Changing out an LCD screen
I need a step by step instuctions...to me it sounds easy to do, but before I attempt something I have never done before, friends recommended I try to find a youtube video showing me how. I am also concerned about the broken glass. Still solid screen, but cracked. Thanks!!
  • 1 more comment
  • joecoolvette
    joecoolvette Oct 26, 2012
    I need the laptop manufacturer name and model number.......The model number is on the bottom of the laptop. Otherwise you just get generic info you could find -> ANYWHERE. I may be able to find a link to a Service Manual for you, and post pictorial guides. Plus I have a COUPLE of years at laptop repair, lol! Post back in a Comment. Regards, joecoolvette
  • lsmacazo
    lsmacazo Oct 28, 2012
    Hello, I have a HP Pavilion dv6-3225dx. The two bottom screws are unreachable as the laptop is even, top and bottom. reallyt stupied way this computer was put together..
  • lsmacazo
    here is my email lsmacazo@yahoo.com
  • 5,660 Answers
Ismacazo, do NOT post your email addy on here!
HP Support > Pavilion DV6-3225dx Notebook PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&lc=en&product=5051461&
In the list click on - Manuals
HP Pavilion dv6 Entertainment PC - Maintenance and Service Guide
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=5051461&
(Took you the 'long way', because I want you to have all information on your laptop )
[ Ignore if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which use PDF files.
After you click on the above file name it may take up to 30 seconds, before the first page comes up.
The PDF file is downloading in the background. It is a Temporary Download.
I didn't want you to click, and think nothing is happening.
The Zoom In icon at the Top ( + ) increases the view size.
The Zoom Out icon ( - ) decreases the view size ]
In the Bookmarks menu to the Left, click on the + sign to the left of -
Illustrated parts catalog
Click on the + sign to the left of -
Display assembly components
Finally click right on - BrightView display assembly spare parts.
Just wanted you to see all the components involved.
Now you see why the Display Assembly must be removed.
Go back to the Bookmarks menu, and this time click on the + sign to the left of -
Removal and replacement procedures
Component replacement procedures
Scroll the sidebar down, click right on -
Underneath Number 4 in blue, are the various components you must remove, in order to remove the Display Assembly.
They are listed in order, and in blue.
Suggested procedure is to click on each component listed, and in order.
When going to remove the next component in the list;
1) Put your mouse cursor, in the Adobe Reader page number box at the top. Left-click once. Everything in the page number box should now be highlighted in blue.
2) Type 77, or 78.
3) Press the Enter key.
Takes you right back to the page you were on.
(Or use the Bookmarks menu)
The Display Assembly MUST be removed, in order to remove the Display Bezel, and LCD screen.
NOTES*
1) Once the Screw Covers are removed, (I just lightly stick them to the Display Bezel for safekeeping), and the Philips head screws, the Display Bezel is flexed to remove.
Yes I read about it being broken. I would cut out cardboard from a cereal box, that just fits inside the Display Bezel, and lay it over the broken LCD screen.
Then use a thick guitar pick, or similar tool, (I use a Spudger Tool. About $3), ease up the middle of the inside, of the Display Bezel.
It is now flexed up a little bit. Use the fingers of your other hand, move over from the point you are at now, and ease up on the bezel.
The Display Bezel is made of space-age plastic. Pretty TOUGH stuff.
You do have to use care, but it isn't all that breakable.
Of course there are those of us, who could damage steel balls in a sand pile, with a rubber mallet.
The Display Bezel has Latches going around it, on the inside perimeter.
There are matching Tabs on the Display Cover.
When removing, the release of the Latches/Tabs sounds like you are breaking something. Snap, snap, snap.
Just wanted you to be aware.
Keep popping each Latch from it's Tab, and going along the Display Bezel.
Once you are at about 2/3 of the way or less, the bezel will come off.
The LCD screen should be PROPERLY disposed of, and NOT go in household trash.
2) Keyboard Cable:
The Keyboard Cable STAYS attached to the Keyboard. It disconnects FROM the motherboard connector.
The Keyboard Cable is an FFC. Flat Flex Cable.
One example of a FFC,
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
Note that the Keyboard cable does Not have a connector on the end.
Note also those flat terminal strips of the cable.
The cable MUST be realigned in the SAME position, it was originally before being removed.
For this reason you may wish to make a mark on one side of the cable, and a matching mark on the same side of the motherboard connector, BEFORE removing.
The motherboard connector is a style of ZIF connector.
Zero Insertion Force.
It is composed of two pieces, but does NOT come completely apart.
The larger rectangular bottom piece is referred to as the BODY.
The smaller upper rectangular piece is the Locking Bar.
