Marantz SR5600 Problem
The volume on my Marantz SR5600 is stuck between 66 and 68. I can't get the volume to go higher or lower. Any ideas? Thank you!
  • alan512 Jan 03, 2009
    To petraman7 - Thank you for your reply. I am in Denver, Colorado. Do you have a recommendation for repair shop?
    Thank you. Alan
    Genius:
  • 1,175 Answers
HI...
From others I've worked on it appears that some solder joints on the volume control assby have "let go".
There are a few places that stock Marantz parts online.
Typically ,this isnt a consumer serviceable issue.
I can possibly suggest a repair place depending on where you are.
Hope that helps.
Posted on Jan 03, 2009
  • Scott Frye
    Scott Frye Jan 08, 2009
    Hi...
    I got this from one of the guys on a stereo blog:
    One possibility is Rocky Mountain Vintage Audio, run by Wayne Powell.
    He's in the SW area on Lowell near Belleview. He is very
    knowledgeable but not cheap. Generally you will pay 1/2 the unit's
    retail value for repair. But it will get done. Great guy.
    Also Intrinsic Sound on Broadway in Denver.
    Scott
Humming/Buzzing noise in my Marantz SR5600-even on lowest volume-
Check the main filter capacitor at its power supply section circuit. Electro help
Nov 19, 2014 | Marantz SR-5600 Receiver
Home Theater Receiver turn itself off at higher volumes
Could be that the speaker are being over-driven. The harder a speaker is pushed, the lower the resistance becomes, and the receiver could be sensing it as being a short and shutting itself down to protect the amp.
Jul 10, 2013 | Audio Players & Recorders
Marantz sr5600 reciever click and goes to blinking standby
I have the same problem. Earlier it got sorted out itself and now it has started coming up again.
Feb 26, 2012 | Marantz SR-5600 Receiver
Hi Strange problem with Marantz pm7001 When ever I turn the volume upto around 1/3 and 1/2 of the way, the amp cuts out and reset it self down to minimum volume. It seems like the amp ins't enough power...
What's probably happening is that the amplifier is shutting down or cutting back the volume as protection from damage. You may have a partial short in the speaker wiring that is not a problem at lower levels, but at higher ones causes the amp to see too low a load. There may a problem with a speaker or crossover component that is breaking down at higher volumes. Or something in the amp's output stage is unable to handle the load.
Test the system with a known good speaker system and length of wire and see if the trouble continues. If it does, you'll know it's the amplifier that needs to be checked. If the test speakers can reach normal volume, you can start checking the wiring and other speakers for the source of the trouble.
Mar 13, 2011 | Marantz Audio Players & Recorders
Marantz 2220B with Sound Problem at Half volume
The most likely cause of this is some DC current working its way through the system. WIthout taking some measurements, it will be difficult to confirm this though. This should not be an expensive repair. Figure on $20 or so for parts (capacitors mostly).
Dan
Apr 12, 2009 | Marantz Audio Players & Recorders
Wavy Video output from Marantz sr5600 Receiver
are you using component inputs s video rbg or hdmi?
Jan 31, 2009 | Marantz VP15S1 Television
172 people viewed this question
 Grubhead
Grubhead
