Hi
You can order from your local Quinny retailer or direct from the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
RRP for Quinny Speedi front wheel unit is 27GBP
RRP for Quinny Speedi rear wheel (each) is 37GBP
There would be a p+p charge of 3.99GBP or 8GBP on an order placed direct depending on the weight of the final order.
SOURCE: looking for a replacement front wheel for my
contact Quinny directly through their parent company Dorel - www.dorel.co.uk They will sell you a new wheel
SOURCE: How do you attatch the dreami carrycot to the
Try this web link, it will take you to the owners manual that you can view or print out and show you the answer to your question.
http://quinnybaby.com/info_instructions.asp
Hope this helps, DutchTexan
SOURCE: Quinny Speedi sx replacement seat unit and hood
you can get replacement seats & hoods from quinny.com they are really helpful, seat is £65.00 Hood £35.00 hope this helps
SOURCE: How to I collase a quinny speedi sx pushchair
f the dreami carrycot or the maxi cosi car seat are attached, these will have to be removed first. Apply parking brake Release the handle bars by unclasping the silver clips on the frame. Push down handlebar to lowest height as you press in the silver button under the quinny logo on the very top of the handlebar( in the middle of the foam padding) with a downward thrusting motion. The chassis should then collapse for storing. To unfold then release the transport clip on the left hand side with the red sticker on it and unfold upwards adjust handlebar to required height and lock by closing the silver clasps either side of the frame. If you want me to do a pic/video demo let me know. HTH
