Question about Dymo LabelWriter 450 Turbo USB Label 1752265 Thermal Printer
I have a Dymo 450 labelwriter. The platen release lever came off and I can seem to figure how to reattach it.
Here is how I fixed my 450.
You have to open the case, which invalidates the warranty.
First, remove the case front - http://global.dymo.com/img/compel/cRydqiFncuah2s6Pf5DxrozTFsn13Cnc.pdf
Undo 2 long screws (front) and 2 short screws(rear) underneath the case.
Remove side panels and base carefully as there are ribbon connectors to the base which might get damaged.
You will see two metal pins at the left front, partially hidden by a ribbon cable - do not damage the ribbon!
There is a notch on the metal part of the platen lever which goes against the front pin.
The hole in the metal part then gets pressed down until it catches on a groove in the second pin.
Do it in that order or it is likely to just pop off again.
You then spend several hours getting all the bits of the case to fit back together. Put the front on last.
Mine is now working but I accept no responsibility for what happens to yours!
Posted on Apr 20, 2013
SOURCE: DYMO LabelWriter 400 Turbo Installed but gives error message when sending prints
Unplug the printer and wait 30 seconds then plug it back in. Mine printed everything that was in the queque.
Posted on Oct 16, 2008
SOURCE: Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
Step 2: Remove .NET Framework
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Posted on Apr 28, 2008
nandosnut
  • 112 Answers
SOURCE: Dymo labelwriter 310 - vista driver
http://www.labelvalue.com/dymo-software.php
Posted on Apr 25, 2009
  • 4 Answers
SOURCE: dymo 400 labelwriter does not print unless shut down and rebooted
It could be how you have loaded the labels. If you have loaded the labels and there is a small gap between the spindle and the roll, it will print one label and give a error-printer message and stop working until you unplug it for 30 seconds and plug it back in. I would reload the labels from scratch and ensure there is no gap.
Posted on Aug 06, 2009
  • 14 Answers
SOURCE: Dymo labelwriter 400 Turbo -We replaced the roll
There are a few common reasons this is problem can exist.
1.) the incorrect template is used when creating the label
2.) the labels are installed incorrectly - the labels must be loaded and pushed against the left side of the printer and lid closed when printing to ensure the labels don't "wander" out of the sensor's view.
3.) the label sensor is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view. Use quality Dymo labels.
4.) The labels are defective - if you have another roll of the same size, try it to see if it has the samme issue.
Posted on May 06, 2010
The platen release lever has come of. Can this be fixed
Of course it can be fixed. But is it worth the price of repair given labor costs/parts these days?
Sep 16, 2015 | Dymo LabelWriter 400 Thermal Printer
How to disable DYMO label roll sensor in DYMO 450 turbo
The sensor cannot be disabled. DYMO printers (including the 450 series) are hard-wired to only work properly with genuine DYMO labels.
^CM
Mar 14, 2014 | Dymo LabelWriter 450 Turbo USB Label...
We have recently printed and applied hundreds of asset sticker labels on our Dymo LabelWriter 450 and they have all faded! Is there a solution to this? or is the Dymo LabelWriter only useful for temporary...
LabelWriter labels are sensitive to sunlight. The coating is what allows to burn text onto them because LabelWriters do not use ink.
They are not supposed to fade easily so it may have been an old roll. Please contact our help desk for a resolution (see dymo.com for contacts).
^CM
Feb 10, 2011 | Dymo ® LabelWriter® 450 Series PC...
With Dymo Labelwriter 450, Can labels be printed in WORD without going through Dymo V8 software? I can print in Word but labels come out in portrait format and not landscape
They can. You may want to use the Word add-in for this. Please contact our help desk for further information (see dymo.com for contacts).
^CM
Jan 21, 2011 | Dymo ® LabelWriter® 450 Series PC...
Labelwriter 400 Thermal Printer: How do I re-assemble the platen release lever in m...
May 16, 2010 | Dymo LabelWriter 400 Thermal Printer
Printing error print system exception error
I had this problem with the LabelWriter 450 Turbo and it was a .Net Framework problem.
1. Uninstall the Dymo Label software
2. Click this link to download .Net Framework 4.0 http://www.microsoft.com/downloads/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
3. Reinstall latest version of your Dymo Label software (w/o printer connected to PC)
4. Reconnect label printer when prompted by installer
This should fix the problem
Dec 24, 2009 | Dymo LabelWriter Thermal Printer
Spits out multiple blank labels and reports a printing error
I just fixed my coworker's Dymo, which had the same problem. I hope this helps: if you've ever fed it labels in the wrong direction (upside down), you may have jammed it and left a piece of a label glued to one or more of the sensors that let the labelmaker know it's finished printing a label.
1. Disconnect your labelmaker
2. Disconnect/remove any unused labels and set them aside.
3. Remove the face plate (with the DYMO LabelWriter 400 logo)
4. Lift the gray plastic lip (labels go under this) and make sure there are no pieces of paper/labels in there.
Once I removed a piece of an old label and put the LabelWriter back together it started working well again.
Sep 23, 2008 | Dymo LabelWriter 400 Thermal Printer
Dymo LabelWriter 450 Turbo USB Label 1752265 Thermal Printer Logo
1,901 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
