Question about LaCie (301146U) 320 GB FireWire 400 (1394a) Hard Drive
Drive not ready on external hard drive
Have looked at other solutions on this site, which either haven't helped, or were not applicable. I have a standard - not Firewire - LaCie 320GB external drive which has been working fine for 15 months. When I went to turn it on recently, I got the "Drive not ready; door may be open" error message. I've tried a system restore prior to the date of the first error, which didn't help. 'm using Win XP Pro.
I've not made any modifications to the OS recently. About the only thing I've done is update Java run-time. The system restore I did should have bypassed any changes made by Java.
I think my device drivers may be corrupt. I'm just not quie sure how to fix this.
    Sergeant:
    Novelist:
  • 190 Answers
If you or a friend have another computer, please try plugging the drive into another computer. If it shows and works correctly then there are 2 other things I would try. You may have done this already but try a different usb port. If you are using a front port, try using one of the rear ports. I find that the front ports are not as reliable as the rear since it adds another short portion of cable and an additional connection at the mainboard. You may have received an update that made the USB act differently. The second thing I would try is plugging in the drive and then before trying to access the drive, run a hard drive diagnostic like Western Digitals diagnostic for Windows or Maxblast. You may find that the drive has failed. Its also possible that the enclosure has failed. If all else fails, try taking the drive out of the enclosure and puting it directly into a computer. You may be able to transfer data to another drive if you can see the information on the drive you have removed from the failed enclosure. Hope this helps... Dale
Posted on Jan 03, 2009
How to Transfer Email Backup To External Hard Drive Automatically?
You can setup TIme Machine and configure your external hard drive for the backup. Selecting the external hard drive will setup the Time Machine to backup Emails directly to the external hard drive. Here's how you can do it: https://support.apple.com/en-us/HT201250
There is another option available called the Mail Backup X. This application is specifically for email backup and you can link your apple mail database backup directly to the external hard drive. It has an inbuilt option to do so. Also, you don't need to backup the entire Mac as in the case of Time Machine. This application will only focus on your email database.
Here's how you can do it, have a look: How to Automatically Backup Apple Mail Mac Mail Mailbox Data on Mac OS
Aug 30, 2017 | Apple Computers & Internet
Tip
Formatting an external hard drive with Mac OS X's Disk Utility
Formatting your new external hard drive is not as difficult as you may think. In fact, you don't even have to be a computer techie or uber-Mac geek to perform this procedure successfully.
The tool you would use, to format your drive within your Mac OS X system, is the built-in utility application called Disk Utility.
Disk Utility is Apple Inc.'s defacto utility application, for performing disk related tasks within the Mac OS X volume.
From creating new images, to burning CDs and DVDs to formatting hard drives, Disk Utility performs well enough to keep not only your Mac OS X volume on your hard drive error free, but keep your hard drive healthy and error-free as well.
I could go on in detail, admirably describing more features of this versatile Mac OS X tool, but the purpose of this FixYa tip, is to show you how to easily format your external hard drive. So that is where I will take you now.
There are generally two formats in Disk Utility that you can use to effectively format your hard drive.
Mac OS Extended (Journaled) - if you want a Mac readable hard drive only
MS-DOS (FAT 32) - If you want your external hard drive to be read by both Mac and PC.
--STEPS FOR FORMATTING YOUR HARD DRIVE WITH DISK UTILITY--
• First, make sure your external hard drive is connected securely to your Mac and is turned on.
•Next, from your desktop, click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Utilities from the
drop-down menu. This will take you to your Utilities* folder.
(*You can also get to the Disk Utility application via Applications > Utilities folder)
• Now, locate and launch the Disk Utility application.
When Disk Utility opens you will see a left side window, which will show
all connected hard drives and optical drives. It is here that you
should see your external hard drive listed in that window.
• When you locate it, simply select it and then select Partition
from the tabs on the right hand side.
• Change the Volume Scheme from Current to 1 Partition
• Make sure to provide a name for your new external hard drive.
• Select Mac OS Extended (Journaled) from the Format
drop down menu, for a bootable Mac only external hard drive.
• Or select MS-DOS from the Format drop down menu, for a bootable Mac & PC external hard drive.
From there, click the Options button, located toward the bottom of
your window.
This will open a partition scheme selection window as seen in this screen shot:
• Select GUID Partition Table for bootability on a Intel processor based
Mac.
• Or select the Apple Partition Map for bootability on a PowerPC based Mac.
• Click the OK button.
Finally, click the Partition button and allow Disk Utility to format your new external hard drive.
When this process is complete, you now have a newly formatted, ready to use hard drive.
Believe it or not, this process can be completed faster than you think.
Using this method with Disk Utility, I was able to format my new 1TB Iomega USB external in less than 20 minutes.
Final Note:
I used the external hard drive as the focus for showing you how to format and prepare your hard drive for use on your Mac, but this feature can also work with internal hard drives as well.
For more information about some of the disk repairing features of Disk Utility, here is a great support link for this nifty and quite effective Apple utility for the Mac OS X platforms:
Using Disk Utility to repair a disk
Thanks for reviewing my Mac OS X Tip!
