Question about Dishwashers
Kenmore dishwasher model 665-13269k110 not draining well
I have been working on the issue for 2 days now. History: floor model installed by Sears a year ago. It never cleaned well or drained completely. Started getting worse dishes coming out dirtier than when they went in. I pulled it out cleaned it well, tested hoses, pulled rusty metal and shards of glass out of pump area. Re-assembled, opened up the punch out on disposal better, hung hoses higher under sink and then tested. It cleaned very, very well but left a ton of water in the bottom. It is draining but not well at all. Any suggestions before I buy a $150 pump?
  • kcokerphoto
    kcokerphoto Oct 26, 2012
    I took apart the entire getup, everything. I found some glass, metal shards and in the bowels of the beast (under the pump motor), some melted plastic (maybe a straw?). I wasn't so sure I would be able to re-assemble everything but it seems as though I did. The pump is pumping for a longer period of time but I think it is just a crappy pump because there is still an inch and a half of standing water in the tub when I try to drain it. Well, I'm off to bed. I will try to look at this again tomorrow with fresh eyes. Thank you for the suggestions!
  • kcokerphoto
    It's the drain hose. it has a check valve on the inside rubber elbow where it attaches to the washer. This was the problem all along. I replaced it with a hose that doesn't have a valve. Now the dishwasher works great.
  • 1073 Answers
SOURCE: kenmore dishwasher makes grinding noise while draining
disassemble the top of the dishwasher pump, remove the bottom spray arm and remove the screws on the top of the pump housing this will get you started
Posted on May 03, 2008
SOURCE: My Kenmore Elite UtraWash Dishwasher
I have the same problem. The part you're talking about can be released from under the dishwasher to clean it. www.searspartsdirect.com has useful diagrams. I cleaned everything but still have the problem which is caused either by the "check balls", the "check valve" or the "pressure check" thing. I still have to figure it out. A good way to know if the system is obstructed is to press the drain button when there is some water left in the bottom.
Posted on Dec 31, 2008
  • 360 Answers
SOURCE: GE Profile PDW7300, Leaves 2 - 3 inches of dirty water in bottom
check for a clogged discharge hose where it connects to the plumbing under the sink...this is the most common area for a clog. if no restriction is found, the discharge valve will need to be tested
Posted on Feb 20, 2009
  • 4 Answers
SOURCE: Maytag portable dishwasher is not draining
try to clean the filter by taking off the bottom section of the water jet, it might be clogged, if that does not work, u got the same problem as me, it just wont drain. The pump is probably broken.
Posted on Feb 22, 2009
heatman101
  • 43501 Answers
SOURCE: Water does not drain completely,water from sink backs up in DW
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Jul 12, 2010
My kenmore diswasher model 665 15772 - lock button is flashing - dishwasher will not start. Can you help me?
6/3 I bought a Kenmore Ultra Wash dishwasher, Model 665. As many others have posted, my dishwasher also do does not automatically drain, leaving about 3" of water in the bottom of the machine. The only way to pump the water from the machine is to use the Drain/Cancel button, which cancels the cycle, and the dry option, leaving the dishes wet and spotty.
I just contacted a tech rep with Sears Repair and was told this is a Factory Defect with this model. Whirlpool (manufacturer) is aware of the problem and working on a resolution. Meanwhile, Whirlpool (via Sears and K-Mart) offers a free service call to install the "retrofit kit" that should solve the problem.
Even though Sears is aware of this problem, you will be expected to jump through their hoops - did you install a disposal at the same time and knock out the plug (FYI - if the plug is not knocked out, the Drain/Cancel option will not work and the machine will not drain at all). They will also ask if there is anything blocking the drain (FYI - if there is a foreign material block of any kind, the Drain/Cancel option will not work and the machine will not drain.
If this dishwasher (Model 665) does not drain automatically, THIS IS A FACTORY DEFECT. A retrofit kit is available to correct. In the DC Metro area, the wait time for an in home service call is three weeks.
If you have this problem, call Sears 1-800-4MY HOME and schedule a FREE retrofit kit installation
ALSO, call your sales person, and the appliance dept manager, at the store where you purchased the appliance to let them know this product is defective.
Jun 26, 2010 | Kenmore Dishwashers
Kenmore Elite: Model 66576962K601.
