No paper in output bin, but still "Out-bin Full" error message, preventing printing.
SOURCE: I have a samsung CLX 3175 FW printer. Paper jams
The limit switches are just flags that block or unblock photo sensors. Try blowing the printer out with some canned air, paper dust on these sensors is a common cause of these problems.
Testimonial: "Thanks very much, I'll try that - I'd like to think it was as simple as that! Kind regards Ray"
SOURCE: i am getting deve home sensor error on my samsung
Dev. Home error can be fixed by stretching out a solenoid spring on the power cord
side of the printer. The solenoid acts as a clutch to stop the spinning
developer actuator at the right spot.
The problem is that the spring gets weak over time / the cogs round out
over time and the solenoid finger is overcome by the spinning cogs, and
resulting in selecting the wrong developer.
Open up the right side (power cord side) of the printer (take off top
cover, then take off side cover). Then, find a solenoid (little metal
square) that touches the white plastic vertical spur gear. Take the
spring off the solenoid. Now, put the spring back on - only this time
you will attach one anchor point to the middle of the spring as to
pre-stretch the spring for more tension.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
