Question about Toshiba 27A60 27" TV
DEAD JUST STANBY LIGHT FLASHING AND HIGH VOLTAGE COMING AND COMING OUT A 1 SEC AFTER.
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
If the high voltage comes up and goes right down something in that area is either shorted , open or bad---only thing in power supply that could cause this is if the main voltage (130 volts plus to the high voltage area is HIGH---the high voltage will go excessive and shut the set down--xray protection.
Posted on Oct 26, 2012
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
Battery charge light flashing amber
Ok, lets start slowly, do you have both a new battery and a new battery charger? If both attempt to use your old battery with the new charger. Also could be a bad charger or a shorted out battery...
Good Luck
Feb 13, 2013 | HP Compaq nx9600 Notebook
I have a sony wega kdf-42a10 its only years old. i already replaced the bulb about a year ago....now when i turn it on the picture comes up then is there for about 4 to 5 sec. then disapears... they...
The tv also have a board that called a Ballast board this board only job are to ignite the tv lamp only.Hear alot of clinking too while the stanby light are blinking.Yes,the Ballast board it is dead and not help to ignite the lamp and helping it stay on.
Aug 25, 2011 | Sony KDF-E42A10 42 in. LCD Television
Red light on tv flashing.Tv will not come on when power button is pushed.Beeping noise heard coming from tv
This tv have a dead "H" horizontal High voltage output transistor.This transistor sit outer wall of the FBT-the flyback tranformer a big block of plastic with a red wire with a cap hook to a CRT-(tv tube).This tv should be repair by a professional,because "H" high voltage transistor are hard to find these day.Because of discontinue parts for tv CRT-(tube design).
Feb 08, 2011 | Philips 30PW9100D 30" TV
Hi, I have recently purchased a Toshiba 32KV500B television. I tried to turn it on but the stanby light is flashing. No image or sound is coming out from the TV. I have checked all cables. unplugged them...
The flashing standby light means the TV is updating. Probably wasn't the best idea to unplug it, but if you leave the TV to update for around 1 hour, everything will be back to normal.
Jan 15, 2011 | Televison & Video
Tv is in stanby mode. when i turn on power it seems like it wants to start but nothing comes up on screen. stanby light is blinking
The problem is in the main board of the tv, it is either a power supply issue or a high voltage problem. In order to isolate you will need a tv tech to check the set out and cost involved.
Jan 07, 2011 | Sony FD Trinitron WEGA KV-34HS510 34" TV
The screen stays black but there s a stanby button that flashes at the bottom
Ur high voltage is dead,the FBT Flyback transformer,the big block of plastic with a red wire with a hook to a CRT(tv tube) is dead.
Dec 12, 2009 | Televison & Video
On timer light flashing
Ur high voltage is dead,Ur FBT,the flyback transformer it dead,big black block of plastic with a red wire with a cap with a hook CRT(Tv tube).
Oct 02, 2009 | Televison & Video
Red stanby light is flashing with sound but no picture 1996 sony projection screen.I also here a clicking noise sometimes.
I will forward a link to a page where you can get more information about this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C399467
Jun 16, 2009 | Sony KP-61V75 61" Rear Projection...
Carrier 40MVC A/C Flahing LED
there is problem with the unit. the 2 flash codes indicates a problem.
i am just not sure what it is.
it could be a low voltage alarm,
a high voltage alarm
freezing evaporator alarm.
not cooling alarm.
reset it by un pluging the unit for 1 minute then plug it back and run it. observe if the compressor would start.
if it start, check if it is cooling,
if it starts to cool, check the coil of the evaporator if it is freezing..
you could trace from there what is wrong with the unit.
pls keep me posted..
kindly use the ask me button,
tnx 4 using fixya,
drcool
Sep 06, 2008 | Heating & Cooling
Toshiba 27A60 27" TV Logo
54 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
