Question about Sony VAIO VGN-NR498E/S Notebook PC
Need to get winVista Home from Sony Vaio VGN-NS230E recovery disks to new 1TB HDD
The BIOS sees the new drive and 1TB capacity, but does not allocate a drive latter. When I try to use the recovery disk kit, it recognizes drive 'C' and also a 10GB partition that has no drive allocation letter. Thank you.
  • 2,878 Answers
Could be a recovery partition. Could be hard drive software partition. Could be junk.
Leave it and have an extra 10GB drive later. Or, delete it and take advantage of the space. If the recovery recreates it you will know where it came from.
On a side note, I suggest partitioning the 1TB drive. Make a OS partition, and possible 2 other partitions. It will help with defrag and keep your important files out of the OS side in case another recovery is required.
Posted on Oct 26, 2012
SOURCE: I need a recovery disk for Sony Vaio VGN-NR11s/s
here is a disc made by these guys http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/
both 32bit and 64 bit
in your case the VGN-NR11 is 32 bit
Posted on Aug 03, 2009
HW_Dude
  • 87 Answers
SOURCE: Sony Vaio VGN-SZ460N - freezes on System Recovery
I put my money on that you have a CPU over temperature problem, and/or intermittent RAM problem.
Be sure you are ESD safe when working on the electronics as follow !
I suggest, using a eye piece magnifier and a wooden tooth pick and carefully touch each pin of your RAM sockets and see if the soldering is bad, allowing the pin to move slightly. If that happens, well it needs re-soldering there, make sure you use leaded solder, not the ROHS crapp.
If that turns out to be ok, then check your processor. It might over heat.
You may want to observe if the CPU fans runs at all and if it runs at full speed most the time, even if you don't run any 'heavy' programs. This usually would indicate poor heat dissipation. Most Sony Laptops have a piece of thermal foam pad is used for heat transfer from the CPU chip into the heat sink. Over time this pad shrinks, effectively impeding the heat transfer causing the CPU to over heat and intermittent shutdowns ect. I suggest, find a new piece of thermal pad or replace that with a piece of copper sheet material and use Thermalloy transfer paste.
Posted on Aug 01, 2009
  • 114 Answers
SOURCE: sony vaio vgn cr200e drive
Western Digital Scorpio WD5000BEVT Mobile Hard Drive - 500GB, 2.5", looks nice. I haven't seen any larger yet.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4322423&CatId=1277
Posted on Jan 16, 2009
micromend
  • 748 Answers
SOURCE: Sony Vaio VGN-NR498E recovery disk
Hello
Well, the recovery disks won't allow you to go to your present system. The recovery disks are designed to put everything back the way it was when you bought the computer, minus all your applications and data. If it's your data that you need then a reputable repair service like mine can slave your hard drive to another system and recover all your data (not applications), provided the hard drive has not electronically or mechanically malfunctioned. Again, a reputable repair person can tell you the status of the hard drive.
Thanks
Posted on Jan 07, 2010
SOURCE: recovery error 320 on sony vaio laptop
Ketanvasu your an idiot....If he's trying to recover the laptop obviously the thing isn't working...so how the hell is he supposed to burn cd's genius?
Posted on May 18, 2010
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Sony VAIO VGN-NS230E vga
Look and see if it appears as a monitor in your display settings, if it doesn't, then another good first step would be to update your video card drivers (go to this page and select "Video" then download " Intel Graphics Driver"). If none of this fixes it try the VGA cable with a different PC and see if it works.
Oct 20, 2012 | Sony VAIO VGN-NS230E/W Notebook
I want to upgrade my Sony Vaio VGN-FS630/W - which largest storage hard drives are compatible and what specifications should I search for while purchase?
From the age and specification of your Sony Vaio VGN-FS630W laptop you will need to buy a 2.5inch IDE internal disk drive if you wish to upgrade the existing drive.
The capacity you select will depend on how much money you want to spend as disk drive prices are much higher at present due to problems in the countries making these in the Far East due to flooding.
The machine should have come with an 80GB drive so you should be able to upgrade to a 320GB IDE drive with no problem - higher capacity IDE drives may be harder to find as the majority of drives today are SATA technology.
The procedure to replace the hard drive is described with graphics in a document provided by Sony Support.
You will also need software to help you migrate your existing operating system, programs and data from the old drive to the new drive unless you intend to perform a clean install of a new version of Windows.
There are a number of commercial or free utilities that can help you do the migration - Acronis True Image (commercial) is very good and effective but has to be bought - alternatively, Easeus Todo Backup is a free utility that can do the same. Paragon Software also offer several free utilities that can help you backup your existing drive and restore the backup on to your new drive - Paragon Backup & Recovery 2012 Free is one of these.
Dec 24, 2011 | Sony VAIO VGN-FS630/W Notebook
Vgn-nr185e (sony vaio) read error.. alt+ctlr+del to restart
what are you using to reformat the hdd? if you havent formatted the hdd using any retail version of od disc, youmay try to access the vaio recovery partition.. that is when you restart the computer, then press f10 key repeatedly for 5-7secs. it will load vaio recovery center. then from there, select restore c: drive. follow on-screen instruction and it will format the hdd. process may take for 45mins up to an hour
Mar 18, 2010 | Sony VAIO VGN-NR180EW Notebook
Vgn-fs630w won't reboot and also when try with reboot disk it won't read...just continuous boot over and over again after "window loading" screen.
Sounds like you may have 2 problems, that is
1) corrupted windows installation or faulty Hard drive causing the constant reboot.
2) faulty CD drive or dirty laser or dirty disks.
You could try pressing F10 when you see the vaio logo which will take you to the HDD based recovery options.
Test your cd/dvd disks in another machine to make sure they are o.k if they are you can try cleaning laser in cd drive.
Or if the disks are o.k and your cd drive is faulty you could use an external usb cd drive and set the bios to boot from an external drive.
Feb 24, 2010 | Sony VAIO VGN-FS630/W Notebook
Recovery error 320 on sony vaio laptop
May 09, 2009 | Sony VAIO VGN-NR498E/S Notebook PC
Reinstall from the recovery disks
To ge into de BIOS hit:
Sony: (F3) while you are starting the PC, then (F2) or (F1)
Nov 18, 2008 | Sony VAIO VGN-S460 Notebook
Sony VAIO VGN-NR498E/S Notebook PC Logo
154 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