Regards,
-Mactechtrainer
on Feb 11, 2010 | Computers & Internet
I have had my external hard drive for approx. 1 year and haven't ever set it up. Now that I am ready to do so, I cannot find any of my paperwork. I looked at troubleshooting options on your websites...
google and type in-- manufacturer of ( make and model) hard drive
when that site comes up look for a web page for the manufacturer that has driver downloads
select the model and download the driver
so if it is best western make as an example
google best western model xyz( what ever it is )
best western pages will come up and one will show up as drivers and software downloads and updates
click on that then select downloads and high light the model
click on down load
that will put the driver onto your computer
when downloaded , click open then run
now power up the external hard drive and plug it in
a sign will come up as new plug in found , checking for drivers
next sign will say hard drive ready to use
Oct 18, 2017 | Iomega 1TB Prestige External USB 2.0 Hard...
I have just brought a sandisk cruzer edge USB flash drive (16GB) for backing up files on my apple mac. When trying to copy files it says "cannot copy because not enough free space". I...
  • you need to "format " the flash drive first on the MAc, than you can save /copy of your files..
here is how you can format it:
How to format external hard drive?
Open the Applications folder,
open the Utilities Folder,
then open Disk Utility.
Select the drive, click erase,
choose the name and format of the drive,
and click erase.
For more detailed way of formatting ,you can visit the URL below..,
http://www.ehow.com/how_5777700_format-drive-mac-os-x.html
Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
Jun 25, 2011 | Computers & Internet
How does a hard drive looks like? I'm getting a error msg saying that hard drive is bad!!
How old is your hard drive ? Hard drives eventually fail due to normal usage or it could be something else. You need to provide more information.
Nov 07, 2010 | Computers & Internet
Malfunctioning WD passport that windows doesn't detect.
Inside the case is a regular laptop size harddrive.
Laptop harddrives are 2.5 inches across. (2-1/2 inches. Desktop harddrives are 3.5 inches)
I would suggest the external enclosure the harddrive is in, is defunct.
I would suggest buying a new external enclosure, and putting this harddrive in it. Then just plug the USB cable in, (As you did before), and download your data, to be ready to transfer.
You need an external enclosure that is Sata, and is for a 2.5 inch harddrive. These are relatively inexpensive.
Let me show you some examples:
1.http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2783&name=2.5-eSATA-Hard-Drive-Enclosure&Nav=|c:2781|&Sort=0&Recs=10
May 10, 2009 | Western Digital Passport WDXML800UE...
Transferring data from an external hard drive
Best solution is to make an image of the PC and then use that image to transfer it back. Norton Ghost is a good application for that, but there are more.
Jules
Mar 02, 2009 | Western Digital Computers & Internet
Computer doesn't detect
This is the best solution, unplug the device carefully, pick it up slowly, go to your room and stick it up your ***.....
May 30, 2008 | SimpleTech Pininfarina 80GB External USB...
Using external hard drive for running applications.
FOLLOWING THINGS U SHOULD KEEP IN MIND WHILE GOING FOR EXTERNAL HARD DRIVE :-
1. PURPOSE OF EXTERNAL DRIVE - MEANS U WANT TO KEEP THAT TO USE IT FOR BACKING UP OF DATA?
2. DO THE COST EFFECTIVENESS OALSO EFFECTS UR PURCHASE?
3. TELL THE SPECIFICATION OF UR PC TO THE VENDOR BEFORE U BUY A NEW EXTERNAL DRIVE, AS IT MAY NOT SUPPORT SOME TIME.
4. ..... MAYN MORE...NOT COMMING TO MIND NOW... :-)
Apr 11, 2008 | Computers & Internet
Using a hard drive for running programs
Hi ambladybut
It's true, you CAN choose to install applications to a drive other than the usual default location of c:\program files\newsoftwareprogram
However---- the operating system will still need to know all about these applications. It will keep information about these applications stored in locations on the laptop's internal hard disk, including in your user profile directory (c:\documents and settings\youruserprofile (if you're using WindowsXP)), the system registry, and various other locations depending upon the software.
These applications will also install shortcuts for accessing them to the Start Menu and Desktop.
Finally, where they store their data (unless you configure them differntly) will also be saved to the laptop's internal hard disk.
So, whether installing the applications to an external hard disk will achieve what you are attempting to accomplish will depend upon your reasons for doing so:
(A) Do you want to use the external hard disk in order to save space on the laptop's hard disk? If that is the case, then using the external hard disk would meet your needs.
(B) Do you want to use the external hard disk for privacy or security reasons? If that is the case, then an external hard disk would not be the appropriate solution for you.
In the case of (B), there are other solutions. Rather than delve into them yet, let's find out what you would like to accomplish w/ respect to segregating your home and work applications. Then we can point you in the appropriate direction.
** We WILL keep working w/ you until all of
** your questions have been answered.
** Please, don't assign a rating to any of
** the experts' answers or recommendations
** until that time. Once ratings are assigned,
** the problem will be closed and we won't
** be able to continue to assist you.
** Once your question(s) have been ans-
** wered, please do, take a moment to rate
** the participants' solutions.
Thank you,
BJ @:)
LaCie (301146U) 320 GB FireWire 400 (1394a) Hard Drive Logo
301 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
