Question about Savin Office Equipment & Supplies
Savin 2518 sc320 code
Sc320 code
2 Suggested Answers
  • 23 Answers
SOURCE: how do you get rid of lines that are coming
U PROBABLY NEED A NE DRUM. OR HAVE DFIRT ON LENSES AND MIRRORS
Posted on Sep 13, 2010
I have a savin 2518 copier It's printing very light do you have any idears
first take the toner cart out and shake it, if that doesn't cure the problem, you may need to replace the toner cartridge with a new one
Mar 18, 2011 | Computers & Internet
My 2022 shows an error code SC320 and also a error code SC672 what could be the problem
CS320 polygon motor (laser), you will need to replace it, it is not expensive!
CS672 control communication on start up, to many options, from circuit board to bad connection, you will need a tech for this.
Nov 23, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
I have code SC320 of my copier NASHUA D425
SC320: Polygon motor error
-Definition- [B]
The polygon motor does not reach its operating speed within 10 seconds
after the polygon motor on signal, or the lock signal is not detected for
more than 40 ms continuously during operation.
- Possible causes -
· Polygon motor defective
· Poor connection of the interface harness which connects the polygon
motor driver and the IOCSS board
· IOCSS board defective
u need new polygon mirror
Nov 07, 2010 | Ricoh Aficio 250 Copier
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Oct 15, 2010 | Lanier 5222/27 Laser Printer
What is code sc320
SC320 is a Polygon Mirror Motor Error/Lock
Sep 14, 2010 | Ricoh Aficio 2022 Black and White Copier
How do you get rid of lines that are coming through on copies Savin 2518
Sep 13, 2010 | Savin Office Equipment & Supplies
Error code 320 on startup
SC320, THE ENGINE POLIGONAL OF THE UNITY LASER DOES not TURN PROPERLY BY DAMAGE, HAVE TO CHANGE IT BY ONE NEW.
Apr 06, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Can MAC OSX 10.5.x use Ricoh Aficio 1018D? Do you now alternativ drivers for ricoh aficio 1018D. HP LaserJet 5-Gutenprint v5.1.3 is o.k. for A4 but not for A3
this is an older model copier, however try going to www.savin.com and click downloads then drivers. there will be a tab for drivers, this is 10.5 though not snow leopard. Ricoh/Savin/gestetner and Lanier are all the same copier, but savin site has more mac info than Ricoh site. Usually I have better luck using already installed Mac drivers than Gutenprint, if you type in the ip it should give you a list of preinstalled Mac drivers. I believe the Ricoh 1018 corresponds to a Savin 2518 if that helps. Also use print daemon, not ipp. hope this helps somewhat as Macs are difficult with options and such on most printers. also must use PS3 for best results.
Jan 09, 2010 | Ricoh Aficio 1018D Copier
I have problem with Ricoh Aficio 1113, error code sc320
I am assuming you really meant an Aficio 1013 - SC320 indicates a polygonal mirror motor failure. This motor drives the mirror that distributes the laser to the drum. Could be a defective motor, poor connection between the motor and the BICU - one of the motherboards, damaged cable or defective BICU.
This will require a service call. Probably looking at an hour to diagnose the exact problem and an hour or two to repair plus parts. Could be as simple as a loose connector --- doubtful, but you never know.
Dec 24, 2009 | Ricoh Aficio 150 Copier
121 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Don  Farrell
Don Farrell
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
