Question about Dimplex OFC2000TI Heater
The LCD (24 hour timer) is blank so the heater wont work
Dimplex OFC2000TI Heater - The Neon light is on but the timer LCD stays blank. The little power light is off. I'm cold. Please help.
  • 499 Answers
There is nothing you can do, turn on your oven if electric, or if gas open a window 4 inches and dont sleep with a gas burner running.
Posted on Oct 26, 2012
  • 5 more comments
  • Rory B Oct 26, 2012
    Thanks for the reply but it doesn't really help since I dont have an oven in my bedroom. Maybe I could sleep in the kitchen. Maybe I am missunderstanding your solution. Anyway thanks for the suggestion.
  • KD Grayson Heating,Air conditioning & Refrigeration
    I assumed you would know to leave the door open to your room, silly me,
    I also mentioned DO NOT SLEEP with this burner on.
    As I stated before, it is not repairable.
  • Rory B Oct 28, 2012
    Ah ok, thanks. Not repairable. Bummer. Going to be a long winter.
  • F Flannelly
    F Flannelly Feb 12, 2014
    You could always by pass the timer... same happened to mine and I managed to bypass the timer. There are 3 wires entering the timer... the blue one can be disconnected at source whilst removing the other 2 wires from clock and joining them together should do the trick... If you don't know what your doing an electrician should be able to do this fr you rather than having to bin it and buy another heater!
  • F Flannelly
    When the blue wire is removed at source the light on timer will not light so guess this wire is the power feed... Clock not repairable as per previous comment but heater can be saved... although at this stage this advice maybe a bit late!!! lol
3 Suggested Answers
SOURCE: I have two dimplex XLN storage heater, it was
It sounds as though it has tripped the internal cut-out - this can be manually reset quite easily by yourself. It would probably be best to ring Dimplex customer services on 0845 6005111 to get them to talk you through it step-by-step though.
Posted on Dec 21, 2009
SOURCE: My dimplex night storage heater is not heating up,
thermal heat line melted just 2years 3 weeks old should this heater have been recalled some were put in by the warm front scheme frozen old age pensioner
Posted on Jan 19, 2010
I have a small wall heater, towel rack included, the fan & timer work, but no heat. Where do we find the model number
Usually on a small sticker on the back near where the wire goes into it.
If you know the make you can Google it and look at the images tab like this for 'Dimplex bathroom fan heater'.
dimplex bathroom fan heaters Google Search
Jan 22, 2016 | Heating & Cooling
Cant get the heating to come on ~~ all red lights are working
If it's warm that's all you get, I have one and it's worthless, I have to hug it our have it between my knees with a blaket arounf me and the heater.
Oct 11, 2014 | Dimplex OFC2000 Oil Filled Radiator Heater
Dimplex electralog is making an intermittent squeaking sound?
When it is switched off try spraying WD40 around end of spindles. Try heater again after about an hour.
Nov 30, 2013 | Dimplex Compact Electric Flame Stove...
Dimplex PW4 timer not working with heaters
In UK, you can call 0845 600 5111
The manual is very unclear about:
1) Wiring.
2) Resetting the timer when encountering a problem due to surge, power outage, or malfunction.
3) Troubleshoot section is missing.
http://www.dimplex.co.uk/assets/kb/operating_instructions/0/RXPW4_Instructions_Issue_4.pdf
Jul 25, 2012 | Dimplex Epx1250 Panel Heater
I have lost the brochure for my heater, the Dimplex Eco 2.4kW 11 Fin Column Heater.how do you set the timer?
Emily, if you live in the USA, contact Dimplex Technical Service 888-346-7539 for that information, as well has getting a replacement Owners Manual.
Apr 18, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
Hi, I don't know what the reset switch on my dimplex ofc2000ti looks like, anyone any ideas? Power to unit but not heating up, all connections inside fine. Hopefully it overloaded and tripped.
Turn the Master On/Off Switch to OFF and unplug the unit from the wall receptacle. Leave it unplugged for 12 - 15 minutes. That should give it enough time to reset itself. Then plug it back in and give it a try. Also, make sure that the wall receptacle is working properly and hasn't tripped the circuit breaker in your home's circuit breaker panel. If it did, something is seriously wrong electrically, with the heater.
Hope this helps you solve the problem. Please don't forget to rate my response to your question.
Thanks!
Mar 25, 2011 | Dimplex OFC2000TI Heater
How do u set a 24 hour timer on a dimplex storage heater!?
You posted question under 24-hour dimplex timer.
I have extensive files on timers, and don't show that timer.
1) Add a comment with photo of your timer:
And include voltage that you are working with, and type of Load that timer controls
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
2) Add a comment with clear description of timer and timer buttons/dial so I can compare with my files.
And include voltage that you are working with, and type of Load that timer controls.
3) Open following link to identify same-similar timer and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 20, 2011 | Timex Multiple Setting Timer
Dimplex OFC2009TI programmer not working
yeah i now have this problem did you find a solution?
Jan 26, 2010 | Heating & Cooling
Heater fan stop working after a couple of muinutes
Dimplex Electralog Model 6901050600 Ser 17807D2F - 048 Blower and Heater Works fine, Flame has quit working. How do you find and replace the Bulb? Email cairoeichard@gmail.com
Jan 02, 2009 | Dimplex Compact Electric Flame Stove...
Dimplex OFC2000TI Heater Logo
460 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
