Question about Maytag Washing Machines
How to remove front panel on my maytag performance pav3300aww
How to remove control panel
5 Suggested Answers
  • 351 Answers
SOURCE: removing front panel on maytag washer
some maytag panel just pull off from the bottom,they are just a tight fit.and some have screws under the hob.
Posted on Mar 21, 2008
  • 1073 Answers
SOURCE: How do I remove the
take a putty knife and about an inch inward on each side ther is a top retaining clip, push in with the putty knife and lift up on the top, do the same for the other side, it may take a try or to but you can do it
Posted on Apr 12, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: My maytag washer model PAV3300AWW will not spin
Check the belt at the bottom of the machine. You can also remove the back panel. Either the belt has become stretched or broken and needs to be replaced
Posted on May 22, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: Front Panel
See the first part of my Clutch Fix I describe the process and have links to the Service manual.....Rich
Posted on Apr 26, 2010
How do I remove the light wiring harness from the front panel?
Type Maytag Epic Z into YouTube and see if the video comes up, thanks!
Jun 25, 2015 | Maytag Epic z Front Load Gas Dryer
Maytag control panel
why do you want to remove the control panel?
much more info is needed...
you can gt to it by starting from the back and removing the screws from the top. push the top panel backwards and remove it from the cabinet. then you can access the front panel. it will have 2 screws holding it to the front. remove them and then lift the control panel up and off the front.
Nov 03, 2013 | Maytag Washing Machines
My Maytag Neptune washer is not spinning and I tried only Spin cycle for 12 minutes and gave LR error message. Pl help?
Hi, the Maytag Neptune front load washer LR or Locked Rotor error indicates and issue with the motor drive system. The motor control board is located near the floor on the right side. See Neptune Disassembly help to remove the door and front panel to get access, if needed.
I would unplug machine, remove all connectors and reinstall a few times and retry machine in case of any oxidation on the connectors. Also, check the belt and make sure it has not popped off. There is a rear access cover you can remove to take a peek.
In addition, there is a motor drive test you can perform to see if the inner tub will rotate at 50 rpms. You should have a document with your machine that instructs how to perform this simple test and it could be located in the top console.
Depending on which machine you have... If the motor control board has failed then you may have to replace the motor and motor control board since Maytag redesigned them because they were having reliability issues with them and they decided to change the motor technology they were using. See maytag maytag Neptune motor conversion kit for more info.
I hope this helps...
Apr 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
How do i remove the drum on a maytag top-loading washer.MAV 7000aww
If you want to remove the drum of your maytag wahser follow this procedure:
  1. Disconnect the power supply to the Maytag dryer by unplugging it from the wall outlet.
  2. Use a screwdriver to remove the three screws located at the top of the control console.
  3. Pull the control console forward to release the tabs that hold it to the Maytag dryer top. Maneuver the control panel out of your way without disconnecting any wires.
  4. Use a putty knife inserted between the top and front panel to disengage the retaining clips that secure the top panel of the Maytag dryer. Lift the top panel up, and remove it from the dryer.
  5. Use needle nose pliers to remove the wires from the door switch terminals. The door switch is located just inside the front right corner. Grasp the wire leads with the pliers and pull them off the terminals.
  6. Use a screwdriver to remove the retaining screws that hold the front and side panels together on the Maytag dryer. Lift the front panel up and out of the work area.
  7. Use a screwdriver to remove the Maytag dryer drum light lens screw. Press the locking tabs on the light socket, and remove it from the cavity of the drum.
  8. Use a socket wrench to remove the four retaining bolts that secure the drum bulkhead to the sides of the Maytag dryer.
  9. Reach your hand beside the drum and the motor, and push the idler pulley forward to release tension on the belt. Make notes of how the belt is routed on the pulleys, and then remove the belt from the motor pulley and idler pulley.
  10. Grab the belt with one hand, and the Maytag dryer drum with the other. Pull the drum out of the front of the dryer.
Jan 30, 2010 | Maytag Washing Machines
My maytag washer stoped during the cycle with 8
You may have blown the internal fuse located in the lid switch. Could be you over loaded the washer and blew the fuse.
Unplug the washer and remove the four screws holding the control panel front in place. Two screws on top and two screws under control panel.
Remove the control panel and tilt forward.
Locate the lid switch assemble and remove glass fuse and inspect.
Door switch assembly should be replaced. When you order the proper fuse it should come with the door switch assembly.
Replace assembly. Reinstall the front control panel and four screws.
Plug machine in and test.
Jan 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
May 22, 2009 | Washing Machines
Leaks water during fill up
That washer is inspected by raising the top. Insert a putty knife into the crack between the top of the front panel and the bottom of the top. There are 2 spring-type clips holding the top down. You should feel the clips resisting as you push. When the top is up, you can see down into the machine, and hopefully see your leak. If not, the (2) 5/16" hex screws now revealed can be removed to remove the front panel for better access to components under the tub.
Apr 25, 2009 | Washing Machines
My pav3300aww top load maytag washer squeals when it stps after spin jimboo
sounds like a brake issue, youll need to replace the brake to stop the squeak. problem with this is the brake is loaceted on this machine under a "high tension" spring nad in order to remove and replaceit youll need a specialized brake removal tool. GOTTA LOVE MAYTAG. so the cost to purchace the bake and the tool to do the job may out weighthe cost of someone doing the job for you..just like your car thought its a sqeaky brake, JUST ANNOYING to listen to but no real harm being done
Mar 19, 2009 | Maytag Washing Machines
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
