Question about Tatung V23CLTT 22.92 in. LCD Television
HDTV not picking up local channels
It says it has an internal tv tuner and is HDTV ready but doesn't seem to pick up signal from an antenna. Do I need an external tv tuner?
    Top Expert:
  • Tatung Master
  • 14,553 Answers
Look to see in menu if set is set to Air or Catv (cable) if on cable anything is possible 2-13 but above that no or almost no reception.
Posted on Oct 26, 2012
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
TV won't pick up channels 7-13
These are what once were VHF channels and are still mostly assigned to local stations.
You didn't mention the source for your received signals, if antenna, cable or satellite and it does make a difference as to the possible source of the problem.
If you are receiving via antenna, then the problem is within the set itself. If from one of the other two sources requiring a 'box,' then the problem is likely within the cable or satellite box that is between your incoming signal and the set.
Jul 29, 2012 | Magnavox 39" LCD 1080p HDTV 39MF412B -...
Emerson hdtv does not pick up any antenna signal
With digital OTA TV signals, a lot of things could cause you to fail to pick up a signal on any channel. First, do you have an indoor or outdoor antenna and how far are you from the transmitters for you local stations? Digital signals are either enough to for the tuner to interpret or you get no signal. Next check that the antenna is pointing at your stations' transmitters. Use antennaweb.org or tvfool.com to check the direction for your location. Antennaweb assumes an external antenna and provides a very conservative list of stations.
Check for buildings, hills or tall trees that might block the signal to your location.
If your antenna is providing a signal to several TVs, try a direct connection (taking out the splitter). You may need an amplified splitter to minimize the signal loss. Note: amplifiers (whether at the splitter or part of the antenna) can fail and become signal filters (blockers) instead. The direct connection tests this as well.
If another TV does pick up the signal from the antenna (at this point), then the tuner may have failed. It may also just be a weaker tuner compared to the other TV. Surges (for example, lightning strikes) can cause a tuner failure. In that case, you need a new tuner. (a stand-alone tuner like the converter boxes might work) or try a site like shopjimmy.com, searspartsdirect.com or partstore.com. SearsPartsDirect lists the tuner here: http://www.searspartsdirect.com/partsdirect/part-number/Emerson-Parts/Television-Parts/UTUNATSSP006/0057/528/Model-LC320EM9/0352/0333600?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=50034435&diagramPageId=00001&productTypeId=x&searchModelNumber=LC320EM9&subCompDesc=Lcd%20tv&brandDesc=EMERSON&modelDesc=LCD-TELEVISION&blt=11&shdMod= .
This TV was made by Funai so you may see other TVs that use the same part.
I hope this helps.
(I have two TVs with different quality tuners. With one, when the antenna shifts slightly out of place, I can lose the ability to tune in the channels from the closest transmitters. The other TV does not lose the signal until the antenna rotates more than 90 degrees from its usual position.)
May 27, 2012 | Emerson LC320EM9 32 in. LCD HDTV
I have done an autotune on my sony bravia tv but am not getting channel 9 sbs. the television in the bedroom is a smaller digital tv and that picks up all the channels. the two tv's are connected
Is the splitter an amplified splitter or not? Have you tried the channel search when you connect the antenna directly to the TV? (Disconnect the cables from the splitter and use a coupler to join them together.) Tuners do vary in their sensitivity. For digital signals, your TV should report the signal strength. This is often under the Settings sub-menu. Some TVs will give this information in the Channel Edit option.
If the straight through connection gives a better signal, check your antenna direction and try a different splitter. Amplification will often help; however, when my amplified splitter was damaged the less sensitive tuner lost a number of channels that the other TV received. (Looking at the signal strength, one TV was getting adequate signal with one bar out of 8. The other needed at least 4 bars to process the signal.)
I hope this helps.
Feb 01, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Cable in my area has switched to digital cable. I own a Hitachi HDTV about four years old. When I scan my channels it will only scan analog channels...the digital channels are an option but I don't...
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: http://www.retrevo.com/support/Hitachi-65F59-TVs-manual/id/371ci977/t/2/ . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See antennaweb.org or tvfool.com for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
Sep 06, 2011 | Hitachi 65F59 65" HDTV
Is jvc av-32d503 digital ready or do I need to buy a converter box for use with an outside antenna system
Looks like you'll need a converter.
Here's some background info:
Analog TVs were made up until 2007.
Digital tuners for over the air signals are called "ATSC tuners".
To tell if your TV has one:
-If the TV was sold as a "HDTV" or "DTV", it's supposed to have an ATSC tuner built in to it. "HD ready TVs" do not have a digital tuner.
-Check the specs in the owners manual or google the make & model of the TV to see if it has an ATSC tuner.
-If your TV's menu has an option for scaning for digital channels, then it has an ATSC tuner. If it dosen't have a way to scan for digital channels, then it doesn't have a digial tuner.
Most DTVs also have a digital QAM tuner that is used in some (but not all) cable systems.
Jun 11, 2011 | JVC AV-32D503 32" TV
Really? cool... so I have a Panasonic HDTV 720p... just moved, no cable, but I have a TV antenna. Amplified indoor antenna. GE brand model 24700. I powered and connected the coaxial cable between the tv...
You need to go into on screen TV tuner/channel scanning setup page and change the signal source from CABLE to ANTENNA so it will scan again to pick up off the air signals. Please read the TV user manual for more details.
What is the model number of the TV?
May 15, 2011 | Televison & Video
Internal antenna
It sounds like the TV justs has a insufficient internal antenna system. If you can put an external antenna on this sytem do so just to test it.
Sep 21, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Tatung V23CLTT 22.92 in. LCD Television Logo
87 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
CoppellTVRepair.com
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
