Question about Whirlpool Dryers
CIRCUIT BREAKER TRIPS AFTER 5 MINUTES RUNNING.......WHEN I RUN WITH NO HEAT SETTING IT WILL RUN FOREVER......I PULLED THE HEATING ELEMENT AND IT "APPEARS" TO BE FINE.
  • 706 Answers
Hello dale210mile,
Based on your problem description, it is possible that your circuit breaker itself is on its way out.. ( they do go bad sometimes) but before going that route, I would make sure that ALL wiring connections are tight ( meaning shut off the circuit breaker and make sure every electrcial tie point is snug and that you don't have a 'high impedance junction' somewhere in the power feed to the dryer. When you say the heating element 'appears' fine.. not sure what that means exactly but depending on the model.. you should be able to measure its cold resistance with an ohm meter and it should fall within manufactures spec.. A visual check of the heating element really won't tell you much unless it has shorted and you see a burn mark on it.. The mere fact that it runs OK for 5 minutes and then trips the breaker leads me to beleive that it may not be ok..but it is important to rule out the other hardware ( wire terminations etc) before going that route. One test you can try.. if after you've checked all the wiring etc..try running the dryer with no laundry in it .. ( just to verify that the additional load that the motor adds to the entire current draw isn't taking it over the top...) Hope these suggestions help you zero in on the solution..
Good Luck
Rick
Posted on Jan 03, 2009
Why does the circuit breaker keep tripping?
Need more information is it dryer,stove,ac ,heat, water heater,bathroom plug, garage plug ,outside plug, other
Lighting circuit with plugs
Oct 19, 2016 | Dryers
Oscillating drum sander runs a few minutes and stops
This usually occurs if the motor is overheating and the internal circuit breaker is tripping. After it cools down, it self resets. This can be caused by bad bearings or parts dragging the motor down, making it work hard enough to over heat and trip the breaker. If you are running it on an extension cord or circuit that isn't able to provide it with the amps it needs the motor will overheat and trip the breaker also.
Dec 02, 2012 | Delta 17-960 Oscillating Spindle Sander...
Breaker trips after bout 5 minutes
Breakers trip because of heat.
When heat from wire exceeds breaker rating, it trips.
Something is causing heat on the wire, wire is too small for the amp draw, there is short circuit, or breaker is bad.
Replace breaker and/or test wire.
Put amp-meter on wire and read amp draw through wire.
Amps cause heat. That's why high voltage lines from power station are high-volt-low-amp so there is no heat loss with long distance transmission, until transformer at home converts electricity to lower volts and high working amps with enough power to run electrical devices.
Same is true for AC and DC circuits.
If amp reading on wire exceeds rating on breaker for length of time, then breaker will trip.
The fact that the breaker lets current (amps) to flow for a period of time before tripping is because the breaker is probably rated for slow-acting, or it takes a while for amp draw to heat the wire.
Following image shows amp-meter that clips over wire to get amp reading.
http://waterheatertimer.org/pdf/Which-is-best-gas-water-heater.pdf
Oct 31, 2012 | Electrical Supplies
The fan will not engage when unit is turned on and after 5 or so minutes the circuit breaker trips.
since the fan doesn't run - the compressor heats up and pulls excessive amps and trips the breaker.
99 out of 100 times your fan motor will be bad.
You need to replace the motor.
Jun 07, 2011 | Kenmore 74123 Air Conditioner
Electric dryer trips circuit breaker after about 5 min when running at high heat not sure of model number
Most likely culprits are the thermostat (or a short in the wiring related to the thermostat) . I am assuming it is a normal current breaker and not an earth leakage breaker. It seems likely to be the thermostat as that probably switches after a few minutes (whereas the element which is also a common failure is on from the start of the cycle, so if there was short in the element that would take the breaker out immediately).
Does it do the same whatever heat setting you select?
If you switch it back on before letting it cool to much does it trip sooner?
If the time it takes to trip changes when you change the heat setting that would point to the thermostat/wiring too.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 15, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
Unit comes on and runs for 5 minutes, the circuit trips off
30 is the correct size breaker for this unit. It sounds like there is a grounding issue going on in the system. Or off of the Thermostat. Something is grounding out causing the switch to trip. Are you running #10 wire to breaker and the unit? If not you will need to increase your wire size
Jan 03, 2010 | Dayton D-F79 Electric Space Heater- the...
Outside unit trips the circuit breaker
seems that if it runs for 5 minutes there shouldnt be any shorted wires I would say your breaker needs replaced
Aug 04, 2009 | Weather King 10AJA6001AH Air Conditioner
Dishwasher pops the circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jul 01, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Dryer will run about 5 mins. then trips the circuit breaker.
I would change the breaker frist and see if that sovles the problem
Oct 14, 2007 | Kenmore 62602 Electric Dryer
Dryers Logo
102 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