For your style the Locking Bar flips up to a 90 degree position, or also stated as straight up.
IF, the Locking Bar is broken, and/or the hinge pins on the Body for it, you are looking at MOTHERBOARD REPLACEMENT, and why I am being so detailed about this.
BE CAREFUL.
3) Use an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Cost averages from $3 to $6. Pretty cheap insurance to make SURE you do Not fry out your laptop.
Here is but one example,
http://www.radioshack.com/product/index.jsp?productId=2103245
Why worry Joe? Because the Static electricity your body carries, WILL fry out (Short Circuit), the delicate hardware components inside the laptop.
You won't see it, or feel it. It isn't like taking your coat off in winter.
Poof! And you won't even know what happened.
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case. I feel an Anti-Static Mat is not warranted. (I also do not want my wrist connected to the ground source, of the utility company, and where bumbling utility lineman work on )
You can also set a large metal serving tray (Unpainted), on the table you are working on, and connect to it.
Or a large metal knickknack. (Unpainted)
4) The Top Cover (Palm Rest Cover) also has Latches on it, and the Base Enclosure has matching Tabs. After all of the appropriate screws are removed, suggest use a thick guitar pick, (Or Spudger Tool), and start popping the Top Cover loose.
It pops off similar to the Display Bezel, but does Not flex. (Shouldn't)
5) After you replace the LCD screen, and have the Display Assembly all back together, suggest you not attach it yet. Hook the Video Cable up, and see if the display works first, then turn off, remove ALL power, and reinstall the Display Assembly.
You can find out quick if you got the Video Cable to LCD screen connection on tight, and the motherboard connection.
Searches on the internet for a replacement LCD screen, reveal LED backlighting is used.
Therefore there will be NO screen Inverter.
http://www.laptopscreen.com/English/model/HP-Compaq/PAVILION~DV6-3225DX/
Make SURE you get the correct LCD screen.
A) http://www.insidemylaptop.com/replace-broken-screen-hp-pavilion-dv6-laptop/
B) http://www.insidemylaptop.com/disassemble-hp-pavilion-dv6-laptop/
For additional questions please post in a Comment.
Regards,
joecoolvette
( I have a 500,000 Volt DC license in my pocket, and am a qualified Journey Lineman. I can slam bumbling utility company linemen, Lol!)
Posted on Oct 29, 2012
  • 41 Answers
It is easy to do. And dont worry about the glass it will all stay together. Usually there are little rubber bumpers around the edge of the Bezel. Pull those off and there will be screws behind them. Take out all the screws and then stick your fingers between the screen and the Bezel and pry it off. Once you have the Bezel off depending on your model you may be able to get to the screws on the side that hold the LCD in. There should be like 4 very small screws on each side of the screen. If you can't get to the screws you will need to remove the screws along the edge that hold the hinge rails to the cover. Let the cover hang back and then take out the LCD screws on the side. Then peel back the tape holding the video cable on the back of the LCD and very gently pull it out. Then pull out the other connector for the inverter and voila it's out. Then just do in reverse to put it back. It's really easy and usually only takes me 20-30 min. Granted I've done tons of these so it make take u a lil longer but theres nothing to be afraid of and is a great learning experience. Watching a YouTube video first is a great idea. It's what I did the first time! Hope this helps u and good luck!
Posted on Oct 28, 2012
  • 105 Answers
SOURCE: Blank white lcd
Yes, it could very well be a dead LCD unit. I have a LCD in a laptop in the office that has a nasty line running down through the entire screen. We contacted someone about replacing just the LCD portion of it and they said - don't bother. They said it would be more prudent to wait until it dies, and then upgrade to a new computer. It is the nature of the LCD units themselves, when they give up the ghost they give up the ghost.
The fact that you can see everything fine on an external monitor shows that you have lost your LCD. The odds of the cable inside the machine going bad are minimal/tiny to say the least. If they were exposed cables such that they could get crimped, then possibly that could be the culprit. With them being routed inside the unit, it is almost impossible for them to get pinched.
The only other option, and this only works if your machine is still under warranty, is to have HP fix it as part of your machines warranty. BUT, not all warranties cover the screen anyhow. The laptops I have bought required me to purchase insurance on the screen itself.
So, you'll have to determine if you can manage with the external monitor all the time or if you need a new laptop.
Sorry it is not good news for you.
Posted on Jul 23, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Video problem
Generally this type of problem is the video card, however, it's extremely rare, but sometimes a screen malfunction will override the video out causing the appearance of a bad card. To check this, disconnect the screen, and try the external monitor. If the external works properly, then it's the screen.
Posted on Aug 13, 2008
  • 6 Answers
SOURCE: Screen Replacement
ok guys...i have had the same prob and it is now solved...finally...and what an *** about way to build a computer!
