Question about Sony RDR-HXD860 DVD Recorder/HDD Recorder
HARDDRIVE ERROR ON SONY RDRHXD860 DVD RECORDER
Hi, I formatted a 500 gb sata harddrive and put it in the machine but it came up with "harddrive error " I thought maybe it does not like being formatted on a nfts based operating system. so using seagates software i filled the harddrive with zero's and it still comes up with harddrive error. can anyone help. thanks john
  • 1 more comment
  • JOHN PEABODY Oct 26, 2012
    Hi, has you suggested I downloaded the instructions on the pdf file. No it did not work. I also tried holding the power button in for 10 sec. also tried holding the blue dvd button in. i got load "L1 " Then power off. last attempt i got hdd error.
  • willmon22 Oct 27, 2012
    Do you have the remote or have downloaded the file to program a remote for it to work on the dvd recorder? If not I believe this will not work as it has different keys that the unit does not have on it.
  • JOHN PEABODY Oct 29, 2012
    the remote in the P.D.F file is different to mine. I delayed replying because I e-mailed Sony. today I got a reply: not interested, no support out side the guarrentee or upgrades. I did try connecting the harddrive to the computer and copying but it comes up as unallocated space
  • 35 Answers
Http://www.avforums.com/forums/attachments/blu-ray-dvd-recorders-media/68631d1198812029-succesful-upgrade-hdd-rdr-hxd970-how-upgrade-hdd-sony-x70-series-dvd-recorders.pdf You shouldn't use a computer to format the drive as the dvd recorder will do that for you.
Posted on Oct 25, 2012
Hdd not recongnized and unable t open.accesible failed?? like tht it is ans
Hi ,
It sounds like you need to format the harddrive , then you will be able to use it .......
if you need more help , let me know .................Roy
Aug 08, 2011 | Trekstor DataStation maxi m.u SATA 3.5"...
HI I have a desktop with : *MSI Motherboard with Nvidia chipset on it *Intel Core 2 duo *2 GB SDDR2 RAM *500 SEAGATE HDD I created four partitions on the HDD , i had bad sectors on the fourth partition...
Have you considered checking your DVD writer? Also, you might already have a faulty hard disk drive.
You can try any of the following:
1. Double check to see if your Windows 7 installation disk is dirty (clean it using a lint free cloth) or has many scratches. (Your DVD reader/writer would really have a hard time reading scratched disks.)
2. Borrow another DVD-ROM from a friend and use it to install Windows 7 on your computer's C drive.
3. Check to see if ALL cables are properly connected. i.e. SATA, power cables, etc.
4. You could also try to make your 500 GB HDD as a slave drive so that you can backup your files to another media if it works. (Backup to another external hard disk drive, burn it to DVD's, etc.)
5. LISTEN carefully if your hard drive makes unusual noises like unusual clicking, bumping, and/or scratching sound inside your hard disk drive. If it does and as a last resort, replace your hard disk drive.
Nov 23, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hey My WD5000AAKS WD Caviar SE16 does not work, i connect it to the computer and it starts propely, but the computer does not React, and cannot find the harddrive on "My computer" (hardisk do...
did you put cable on o sata or sata 1 on board needs to be on o sata to start right. look on drive to make sure that it is at factory settings. then plug in power cable and board cable on drive jim
Nov 18, 2010 | Western Digital Caviar SE16 (WD5000AAKS)...
Sony RDR-VX530 DVD Recorder / VCR Combo - cannot format DVD+R
is it possible to record dvd+r?
is this machine not only dvd-R
Apr 07, 2010 | Sony RDR-VX530 DVD Recorder/VCR
My samsung 500gb external hdd is niether copying nor being format
you can do one thing remove the hard drive from the casing and put on some other casing then check, if the problem is the same then its the problem of hard disk
Oct 09, 2009 | Samsung 500GB, 7200RPM, Internal, 16MB,...
How do I move the data from broken DVD Recorder HD, to my PC?
you can take the side of your computer, and plug this into your computer, you might need the sata cable but will work a treat :)
many thanks
Feb 15, 2009 | Seagate DB35 ST3500841ACE 500 GB IDE Hard...
Hard drive upgrade
It has to have SATA Hard Drive Connector DFHS22FR685, if you have this then I would try to format the hard drive to what your operating system is using, either NFTS or FAT32. The drive may not be properly formated for your system.
Jan 22, 2009 | HP Pavilion dv9000z Notebook
I have an HP Pavilion dv9000 purchased in 2007, 17" widescreen. Currently it has a 140GB harddrive that is almost full. I purchased a 500 GB harddrive to replace it but my computer won't acknowledge the...
SATA HDD not working
Avinash thaks for providing the exact error..
Re: A Disk Read Error Occured. Press CTRL ALT DEL to restart
1 - Have you tried a different IDE cable?
If not give it a go and do a repair if needed again!
2 - You may have a corrupt MBR (master boot record)!! You will need to reformat and do Fdisk /mbr to delete the master boot record!! Save all data first as this will not allow you to access any of your data as all file location addresses are located in the MBR!!
3 - Your harddrive may have a bad sector get a zerofill tool(low level formatting tool)!! This will rewrite you HD's sectors putting them back to factory spec's!! Maxtors is called Maxblast you can get it from thier site!!
4 - or it could be a defective drive, but most read errors are due ot corrupt MBR or a bad sector!! Good Luck D.i.l.i.p
Jul 02, 2008 | Hitachi (AU-160GBSATAHDHIT) 160 GB SATA...
Sony RDR-HXD860 DVD Recorder/HDD Recorder Logo
709 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
