Philips Projection HDTV 51pp9303h/17
Ok... Were in the TV panel can I find this IC"s, cause I only se one and it does not look like the ones you suggested...
  • 5,138 Answers
STKs in your set should be on same board that has tuners on it board you connect cable too.If different model they will be on board to very right end STK ICs are big black chips Two of them together.will have part number on them.
Posted on Jan 04, 2009
When the power is on start&in a few sec\17\ gose to standby mode what part is defective
Most likely the power supply is bad. It tries to start but does not get up to voltage and then it realizes this and shuts itself down. Either that or the heat sensor is detecting an overheat condition caused either by a faulty fan if your set has one or by excessive dust build up or a bad IC chip
Sep 23, 2011 | Televison & Video
I have a 21inches goldstar colored tv.. it has no sound.. i already check the connections buy its all ok.. also the transistors and the IC is ok.. what is the possible cause?
solution
Step 1 : At first check your TV speaker and volume switch and more check conecting were to speaker or audio section.
Send report :babul_jpi90@yahoo.com
Jul 27, 2011 | Televison & Video
I have an RCA kitchen television. It just stopped responding. I get to cable using comcast and they suggested that I call you since they are getting a proper signal. The TV must be on channel 3 in order...
Hi
It seems that your TV's memory IC has damged. If this IC got damged, no fromt panel or remote signals will work. It is a small IC . It can be found very near to channel selector main IC [System control]. It is very cheap to buy. But replacing it is a skilled work. You have to contact any experienced service technician to get it replaced. This IC controls most of the functions in the Tv. OK.
Jul 22, 2011 | RCA Televison & Video
I'm having trouble with my Toshiba 42HL196 TV. It won't power on. There is a flashing red light on front. I've read the manual and done everything it suggests with no success. I've checked inside the tv...
SYMPTOM: Won't turn on or intermittently won't turn on, Red LED Flashes.
CAUSE: Loss of Main Switched Power Sources. Standby power is OK.
SOLUTION: Replace Regulator IC Q820 with Toshiba Part # 23135094
Jan 18, 2011 | Toshiba 42HL196 42 in. LCD HDTV
I check do not power DC24v input inverter how to fit it?
first you have to check 24v dc on power supply board.if power board 24v ok then there is one ic link on inverter board.check is this ic link ok or not if its open then replaaced it.check one end of ic link 24v dc come?
Oct 16, 2010 | Emerson LC320EM8 32 in. LCD TV
0nida tv why to any tuch rimort boton so of mument
English language without abbreviations would help you get an answer.
May 28, 2017 | Bushnell ONIX 200 GPS Receiver
El relay se enciende y se apaga al enchufarlo
i do know ur language
s fixed !!!!!!! the problem was a bad relay. Upon inspection of the relay
(read that I took out the relay and broke it open) one of the coil wires
suffered from a cold solder joint from the factory!!! I replaced the relay
and its been running for about three hours without an issue!! Thanks to
everyone who gave me suggestions, except the a$$hole who suggested a sledge
hammer.....
When the picture resembles an hour glass in shape, it's generally a problem in the pincushion correction circuit.
The jittering in the picture at high volume levels indicates a problem in the regulator circuit which can also cause the problem with the bowing so I'd say you're got a problem with the regulator IC which is most likely and STK type IC and should cost around $125.00 to repair.
Jul 07, 2009 | Quasar SP-3235 32" TV
Sony KV-35S42 35" keep blowing MX0841 and .1 fuse resistor
Normalmente cuando falla la fuente se dañan los transistores convertidores, la resistencia 607 de 0.1 ohmios los condensadores C609, C610 de 0.47 mf. C611, C612 de 0.22 mf.
En nuestro caso basto con cambiar el MX0841 y R607, ya que el daño se debió a una sobrecorriente provocada por la salida horizontal, esta fuente e mas robusta que la de otros modelos ya que accidentalmente se provoco un corto en la salida del B+134 y simplemente solo se daño el MX0841 y la resistencia R607, se cambiaron y la fuente volvió a funcionar perfecto
Oct 28, 2008 | Sony KV-35S42 35" TV
Clicks but crt does not turn on
The Tv clicks and CRT comes on for a second before it goes into the protection shutdown. The LED flashes 6 times and sometimes 7 times. I checked the voltage accross IC501 as suggested in other posts and one of the votages is higher thatn it should be. thesymptom for the 6 LEd flashes suggest overscurrent and bad IC 504. I don't know how to meassure the voltage on the IC504 however as it has 4 prongs instead of three. My question is if there is something that may be causing this. Please help! I can offer you the Service manual for the KV series TV in return... you seem to be a techanical person so answer is purely technical. Clicks but crt does not turn on 1 check whether power supply out put is ok.by disconnecting h/output 2 if it is ok check hor. section that is eht is ok or not as without eht crt will not glow. check crt supply &loose connection in crt base. regards thanks
Sep 11, 2007 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sanyo TV 29 Inchs
Sounds like you lost your video. Causes could be a vodeo switching IC, a PIP module if the set has PIP Or a fault in the video jungle IC. To fix this problem I would highly recomend you take the set to a trained service person, as there are safety issues to deal with , as these sets hold alot of hi voltage even after the sets unplugged. Better safe then sorry. Good Luck
Jun 19, 2006 | Sony 27IN TV Stand Designed for Model...
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
