Question about Miller Spectrum 375 Plasma Cutter with XT30C Torch - 907532
Miller spectrum 375 manual - Miller Spectrum 375 Plasma Cutter with XT30C Torch - 907532
kevin_max
  • 37 Answers
SOURCE: any one pls can send miller spectrum service
Try this site
www.Millerwelds.com
Posted on May 15, 2009
outdoorsman5
  • 631 Answers
SOURCE: I am looking to purchacs a slightly used miller
The main thing that can hurt these things is water. If he didn't have a water filter on the line before it enters the plasma it could destroy the unit. If you buy it try it out to see if everything works. When you install it be sure to buy a filter that they sell for these and put it on before the air enters the plasma. Around $400. to $600 to replace the parts when water meets with the components. The filter that Norco Welding supplies sells for these is a toilet paper filter and you need to check it often.
Posted on Jul 29, 2009
  • 18 Answers
SOURCE: I bought a used miller spectrum 625, can put on
The consumables on the torch head could be incorrect or not installed correctly. check these.
Posted on Oct 07, 2009
  • 4 Answers
SOURCE: pc board for spectrum 375 s/n lh010317p
contact arndt enterprise 847-234-5736
Posted on Mar 07, 2010
Spectrum thunder plasma cutter will not cut steady, keeps stopping and have to pull trigger to cut
Check the contactor contacts for pitting. if severly pitted, replace contactor. If a death grip on the switch makes it work better then a light touch- replace the trigger switch.
Aug 17, 2012 | Miller Spectrum 375 Cutmate Plasma Cutter...
My miller spectrum 701 was set up for 1ph 230 and got plugged into 460 and fire shot out of it several times.what would it take to fix it?
I'm not recommending that you do this, but if you were to open the covers you'd be able to identify visually the blown boards and on the boards are the codes for re-ordering. This is not a guarantee that other boards won't be fault, but they should be ok.
Jun 13, 2011 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
All lights correct, no start
loosen the retainer cap and twist the consumables and retighten
Apr 24, 2010 | Miller Spectrum 375 Cutmate Plasma Cutter...
Plasma cutter no cutting
the tech is probably pretty close to the cost of board,but you may have moisture in air that still wont take out the p.c..you have a warrenty on the unit,go to your local welding store and request a new one if refussed tell them you want to talk to the miller salesman which they should have no problem to set up.if not call miller direct in appleton wisc.they are good people.
Apr 07, 2010 | Miller Spectrum 375 X Treme Plasma Cutter...
Pilot wont lite. miller spectrum 701
check the cables in the plasma torch.
If the problem continues, theres no enough power to start it.
Jan 04, 2010 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
Miller Spectrum 375 problem
It sounds like you have a problem in the power supply input area. Make sure your voltage select switch is in the correct location. Unplug the unit and switch back and forth between the two positions to clean the contacts. Try again. If still bad check you terminal lug connections on the input lead wires. If still bad please answer these questions.
Does the power indicator come on at all? Does the fan start?
Nov 12, 2009 | Miller Spectrum 375 Cutmate Plasma Cutter...
I am looking to purchacs a slightly used miller plazma spectrum 375 from a private owner is there any common problems related to this unit that I should look for?
Jul 29, 2009 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
Miller Spectrum 375 Plasma Cutter with XT30C Torch - 907532 Logo
22 people viewed this question
Top Miller Electrical Supplies Experts
Craig Butler
Craig Butler
janman
Lawrence Oravetz
Are you a Miller Electrical Supply Expert? Answer questions, earn points and help others
