Question about Carbotech 2006 CHEVROLET SILVERADO 1500 HD CT785-XP12 XP12 Brake Pads
Spark plug wires have a metal sleeve around them, does that need to get removed with plug wire
  • 41 Answers
Dear that metal sleeves are made of aluminium and its for protecting the wires from over heating. if you are removing the spark plugs, you have to pull the wire along the metal sleeves.
Posted on Oct 28, 2012
How to change spark plugs in a 2004 Chevrolet Monte Carlo SS, V-6
The three plugs in the back are a bit tricky but 2,4,6 are all back there 6 is right by the O2 sensor you might have to feel around for them but you don't need a jack or any special tools just a ratchet, small extension 5/8 SP socket slide the metal sleeve forward and yank ******* the rubber plug wires after a while they will come loose 4 it about 3 inches to the left of 6 and 2 is back behind the coolant Reservoir
Feb 18, 2012 | 2004 Chevrolet Monte Carlo
Its not starting believe the wiring is wrong but need to see a diagram to make sure
You have to first check for spark by removing the sparkplug and reatach the plug wire and ground the plug to the metal on the engine. Pull the cord and see if it sparks between the sparkplug gap, the porslin and the metal. If it does not spark switch the 2 wires around to see if it makes a difference.
Mar 11, 2011 | Garden
Is it hard to remove the metal sleeve on a spark plug for a 2002 chevy tahoe
no it comes off with the wire and then the wire just slides out of it
Jan 20, 2011 | 2002 Chevrolet Tahoe
1998 Honda Civic DX. Melted Boots in Spark Plug Sleeve
I would use a pair of long nose pliers to grab a hold of them and pull them off, there are metal connectors inside the boots which snap onto the top of the spark plug.
May 23, 2010 | 1998 Honda Civic
Plug boot has a metal sleeve any trick to getting boot off it is very hard to pull off
i would invest in spark plug puller the pliers is about 10 or 15 dollars save money in the future.pry them wires right off with them
May 24, 2009 | 2002 Chevrolet Silverado 1500
Changing spark plugs
it is possible to remove sleeves but if they are stuck on plug you WILL bend them up pretty good.as long as you can get em back on snug enough to protect plug wire boot,who cares if they're a lil beat up.good luck
May 16, 2009 | 2002 Chevrolet Tahoe
02' silverado,removing spark plugs
THE metal cover is just a sleeve on wire. it will come off with it. try turning wire back and forth to loosen it up from plug. helps a lot to have a set of wire puller pliers
Feb 03, 2009 | 2002 Chevrolet Silverado 1500HD
Changing spark plug wires in 1998 camry
You aer not clear about your problem, when replacing plugs and wires all the boots need to stay in place, the larger boot goes around the spark plug, making sure the metal is secure around the tip of the plug, the oppisite end fits the distributer cap, making sure the metal at the end of the wire is securely in the hole. You said you have 3 boots, you should boots for each end of each plug wire and a plug wire for each spark plug
Jan 18, 2009 | 1998 Toyota Camry
Spark Plugs
You must mean the wire.There is a metal heat shield around the wire at the motor and it is connected to the wire.Just put a pair of needle nose pliers on the metal sleeve and twist it and pull it off
Aug 30, 2008 | 2001 Chevrolet Silverado
Carbotech 2006 CHEVROLET SILVERADO 1500 HD CT785-XP12 XP12 Brake Pads Logo
95 people viewed this question
Top Carbotech Computers & Internet Experts
David Payne
David Payne
Are you a Carbotech Computer and Internet Expert? Answer questions, earn points and help others
