Question about Ariens Garden
Pto stopped working on areins tractor.
Have power on one wire to pto at all times and when switch is engaged have power to both wires. Is that correct or is the switch bad?
  • 1 more comment
  • george boren Oct 26, 2012
    no you should only get power to switch when key is turned to run position.clarify exactly your steps then well be on the same page and i will guild you thru
  • Stan Gertner Oct 26, 2012
    With the two wires discounted from the pto and engine running I use a 12 volt test light to test the wires. With toggle switcg off I have power to one line. When I put the toggle swicth to on I have power to both wires.
  • Stan Gertner Oct 27, 2012
    I hooked the wire that the switch controlled to the pto and then ran a new wire to ground. Pto worked. It is a bad switch as only one wire should be hot.
    Novelist:
    Scholar:
  • 80 Answers
It sounds like your switch is working. Other issues might be a belt that jumped it's track and isn't tight when the tensioner tightens up, or a belt that has stretched beyond working limits, or a bad PTO clutch. You could also have a bad spot in the wire that heads to the pto clutch.
Posted on Nov 14, 2013
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • 218 Answers
SOURCE: Cub Cadet PTO will not engage
Do you have a volt meter or a 12 volt test light?..if you do you can see where you are losing your voltage at..but i would suspect the PTO switch is bad..i hope this has helped.....Keith
Posted on Jun 30, 2009
wireguy212
  • 1627 Answers
SOURCE: JD 6400 tractor, PTO light flashes when engaged
The most likely problem is the pto solenoid valve on the rear of the tractor.It could be the speed sensor but you won't know until you get the codes read by the dealer.I have had to replace the b.c.u. for this problem but it is not common.
Posted on Oct 20, 2009
SOURCE: electric pto clutch will not engage garden tractor -cub cadet gt1
the electric clutch jhondeere won,t engage
Posted on Apr 30, 2010
miket756
  • 2702 Answers
SOURCE: engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
Posted on May 02, 2010
The pto will not engage when switch to turned on
The light just indicates power is available for the PTO clutch. It doesn't it reaching the clutch. You need to unplug the PTO clutch and check to see if voltage is there. If it is there then clutch itself is bad or the wiring from the connector to clutch is broken. If no power at the connector then you have wiring problem and may even have part of the PTO switch not working.
Jul 31, 2014 | Garden
My Allis Chalmers 6080 PTO will not shut off with the lever. Even though I pull the lever to stop PTO, it stays engaged. Any answer to this issue?
The lever is maybe not engageing the electrical switch so if it worked good in the past something has worn or come loose.Find the point where the lever engages the switch and there are usually 2 wires running to the pto.Also one or more wires might be off the pto.Go from one thing the lever does to the next step and it might be a bad switch if the lever is working the switch and it still does not turn off.Hope this helps
Nov 05, 2012 | RTO Allis Chalmers Tractor Pto Shaft...
John Deere LX173 pto will not engage. Wet recently
Probably the pto switch. Find the 2 wire 'T' plug from the PTO clutch and disconnect. With a voltmeter across the the 2 spades on the tractor side of the plug you should get 12 volts DC with the PTO switch on ( you may need to sit in the seat ). If you get 12 volts at the plug its probably the PTO clutch. If no power then its a fuse or the PTO switch
Oct 24, 2012 | John Deere Garden
Pto, electric clutch
check the wires they rub on sharp edges
Mar 23, 2012 | Husqvarna Garden
I have a Craftsman GT 5000 Garden Tractor, 25 HP, 48" mower. I recently changed the mower belt and it was working fine for about 2 weeks. The last time I mowed, the mower blades suddenly stopped and I...
Depending on your engine.. Briggs and Stratton or Kohler there are 2 different seat switches that are used to power the PTO clutch. The seat switch can cause the PTO clutch to disengage anytime there is not at least 70 lbs in the seat.
The PTO drive wiring has a 30 amp fuse in it. If by chance a stick went through the belt and tore off the wires at the PTO clutch (Common failure) even after you repair the broken wire you still need to replace the fuse.
