Question about Garden
Walker mower starter
Walker mower, cannot find starter 2005 MTL model, seems to be sticking, and do not understand much about these mowers. Just need help to save a costly repair bill. Turn the engine key, and hear a click noise but no turn over of the engine.
  • 106 Answers
SOURCE: My riding mower blows fuses once you turn the key.
Sounds like you are on the right path, maybe some wires on the ignition were replaced backward, and you are sending +12v directly to ground? Does it blow right away?
Posted on Jun 04, 2009
mickey813
  • 472 Answers
SOURCE: Kohler command 20 Hp. engine on walker mower
you can lub it up with some 3m oil if that dont fix it than it may need a new one
Posted on Oct 01, 2009
  • 13 Answers
SOURCE: nothing happens when you turn on the lawn mower
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Posted on Apr 16, 2010
  • 376 Answers
SOURCE: CubCadet 1554 - won't start!
If you hear the PTO click when you turn the ignition on, sounds like the PTO button is pulled out like you were engaging the blades. The engine will not start if the PTO button is pulled out....
Posted on May 07, 2010
SOURCE: 18hp craftsman riding mower model#917.255913. won't turn left!
I have had this problem for the longest time. I replaced the secondary gear twice. Helped for a brief period and now won't turn left again. Replaced the steering shaft and worked for a brief period. Back to no left turns once again. The issue is with the secondary gear and bearings (plastic) which is only a temporary fix. What I had done was welded a piece of steel to the bottom of the steering shaft eliminating the secondary gear connecting directly to the tie rod for the steering. Works perfect now.
Posted on Jun 01, 2010
Walker mower pulls to the right
If this is a self propelling mower, check the inner wheel gear patterns for wear. Remove each wheel, only the ones that are self propelling. On the inside of each you will see the jagged pattern that rides on the mowers propelling gear, the plastic eventually wears out causing one to catch better than the other hence you will get pulling on either side.
Nov 20, 2015 | Garden
Walker mower pulls to right
Walker mower turns over but will not start
needle and/or seat in carb
May 22, 2014 | Garden
After running my Walker mower for about an hour,the beeper goes on & the clock reads ''lube''
Grab your grease gun and start looking for zerk fittings you may have missed when you greased your machine last. You will probably find a few you didn't know about. GOOD LUCK FRIEND.
Apr 25, 2010 | Blade WALKER LAWN MOWER DECK HUB BLADE...
I have a 26 hp efi walker mower and the problem I am experencing is that the mower engine shuts down when forward movement is activated, mower stays on in reverse, I have 712 engine hrs and have just...
Sorry about this problem but i would suggest that you flush oil and get new oil into it. Please do this and your problem would be solved.
Regards
Sep 12, 2009 | Mtd Garden
Garden Logo
361 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
