Question about Konica Minolta Bizhub C224 Color Copier Printer Scanner
Won't print 11x17
Printing 11x17
take the paper 11x17 paper out of the draw. or select different draw in the printer properties
Jan 30, 2014 | Konica Minolta Office Equipment & Supplies
I can't print a full bleed on my 11x17.
The white bordwers is in copier machine settings.For full page printin use 11x17 + paper or cut mechanical the whitw parts.
Feb 21, 2013 | Konica Minolta bizhub Office Equipment &...
How do I print two 8 1/2x11 sheets of paper on a 11x17 sheet on the riso 220? It keeps cutting my originals off.
RZ 220s have a smaller print area on the drum. I think around 9x14. Although the 220s can take 11x17 paper they cannot print over the entire area. (This is why I personally went with a RZ390. It has the 11x17 print area) Sorry, you're out of luck pal.
Oct 25, 2012 | Riso RZ220 Duplicator
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
Can't print multiple PDF files in 11x17 format. I open windows explorer and select the specific PDF files. Click on File, Print. They all print out, but they all are 8 1/2 x 11 on a 11x17 paper, instead of...
Adobe Reader can be real pain it the... neck sometimes.
But first I would inspect not only the printer setup, but also printer's default print settings. Windows XP has 3 places, where you can see the printer options:
1. Printer properties
2. Print preferences
3. Default print setup.
The third one is the one you have to set. When you double click on your printer icon, a print queue window opens. Choose Printer->Properties, go to Advanced tab, and on the bottom there's a button "Default print setup" (I don't have English XP handy, so I'm translating back to English from my version - excuse me if they might appear a little different).
It's there you need to set up the default page size and so on.
If this still doesn't help, try opening Acrobat Reader, setting the Page Size Scaling to None, printing something and closing Acrobat Reader. From what I've seen, it tends to remember this setting from previous sessions.
You may also try alternative PDF readers, like Foxit Reader or PDF Xchange Reader.
Good luck :)
Oct 28, 2009 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
Xp driverd for HP 2600 color
On the HP website for driver downloads we used the last set of drivers listed (script) that solved the problem of no color and 11x17 sheet.
Oct 22, 2009 | HP LaserJet 1000 Printer
I'm trying to print 11x17 from Illustrator and every time it would only print half of the 11x17. WHY? any help please?
May be you forgot the Page Setup. If it is: open, copy all (ctrl+A then ctrl+C), File|New, set page to 11x17, paste and re-position.
May be Print Setup is incorrectly configured. Check it by activate the Show Page Tilling option on the menu.
Jun 30, 2009 | Konica Minolta magicolor 7450 Laser...
Booklet printing on 11x17
In Print Settings make sure the original size is 8 1/2 by 11 and print out size is 11 x 17
Nov 01, 2008 | Ricoh Aficio CL7200 Laser Printer
I have a HP Deskjet 9800. It' doesn't want to print 11x17 size paper. It will feed an 11x17 sheet but nothing printed on it, after that the paper feed light blinks, and eventually the printing task bar...
I can't tell you for sure which thing I tried and worked, but I noticed the USB cable looked slightly damaged, so I switched it out. But the thing that I actually think did it was that I was using the A3 size paper because there was no 11x17 paper size with the exception of a banner 11x17, which I didn't try becuase I wasn't creating a banner.
But none the less, that did it.
Sep 23, 2008 | Office Equipment & Supplies
Konica Minolta Bizhub C224 Color Copier Printer Scanner Logo
112 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
