Question about Ricoh Aficio SP C232DN Laser Printer
Replace fuser on ricoh SP C232dn
How do you get the fuser out of a ricoh SP C232dn? I have the two screws out but it feels like it is hanging up on the plug. How do you get to the plug to unplug it
2 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: I need the reset procedure
This is how you reset that error:
press the yellow "C" button
enter 107
press the red "C" button and keep it hold till the display changes
turn the power off with the big red switch on the unit
turn power on again
Thanks much - if somehow that doesnt work please reply.
Tim
Posted on Oct 25, 2010
Reset code printer ricoh sp c232dn
Service mode or maintenance mode:
turn off machine
Hold stop/start & escape and then turn on power
press OK
Mar 08, 2017 | Ricoh Aficio SP C232DN Laser Printer
Ricoh Aficio Sp 1000sf AllInOne Laser Printer - Error fuser temp problem
As with all Laser Printers, the fuser temp error can be frustrating. Sometimes, just turning the printer off, then back on corrects the problem. If you've tried this without success, it's time to order a new fuser. Most have been changed to Customer Replaceable Units (CRU)s. The two ways you can tell if that's the case is either the user manual will have it listed in troubleshooting or, open the side of the printer the fuser is on and see if there are finger screws or tabs to release the fuser. NOTE: IF THE FUSER IS HOT, DO NOT TOUCH! YOU WILL BE BURNED!. It takes about 30 minutes for a fuser to cool down to a safe temperature. If you can remove it yourself without tools. Great! Easy take out and replace. If not, a tech will need to come out to remove the fuser and replace it.
I can't believe no one has answered your question until now.
Jan 09, 2017 | Ricoh Aficio Sp 1000sf All-In-One Laser...
ERROR CODE SC542 ON A RICOH SPC 242
Print Ready Temperature Error
?? The heating roller temperature increase during a set time is not correct.
?? The fusing temperature does not reach the print ready temperature within a
set time after the fusing lamp has turned on.
?? Defective thermistor
?? Incorrect power supply input at the main power socket
?? Defective fusing lamp
1. Check the voltage of the wall outlet.
2. Replace the fusing unit
3. Replace the fusing lamp.
**Execute "Engine Maintenance Menu" to recover the machine after
completing the recovery procedure. Otherwise, the machine continues to
issue this SC code and cannot be operated.
Jan 08, 2014 | Ricoh Aficio SP C232DN Laser Printer
How to restart Ricoh SP C231n?
hi there, try to do the following:
- make a program mode (SP 107)
if you dont know SP mode, press clear/resume button then 1, 0, 7 then clear/stop button for atleast 5seconds.
*the monitor should appear 1.system 2.copy 3.
then press 1, then press 7,8,0,7 then #
*the monitor should appear COUNTER RESET then press 1 to start, let it finished then turn off and on your machine.,
*the SC-542 should disappear
note: if this will not fixed the problem, there maybe a problem with your FUSING UNIT, check it!
Nov 29, 2012 | Ricoh Aficio SP C232DN Laser Printer
My ricoh aficio mp 2000 have the error sc 542 what i can do to sorve this.
Reset the code via SP Mode (I will not tell you how to enter SP Mode, you must research that). Once you are in SP mode enter System or Copy SP and turn off the machine to reset.
The code is actually referring to a thermistor problem in your fuser, regardless, if your machine is under maintenance request service (obviously, I do not think it is under maintenance or you would not be asking). Other than that, once this thermistor completely flakes out your machine will be rendered useless.
P.S. ALWAYS GET MAINTENANCE ON YOUR COPIERS, quit being cheapskates.
Source: Ricoh's Tech Support Goose Guide. Ricoh Qualified Copier Technician.
May 02, 2011 | Computers & Internet
How to clear toner collection bottle sign for Ricoh_Aficio_SPC232DN
replace the waste toner bottle (toner collection bottle)
Or dump the waste toner from it and clean it thourghly.
Mar 10, 2011 | Ricoh Aficio SP C232DN Laser Printer
Ricoh Aficio SP 232 DN access code.
Call a Ricoh Technician to Reset the codes
May 30, 2010 | Ricoh Aficio SP C232DN Laser Printer
Getting error: set fusing unit correctly on Ricoh Aficio SP C410DN. Have just changed thermister in fusing unit.
Take the unit out and install it again, making sure it is in all the way and sitting correctly. Then reset the machine and see if the error goes away.
Nov 10, 2009 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio SP C232DN Laser Printer Logo
124 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