The bezel that covers the on and off switch is a snap in piece (it also screws in from underneath)tand you wedge a guitar pick under it and lift and it will pop out. Then you should be able to see the screws that hold the hinges to the main frame, there are two of the screws for each hinge...BRAD justanswer.com)
The screen bezel has 5 screws on the base..3 are acessible from here, 2 are not...These 2 are in the corner and blocked by the hinge...the hinge therefore must be taken apart via 4 screws (2 then you will see 2 more) on the circuitry board...and if you can get this far...the rest is straight forward
Posted on Jul 28, 2009
Geekman
  • 32281 Answers
SOURCE: how do i replace a toshiba qosmio f45-av411 lcd
You can buy LCD screens on the Internet, I purchase parts from LCD Parts, they also service/repair and have DIY info.
Use this link to their WEB site :-
www.lcdparts.net
Posted on Aug 28, 2009
jmgldsmth
  • 1869 Answers
SOURCE: Samsung NC10 LCD screen has a "broken glass" look
sorry but, the screen is gone
Posted on Sep 06, 2009
How to replace screen
http://www.youtube.com/watch?v=DlHgz4EzFkk the video is in Italian but they show you step by step how to replace the monitor on your exact same model... sorry but was the only video out there. Just mute the video lol
Jun 17, 2013 | Acer Extensa 5620 Notebook PC
How to install new lcd screen
Installing a new LCD is fairly easy in this model.
#1 Remove two bottom screws
#2 Remove four side screws
#3 Slide off silver side panel on the left Front side of the camera
#4 Carefully remove front cover (careful to pry off from the top)
#5 Flip over front cover and release the power panels ribbon cable from the system board
#6 Flip over plastic protector
#7 Remove Back Cover from LCD side
#8 The LCD is being held by 3 ribbon cables.
(This next step should be done very carefully - damage can occur if it is done incorrectly)
#9 Release the middle ribbon cable by carefully flipping up the black portion of the clamp.
Equal pressure should be applied to the full black portion when attempting to flip open.
Do not use excessive force.
#10 Release remaining cables and remove LCD.
To assemble just reverse the steps. We have color diagrams available just ask.
Thank you
Jan 24, 2011 | Sony DSC-T70 Digital Camera
Broken Screen Replacement
Dear it is very easy but a little bit tricky to change its screen, but if have you have any experience of repairing or opening the mobile phone then it will be more easy for you. you just open the mobile phone carefully because it has basically two parts screen part and Keypad part so be attentive while opening. after open the phone you just put off the strip (Jack) of LCD from the keypad part then put in the new LCD strip on it. reassemble carefully, you have done now...
Thank you
May 17, 2010 | Nokia 2760 Cellular Phone
My screen is "shattered" it looks like something was dropped on it and inside it looks shattered. When I turn it on there are lines and a little "hole" like spot on it. Can this be fixed for do I need to...
it can be fixed, u just need to change the LCD screen that is on the camera. its very easy to change. i can help u with all the supplies needed or u can take it to the service center & get it done. if u r interested in the supplies & want to do it yourself that u can comment back here
Apr 13, 2010 | Kodak EasyShare C513 Digital Camera
How to change screen bulb for Acer Aspire 1642zwlmi
I am assuming you are referring to the "back light tube"? If so they are easy to change however rarely the issue. Most likely your lcd screen is dead. Here is a step by step:
http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Mar 28, 2010 | Acer Aspire 1642WLMi Notebook
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Mar 27, 2010 | Vizio GV42L 42 in. LCD Television
I have a cracked lcd screen on my lenovo Y430. i want to open it up and replace with new lcd i just bough. wanted to know if there's any pictorial or video of how to disassemble and put in new lcd screen
Hi, good day sir, well there are pictorials on how to replace the LCD of a laptop on the internet, you may do search using search engines. happy searching.
Jul 16, 2009 | Lenovo IdeaPad Y430-3231U Notebook
Replacing wheel bearing in 1996 ford taurus
It probably needs to be pressed in & out. The hammer is only so good,lol. Make sure you tighten everything to spec too.
Jun 21, 2009 | 1996 Ford Taurus
How to change display strip?
The W580i LCD is easy, easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony W580i LCD Screen Replacement
I hope that helps you out
Jun 04, 2009 | Sony Ericsson w580i Cellular Phone
Laptop LCD screen failure
when you hooked up ur laptop to an external monitor, did you adjust the display settings, you have to do that if ur operating system is xp or older.
Aug 24, 2008 | Computers & Internet
Computers & Internet Logo
158 people viewed this question
David Payne
David Payne
