the option of all three drives for install destination.
Leaving the IDE drive should not affect your resources.
Oct 25, 2012 | Seagate Technology 500GB Pipeline HD SATA...
I had four broken DVRs of same type, I want to use their HDD in raid strip in PC, but they are DVR HDDs (Seagate Pipeline HD.2, ST3250312CS) and they are not initiable in PC. Is there any way to use them? ...
The SATA RAID interface needs to be compatible with SATA revision V2.0. Check the drives with the Seagate diagnostic tool (download it from Seagate) for correct operation. This will also check / test the SATA interface. Connect the drives directly to a PC with SATA interface to do this. If proven OK then use the RAID board.
Possibly there's a way to downgrade to SATA-1 using a Seagate tool.
Jul 05, 2011 | Seagate Barracuda 7200.10 ST3250310AS SATA...
I try to install any os to this seagate barraguda 7200rpm, 80 gb hdd don't have completed installtion successfully. many files are missed. some times do not detecting the hard drive.
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
good luck
Aug 30, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
My motherboard P5KPL-CM sometimes does not detect my seagate Barracuda SATA HDD (500 GB) at all. plz advise.
In this situation the you need to check the IDE or SATA connector. I have already experience this problem before I tried to replace the IDE cable and I will fix it. Replace the IDE or SATA cable with a new one and make your HDD first boot to your BIOS.
Regards
PCmania
Sep 28, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Segate SATA HDD Cannot perform properly
Go to BIOS at machine startup. check the device, make sure hte SATA is set not at IDE.
Apr 09, 2009 | ASUS K8V-X Motherboard
My new 500GB SATA II HDD gets heated very quickly and I have my old IDE HDD still working and it doesnt get much heated even if it is on for 12hours continously. Just in a matter of 15 to 20mins the...
This is normal. SATA II drives spin much faster and run much hotter then IDE drives. You can attach a hard drive cooler to the hard drive if you wish and if there is enough room in your case.
Dec 20, 2008 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Hp compaq dc7600sff
750GB Seagate Hard Disk Drive IDE ATA100 7200rpm 16MB
available at http://www.microdirect.co.uk/(17679)750GB-Seagate-Hard-Disk-Drive-IDE-ATA100.aspx
1TB (1000 GB) Seagate Barracuda SATA II 300 32MB cache
also available at http://www.microdirect.co.uk/(23250)1TB-1000-GB-Seagate-Barracuda-SATA-II-300.aspx
Both HDD`s are what i consider to be best in there range and very good value for money
Nov 19, 2007 | Computers & Internet
Seagate Technology 500GB Pipeline HD SATA 3Gb/s Internal Hard Logo
284 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