Check the PTO clearance gap. It should be 0.012 dis-engaged. Any other value and the clutch will not work correctly. Adjust the clutch if necessary.
There is a 2 pin Pigtail just off of the PTO Clutch that you need to check for voltage at the connector. Probe the back of the wires if you can and your looking for 12V DC under the following conditions.
BRAKE ON or tied down
KEY ON
SEAT (Briggs and Stratton engine only) Someone needs to be sitting on the seat.
Then Pull the PTO Switch out. You should hear the PTO Clutch CLICK. If you hear the click there is no need to check voltage. The PTO switch is a multi function switch and it is quite possible the PTO switch failed. I doubt that the PTO Clutch has failed as they normally give you some kind of noisy indication that they are failing and don't fail straight away.
So.. In short
Check PTO Switch (Red wires) to usually red or brown thru the switch
Check 30 amp fuse
Check PTO clutch wires near PTO clutch (They get torn from something traveling through the pulley)
Check PTO clutch clearance at 0.012
Check Brake switch for an audible click as you depress it some distance No click.. possible bad switch
Listen for Seat switch Click as you slowly add weight to the seat. No Click or any click and it can still be suspect due to the Briggs and Stratton installed engine ones have more than one function.. Ignition and PTO clutch power.
The actual wiring diagram is on page 35 of the owners manal that can be found here:
http://www.managemylife.com/mmh/owner_manuals/27245/CRAFTSMAN-Lawn,-Tractor-L9910386?brand_name_search=917273023
Lastly... check each of the mower deck blade bearings. A seized bearing can cause PTO problems.
Hopefully you have enough information to solve the mystery. If not just respond here and I will help you.
Thanks for choosing FixYa.
Kelly
Oct 06, 2010 | Craftsman Garden
GTH2548 drive spring broke and I replaced it. Tractor would not start. Replaced battery, start switch, seat switch and PTO switch. Tractor will now start and runs well. However, when PTO switch is...
yes when the belt broke it grabe the wires that goto the cluch frome the pto switch and thay have bar spots on them and are grounding out i just done one that was doing the sam thing all you have to do is fix the wires and that should fix ya up thanks for your time mickey
Sep 08, 2010 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
Cub Cadet 1861 amp light comes on when the PTO is engaged and after mowing for a short time the PTO disengages and now the 30 amp fuse blows and stops the engine
Sounds like you have a short circuit, either in the PTO clutch, or in the wiring that goes to it. Inspect the wiring for any obvious spots where insulation has rubbed off or burned. Also look at the wiring at the back of the PTO engagement switch for these signs. Before buying an expensive PTO clutch, unplug its connector. Drive around with the PTO switch on (even though the PTO won't activate and the blades won't be engaged). If the fuse doesn't blow, the problem must be within the PTO clutch. If the fuse still blows, it must be in the PTO switch or the wiring from there to the clutch. Use an ohmmeter to trace and find the short. Good luck!
Jul 09, 2010 | Oregon Scientific Electric PTO Clutch for...
I think i may need to replace the pto clutch on my stx38...is it difficult to do? Also, how can i best determine whether it is the pto clutch or perhaps the switch that activates the clutch. currently,...
Depending on the age of the mower, it sounds like a wire has wiggled lose, or the switch itself has gone bad. I would check the wiring to the switch and to the pto clutch and ensure that all wires are secure, free of corrosion. If this still doesn't fix the issue, install new switch. This appears to be entirely and electrical issue, and is a cheaper troubleshooting method before tearing down the pto engagement system.
Let me know!
Chip
May 31, 2010 | Garden
Pto clutch keeps shutting off
If you have not replaced the pto switch do so. If you have check wiring from switch to the pto coil. Many times the wiring at the pto coil is rubbed by the belt until it wears the wire into. You can also try energizing the coil to the pto directly from battery (With engine off of course) If it energizes and stays energized it is probably not the coil.
May 03, 2009 | Garden
Garden Logo
126 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
