Question about Singer 20U73
Hand wheel rotates but stop motion screw doesn't rotate and it is not moving the needle up or down
  • Singer Master
  • 1,564 Answers
Robin. Take off the hand wheel. Look for the funny looking washer with ears. The center fingers should be angled outward when you fit it into place (counter intuitive, I know) Fit everything back together and try it again.
Posted on Nov 06, 2012
  • 46 Answers
SOURCE: the bobbin is getting caught and needle is jamming
This sounds like there is cotton stuck in the bobbin holder. Check it thoroughly. Take the bobbin out and turn the wheel to lower the needle a few times. This will show up any thread caught. Pull it out gently. You may have to perservere to get it all out.
Posted on Oct 24, 2008
  • 323 Answers
SOURCE: My Singer Quantum CXL seems to be jammed
Go to this site
http://www.singerco.com/support/us_warranty.html
search for a Service Center in your state, call them for how to send in the machine and how much it will cost for repair.
sewman7
Posted on May 05, 2009
  • 980 Answers
SOURCE: Singer 401a does not stopped working after moving.
You may well have a small piece of thread stuck in the raceway, take the raceway out and check, failing that take the top off the machine and look at the fibre gear on top of the motor to see if it has broken away, you may have the model with the metal gear which should be okay.
Posted on Oct 28, 2009
  • 2976 Answers
SOURCE: Singer 401a - hand wheel will not move needle
Make sure the lock is tight. If it is even slightly loose, the wheel will spin without moving the needle.
Posted on Jun 09, 2010
  • 1788 Answers
SOURCE: Needle moves up and & down and sews for a few
If you look at the website, www.sewvacdoctor.com and you can see, they say it may be your foot pedal or transducer(speed control inside the machine) I would call Singer and see if it is still under warranty, hopefully it is. If it is the foot controller, that is not too expensive, I don't know about the transducer. But, call Singer at -800-4singer and tell them what is happening. Good luck
Posted on Oct 11, 2010
Jammed and needle bar will not move.no thread wrapped anywhere,hand wheel won't raise the bar either
1. Remove the needle and bobbin assemble completely.
2 Try to move the hand wheel - forcefully if necessary.
3. Place one drop of oil on race. That is the little dip that has been circled. The hook (pointed thing) must ride on this smoothly.
4. Try to move the hand wheel again. Back and forth until it will move without resistance.
5. Oil parts that move with metal against metal.
6. Replace the bobbin assembly. Try to rotate the hand wheel again. If it is ok you can replace the needle.
7. Try to rotate again. If it rotates smoothly you shouldn't have any further problems. If the needle strikes something under the throat plate you will need to get the sewing machine timed.
Jun 28, 2015 | Juki DDL-8700
The bobbin thread will not raise with the needle
1. REPLACE NEEDLE W/FLAT PART AWAY FROM YOU.
2. MAKE SURE THE TOP THREAD IS PROPERLY THREADED.
3. INSURE BOTTOM BOBBIN IS ROTATING RIGHT DIRECTION. (USUALLY COUNTERCLOCKWISE) ALLOW THREE INCHES OF THREAD PULLED AWAY.
4. HOLD TOP THREAD W/LEFT HAND AND ROTATE HAND WHEEL TOWARDS YOURSELF. DOES IT BRING THE BOBBIN THREAD UP?
5. IF THE BOBBIN CARRIER IS INSTALLED PROPERLY THE HOOK (POINTED OBJECT) UNDER THE BOBBIN SHOULD "HOOK" THE TOP THREAD AND BRING THE THREAD AROUND THE BOBBIN THREAD. THE NEEDLE AND TOP THREAD SHOULD BE PULLING THE BOBBIN THREAD UPWARDS. IF THE HOOK DIDN'T "HOOK" THE NEEDLE THREAD THE PROBLEM IS THE DISTANCE OF THE NEEDLE AND HOOK APART OR THE TIMING. YOU MAY TRY TO MOVE THE NEEDLE TO THE LEFT SIDE AND AGAIN TRY ROTATING THE HAND WHEEL. IF IT DOESN'T WORK THEN TRY TO MOVE THE NEEDLE ALL THE WAY TO THE RIGHT AND ROTATE THE HAND WHEEL. IF IT BRINGS THE BOBBIN THREAD UPWARDS IN EITHER CASE IT WILL SHOW A PROBLEM WITH TIMING. THIS WILL NEED TO BE ADJUSTED BY A PROFESSIONAL.
