Question about Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc Honda GCV160 Gas Powered 3-In-1 FWD Self Propelled Lawn Mower With High Rear Wheels
Location of primer bulb on troy built lawn mower
2 Suggested Answers
  • 24 Answers
SOURCE: How to change the oil
I believe on that model it has to be pumped out. From the Fill hole.
Posted on Aug 20, 2010
How to replace troy built tb25cs primer bulb?
The primer bulb has two clips that fit into a slot. You will have to squeeze both clips to pull it out. Make sure you remember which fuel hose went on each nozzle of the primer. There are two nozzles. Make sure you put the fuel line back on the same way. The part # for the bulb if you need it is a Walbro 188-512-1.
May 27, 2014 | Troy Bilt Tb70ss Gas Trimmer
Primer bulb removal on a 1994 vantage 35 mower how do you remove the bulb
most lawn mower primer blubs have a metal ring holding the base in. Just uses use a small screw drive or hook and drag in out.
Feb 04, 2014 | Troy Bilt 5.5hp Self Propelled Mower
New primer bulb but engine won't prime
remove and clean the carby. clean out the main jet. ensure that there is nothing stopping the primer circuit from working. There are two valves under the primer bulb and a spring. when you push in the bulb fuel is squirted into the manifold When you take your finger off the bulb the spring pushes it out and new fuel is drawn past a valve to fill under the bulb. Pushing in again closes that valve and opens a second valve which allows the fuel into the manifold again
Apr 26, 2013 | Garden
Where is the primer bulb found on a troy bilt original lawn mower
should be a clear rubber or coloured rubber bulb located on or near the carb depress 2 to 4 times
Apr 11, 2013 | Troy Bilt 5.5hp Self Propelled Mower
How do I replace the primer on a troybilt storm 5024 snow thrower?
Heres a link to a video showing replacement of the most common primer bulbs on tecumseh small engines, keep in mind that there are a few different size of primer bulbs that look almost the same, so you would have to go by your engine model and go from there.
Feb 14, 2011 | Troy Bilt 5.5hp Self Propelled Mower
We have a troy bilt snow blower 1 yr old and we are trying to start it. When we try to prime it, the primer bulb does not seem to be moving any fuel. It just sounds like air. It will not start. We have...
Are there two tubes connected to the back of the primer bulb?
If it is connected, then the primer bulb itself could be cracked, allowing air to enter, but not fuel.
See if you can gently pry or possibly unscrew the bulb for replacement. They are readily available.
Gary
Dec 10, 2010 | Troy Bilt 5.5hp Self Propelled Mower
ENGINE KEEP'S DIEING, PUSH PRIMER BULB AND STARS, BUT THEN DIES, IF I CONTINUE TO PUSH PRIMER BULB IT KEEPS RUNNING, BUT STOPS AS SOON AS STOP.TROY-BILT SELF PROPELLED MOWER MODEL E189- BRIGGS&...
Carburator issue. If you have some mechanical abilty you can pull the carb off else take it to a shop. You probably left gas in it off season. Either the main jet is clogged or the float valve is stuck. Either way, remove the carb, tae off the bottom cover and clean everything out with gum out or a carb cleaner. reassemble and eveything should be fine.
Jun 14, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How do you prime a troy bilt 675 pressure washer
if you dont see a primer bulb then you must start it in choke mode after running out of fuel
May 31, 2010 | Garden
I can start it, but it shuts down after a 10 seconds
The model number for your post is for the blower attachment. Can you pass the model number of the upper assembly please so we can better help you. Thanks
Kelly (cont below)
I am going to go out on a limb here.. Most of these troy-built trimmers use this carb with primer bulb.
PN 753-1225
http://www.ereplacementparts.com/carburetor-with-primer-p-283336.html
What usually happens to them is the primer bulb on the bottom of the carb gets a pin-hole in it and then air is drawn into the carb vs fuel from the tank.
You can try to get just a primer bulb at your local lawn mower parts supply. You may just have to bite the bullet and replace the whole carb.
Apr 19, 2010 | Troy -Bilt String Trimmer/Blower...
Troy bilt mower. starts but shuts off within seconds.
sounds like you have a primer bulb if you take the bolt that holds the float bowl off and take a tip cleaner that they use for welding tips and clean the holes out of the side and the top it should let the fuel in again that will save you a trip to a service repair shop
Nov 22, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc Honda GCV160 Gas Powered 3-In-1 FWD Self Propelled Lawn Mower With High Rear Wheels Logo
61 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