I had exact same issue. I've called Sears Maintenance. They had to change 2 pieces in UI: Timer KUDS02SRB10 and CONSOLE Assy. Cost 360$ pieces  130$ Job Charge 60$ taxes.
Now It works perfectly, but I bought 1100$ 3 years ago... Really expensive to keep it running.
Nov 29, 2009 | Kenmore Dishwashers
Our dishwasher pools with water and this a.m. there was water all over our hardwood flooring. I drain the water 2 - 3 times a day. We moved in this house with no manual for the dishwasher.
the bosch dishwashers are known for faulty inlet/water fill valves. that is a very real possible problem, however, have a tech out immediately.
you can try a do it yourself approach with the valve. replace the valve with part number BT-425458. (your local parts depot should have it, or try an online store such as "AP Wagner" or "Sears". My shop carries it at our parts department).
*notice; The new valve should have the solenoid coil laying horizontal, the original likely will be vertical. they have a history of failing in the "open" position, letting water in even with the unit "off" I've seen many insurance claims due to this failure, especially in the late 90's early 2k's. I'm sure there are still thousands out there. I should add, other possibilities could be, one being back flow throuh the drain line (hooked to a garberator?).
*If it is only happening when nothing else is in use, i.e. water running in sink, garb. running, including the dishwasher, I'd bet on the valve.
hope that helps,
good luck
p.s. if you provide a model number you should be able to get a manual via a pdf on the b/s/h home site here, http://www.bosch-home.com/us
Sep 26, 2009 | Bosch SHU3305 Dishwasher
Kenmore Elite Dishwasher model 16264 electrical fire
I contacted my lawyer who advised that I file a Civil Complaint against Sears so that is what I have done.
Feb 18, 2009 | Kenmore 24 in. 16264 Built-in Dishwasher
Dishwasher won't drain -it's only 3 months old
Yes they do have a drainage problem! I worked for a Sear install team. You need to have the installer come back out, if they did the install correctly and you still have problems then sears needs to send a service tech out. If they can't fix it or tell you it is a install error then be persistent and tell them you want a BOSH TECH out. You more than likely need a stronger pump as Bosh DW work off a gravity type pump system. Keep in mind Sears installers guarantee there install for 1 year and all products come with a 1yr MF warranty. If you purchased a warranty or PA agreement the you will be entitled to a new unit if that one is not fixable. If you have a garbage disposer, they work best when routed into one.
Jan 17, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
We recently bought a house with a Kenmore 363.16222100 (?) dishwasher. No manual. Monday night it didn't drain properly and leaked some water on the kitchen floor. The cycle had finished when we saw the...
Hello
Welcome to Fixya
My name is Huum,
You can find your model dishwashers manual here at this site. this site
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0801624.pdf
I feel you should not invest blindly in someone else s old dishwasher with no history.
Buy your self a new one
It will be much more energy efficient too!
Please remember to leave a rating before you leave
Dec 10, 2008 | Dishwashers
Sears Kenmore Automatic Dishwasher: Models No. 14041 /14045 /14045... Problem:
Many dishwasher have their drainlines tied into under sink disposers. If a person caps the sink drain while dishwasher is running, it can back the water back to the washer keeping dishes dirty and backing up water
Jul 05, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Installing a dishwasher
If you are replacing an existing dishwasher installation then it is no problem.
If you are putting in a new dish washer where there was not one before then you have to run wiring and plumbing (fresh water and drain).
Get a good one. Here is what Consumer Reports recommends.
Kenmore (Sears) 1373[2] , $580, CR Best Buy
Kenmore (Sears) 1374[2] , $650, CR Best Buy
Whirlpool DU1100XTP[Q] , $500
Nov 20, 2007 | Computers & Internet
Kenmore Ultra Wash Model 665 Dishwasher
Dishwashers which are properly installed and regularly used won't normally have a problem with bad odors. Check the following: ?Was the drain hose brought in at the top of the cabinet, or down near the floor? it must be 34" from the floor. ?Do you run the unit at least once every 2 days? -Run a cycle with a quart of vinegar to clean the tub and pump. ?Does the disposal tend to back up slightly when the dishwasher drains? Drain may be clogged. -Don't use gel detergent! ?Check your water softener(If so equipped) These can cause foul odors in the water supply if not properly balanced or maintained Good luck!
Sep 02, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
