Question about Dewalt Dc385 Reciprocating Saw 18v Tool Only
Dewalt DC385 runs good for about a minute then slows to a stop. Battery is fully charged and when I remove it and put it in my drill it works fine. any ideas?
  • 313 Answers
SOURCE: dewalt dc 988 cordless drill
posible motor problem, the built in magnetic ring in the motor may broken inside or just to much dust in it. advice when replacing motor also replace th switch for the cost $132.00 plus tax canadian. thanx
Posted on May 24, 2008
bozcro
  • 867 Answers
SOURCE: Dewalt 18v impact drill
if you use it every day, it would be normal for the battery to be at the end of its life. ni cads are usually good for 300 charges/discharges
Posted on Jun 21, 2009
rowdy45176
  • 2176 Answers
SOURCE: I have aa 18 volt Dewalt drill. When I put in a
I would have to think the motor, what does it sound like? Do you notice a burning odor, If you are not careful it might short out the new battery. Let me know and I will see what I can do
Posted on Jul 14, 2009
SOURCE: Holding battery charge on 12v DeWalt batteries
Are batteries for the dewalt cordless drill interchangeable? Will an 18 volt battery fit in a 12 volt drill?
Posted on Feb 24, 2010
rowdy45176
  • 2176 Answers
SOURCE: I have a Dewalt DC385 Reciprocating saw, when I
I would look at the battery contacts first for burnt/discolored contact, if so clean with something like a pencil eraser, look at the contacts on the tool also. If these are acceptable then I would think a loose wire inside the handle area is causing. Before disassembly hold tool level and GENTLY tap with a soft hammer to see if you can get it to work and that would be a first indication of a bad connection
Posted on May 24, 2011
Charger light blinks rapidly for dewalt charger?
usually indicates battery has failed slow blink charging steady red fully charged
Nov 03, 2017 | Dewalt Drills
How to tell if its a battery problem or the motor is just wore out.
Richard, test your battery with a digital volt meter, charged battery will show close to or over 15 volts, try another fully charged battery, borrow one if need be.
show your appreciation by pressing the helpful button and follow me on fixya for more tips and info.
Feb 14, 2016 | Dewalt DC728KA 14.4V 1/2" (13mm) Cordless...
How long to recharge a 18v dewalt drill battery
A fully working 18v Dewalt Battery will only take 90 minutes to just over an hour to fully charge from going flat. This fully charged battery should last about 4 hours of use (depending on the load). So the answer is 1 hour.
Aug 11, 2013 | Drills
My dewalt 18v xrp battery wont take a charge
Depending on how old or more to the point how many times you have already charged the battery, it may be worn out. All rechargeable batteries do reach a point where they won't charge up anymore. If you have fully discharged the battery and tried to fully charge it up again and it won't take a charge or only lasts a few minutes on a charge it may be time to recycle it and buy a new one.
Aug 22, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Re: DeWalt 18V XRP Cordless Drill Driver. Should performance of the drill slow as battery becomes weaker? My drill works fine for quite some time then suddenly loses all power, even the light won't...
Yes. It's kind of like a flashlight when your batteries get low the light get dim, but if you replace the batteries light gets bright again. The drill will get weak as battery get low.
May 09, 2011 | Garden
Can I use a dewalt 18 volt dc9098 battery on the dc385 Saw?
If you have the handle disigned for the lithium battery becareful using the 9096 battery as it moves in the handle a lot and can hit the terminal on the switch wrong and bend it or break it. Also it will get a lot of vibration when running and because it doen't have the support that it needs for a 9096 it wiill likely brak a contact on the switch eventually. the factory does say they work in any tool however.
Feb 14, 2011 | Dewalt 18v Battery Reciprocating Saw Dc385...
I have a dewalt xrp 18 volt cordless drill and the trigger stopped working the battery is fully charged and i tested the motor and its good this is the part number off the trigger 152398-04.
This replacement battery was a great find. We searched for batteries for our Dewalt drill and this is the only site(www.drill-battery.co.uk) that had it and at a good price. Works fantastic and is a great deal.
Jan 13, 2011 | Garden
My new drill suddenly stopped working even though the battery has been charged OK.
Is it Nano li-ion? have you got another spare battery to double- check?
I experienced the same problem with 18V Dewalt nano li-ion battery. Was fully charged, came to work- Dead!!! I was lucky I had spare one, so then i was ok, but anyways had to buy a new one. Check on these things:
1. Battery is faulty. If u have any chances to ask someone who has the same gun (voltage is very important!!! has to be the same!!!- 12V battery to 12V gun, 14.4 to 14.4, 18 to 18 etc). Put your battery into that other gun. If You find the same problem that means your battery is dead.
2.Gun with battery contacts. If you 100% sure, that batterIES (check 2 batteries, or more) are OK, check bottom contacts where u put battery in, use WD40, or similar to clean them.
3. Least common Dewalt thing (Most common in Panasonic drills) is trigger contacts.
Basically i do not know what model is your dewalt, i was only talking in general, but there are no miracles- stopped working suddenly, and what u describe new, for instance my new drill dw727kd is less than 1 year old, i was too stuppid to open that battery myself to void warranty :(
AAAAHHH!!!!!! One more thing - If you have not tried to open these screws- check your nearest Dewalt authorised repair center- new NANO batteries have 2year warranty!
Apr 24, 2010 | Dewalt 18 Volt Compact Drill Kit
Drill running slow
Is the battery fully charged? Is the slector switch on high?
Sep 15, 2009 | Dewalt Dc212 18 Volt Sds Plus Rotary...
Aug 27, 2008 | Dewalt 12V XRP Battery Pack
Dewalt Dc385 Reciprocating Saw 18v Tool Only Logo
Top Dewalt Saws Experts
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