6. REMEMBER TO PUT ONE DROP OF OIL ON THE RACE TRACK BEFORE YOU PUT THE BOBBIN CARRIER IN.
Jan 13, 2015 | Singer HD-110 Mechanical Sewing Machine
I'm having trouble with the bobbin. The thread won't come up and just bunches up under the plate
1. Make sure your bobbin has enough tension. Check by hanging from your finger, It should extend one inch when you bob it.
2. Set top tension starting at 3.
3. Replace needle. Make sure that it is in right.
4 Check the way you thread the machine. It must be done right.
5. Rotate the hand wheel towards you and hang on to the top thread. As you rotate there should be some pull at some point. This is the bobbin doing this. If there is pull but the thread isn't coming up then your bobbin is hanging up.
6. Monitor the bobbin while you rotate the hand wheel. The thread should move across the bobbin but not get snagged. If there is a snag you will need to readjust that part just a little. This is normally a screw that needs to be loosened and retightened.
7. If the other suggestions don't work then move the needle to the right side of sewing. Also, try by doing it on the left. If it does bring the bobbin thread up then your machine needs to be timed.
8. For timing you can go to youtube for instructions. Or go to a repairman.
Nov 26, 2014 | Sewing Machines
Hi I have a pfaff industrial zig zag 428, the bobbin has stopped all rotation
bobbin case should be stationary, bobbin itself is rotated as thread unwound, check hook timing. Simply turn hand wheel towards you and watch needle go down, when it reaches lowest point turn it slowly until needle rises 3/16" or so. Hook should be behind needle and slightly above eye.
Feb 12, 2014 | PfaFF Sewing Machines
Needle clamp tragedu
The needle clamp usually has a screw on the back that is tightened to prevent the needle holder from falling off. The screw on the back should be very loose. Place the holder on the arm (moves when you rotate the wheel by hand) with the screw towards the back and the hand screw on the side. Tighten the screw in the back and it shouldn't come off. Now, place the wire on the side where the hand screw on the inside of the hole along with the arm and place your needle in. Now you can tighten.
Apr 27, 2013 | Sewing Machines
Slow Machine
it sounds like the machine needs to be checked at a sewing
machine repair shop, to see there is anything wrong with the
gears or other parts & also to be regreased & oiled
Aug 23, 2012 | Singer 2263 Mechanical Sewing Machine
Pfaff select 1540 bobbin thread jam
if there is a thread in the hook area try taking a pair of needle nose
pliers to try & get the thread out, if that doesn't work then you might
think about taking the machine to a sewing machine shop to have the
machine checked since the needle will not go up & down & handwheel
won't move
May 03, 2012 | PfaFF Sewing Machines
My needle keeps moving while I try to wind my bobbin
hi there,
the hand wheel and clutch should be disengage so that needle will not move also w/ the bobbins,doing this is hold the hand wheel then grip hold also at the center hand wheel.rotate center counter clockwise to release clutch.other type is push and pull hand wheel.any of them,try to run machine if needle is move again.cheers have a nice day don't forget to rate me.
Apr 07, 2009 | Singer 7436 - INGENUITY
Handwheel on Sewing machine no longer moves needle.
Actually you should have a "set screw" in the hand wheel. The set screw is usally locked down tight to keep the hand wheel from spinning freely. I f you can run the machine slowly and hold the hand wheel in one place but the machine continues running, then you do need to replace the "set screw". If you replace it you will find that you can offset some of the machines vibration by where you lock the wheel down. Trial and error is the only way to achive this adjustment, kind of like balancing the tires on your car.
Feb 13, 2009 | Sewing Machines
Can only move the hand wheel one way
This is tech crazy
The most important element of a stitch mechanism is the shuttle hook and bobbin assembly. The bobbin is just a spool of thread positioned underneath the fabric. It sits in the middle of a shuttle, which is rotated by the machine's motor in synch with the motion of the needle.
so either there is rotational problem in the motor or the needle position is altered .just check out for it
Kindly rate me on the above said solution
Feb 02, 2009 | Singer 8280 Mechanical Sewing Machine
Singer 20U73 Logo
229 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
