Question about Toshiba REGZA 32WLG66 32 in. Television
46xf355d blinking green
Blinking green every second please help any one know what this fault is no sound no picture had two horizontal lines before the screen went off.
    Top Expert:
  • Toshiba Master
  • 75,581 Answers
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Posted on Oct 26, 2012
SOURCE: Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Posted on Feb 06, 2008
  • 12 Answers
SOURCE: solid white horizontal line
Have a look at my 'I broke the glass post'
Posted on Jun 06, 2008
SOURCE: vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Posted on Apr 21, 2008
SOURCE: Horizontal green line appears on screen
my maxent plasma tv has the same problem but it has green and red lines. I found out that hitting the tv from the back works. It used to last a long time but now i have to get up now and then to slap the tv on back with my hands! anyone with a long term solution?
Posted on Jun 12, 2008
  • 298 Answers
SOURCE: JVC PD-42DX6BJ plasma 42 inch black horizontal lines over the pic
Here's a link to order the original the JVC upper Y-buffer board and lower Y-buffer board for this model from a major parts distributor if needed:
JVC "PD-42DX6" Replacement Part Upper Y - Buffer Board (LJ41-02760A)
JVC "PD-42DX6" Replacement Part Lower Y - Buffer Board (LJ41-02761A)
Based on the symptoms: It is possible that the Y-buffers are faulty, which may require the replacement of the Y-sus board as well. You may want to get a local technician to diagnose the unit and provide a second opinion.
Posted on Apr 01, 2009
My sanyo lcd 50" tv is flashing green blue red colors across screen?
Sounds like display panel fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Aug 19, 2015 | Televison & Video
No picture, green picture or horizontal bars
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 31, 2014 | Televison & Video
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My (2) Philips Magnavox 27TS54 C101 have lost the picture accept for one white horizontal line.
Hi Dean,
White horizontal line then the unit automatically shuts off with a led blinking on the front panel is an indication of faulty vertical deflection circuitry.
The most common faulty parts is the vertical deflection IC (TDA9302H) itself. This IC is mounted on the aluminum heat sink near the flyback transformer. You have to replaced it with new one to resolve the issue. Click HERE to have an idea how much it will cost for the parts.
Hope I helped you.
Good luck and take care!
Jdvillanueva
Jan 11, 2012 | Philips Televison & Video
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
I get curved red lines and then screen goes completely red and no sound
This is symptom of defective red picture tube in TV that needs to be replaced.
Let me know if you want to replace it by yourself to provide you part number info or call tv tech to do the job.
Thanks.
Nov 30, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
My Sony 42" DLP TV blacks out every 87 seconds. Then the green standby light blinks 30 times then I get picture and no sound. 7 more blinks after that I get sound. In 87 seconds later, it blanks out again...
Please replace Lamp in TV because this lamp is weak in result, causing darker picture and turning off and on TV.
Lamp replacement procedure would be written in user manual and its easy.
I would recommend to buy Sony original replacement lamp for TV safety.
Thanks.
Nov 13, 2009 | Sony Televison & Video
No horizondal oscilation.
no line flyback transformer
vertical line horizontal out put circuit
horizontal line vertical output circuit
at fault
Sep 14, 2009 | Televison & Video
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
Sony KV-28CL10U TV
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 08, 2017 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Toshiba REGZA 32WLG66 32 in. Television Logo
126 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
