Indesit WIA 102 problem
The heeter was dead, so it has been runing the cycle wery long. After changing the heeter with new one 1700W (32,5ohm), when machine start afte while red lock led fleshing with spin cucle selector buton, and the pump is on. Do you have the idea what is wrong?
  • Mladen Oct 26, 2012
    I just finde out the meaning of the code. It is F8 (Heater relay can not be activated). I will check the PCB.
  • Mladen Mar 02, 2013
    After some more testing, the residual-current circuit breaker (RCCB) start to switch off. My friend then check the motor, and he found that the colector contacts are black, witch indicates the motor problem. Now the motor is repaired and machine is working fine. Than you all for sugestions. It was the motor problem and dead heeter too.
3 Suggested Answers
  • 197 Answers
SOURCE: Indesit WIA 121 washing machine,
One of the main problems with Indesit front loaders ( apart from replacing the door interlock switch) is
If the door will not close and click in the lock, then take the door off with a tork screwdriver and take the screws of the inner plastic off the door (make sure you do this on a flat surface) and gently prize off the inner plasic by running round a flat head screwdriver..
Once you have taken off the door and glass bowel - check out the door catch to see if a metal rod has come out of its housing holding the catch and spring in place and refit or replace.
I have come across many door catches like this.
Posted on May 17, 2009
beltronic205
  • 1466 Answers
SOURCE: The drum wont spin and then the LEDS start flashing
Could be motor brushes....
Posted on Nov 11, 2009
Indesit wia 101 stuck on one part of cycle and won't move on
check pump for blockage remove plug for 15mins re try
Apr 19, 2015 | Indesit Washing Machines
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
HAVE JUST AQUIRED WIA 111 without hand book. How
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Not sure what you mean by ‘turn off lock’. If you mean the door lock light is on or flashing this may indicate a fault, in which case you would have other lights flashing as well to indicate what the fault is. Click on this link for Hotpoint, Creda and Indesit error code definitions or if you need a free user hand book then click on user manual and select your manufacturer.
Mar 06, 2010 | Indesit Washing Machines
Changine a heating element on a washing machine Indesit WIA 101
Sam. The small nut and bolt which protrudes between the element ends should be loosened but not taken off. Press on the bolt, which will relax the compression on the rubber sealing block. This should allow you to extract the element. Once you have done this it will become clear..
Feb 20, 2010 | Washing Machines
Indesit WIA 121 not working - door latch not shutting
At first thought it was door lock mechanism was at fault but proved it to be ok - removed rubber 'boot' which on this model was on two stretchable spring retainers and checked operation of door lock.
Thought door hinges may have been bent so dismantled door, finding the problem to be the pin that the door latch pivots on had come out on one side so not lining up properly. This was easily pushed back into position.
Oct 05, 2009 | Indesit W 123 Front Load Washer
Indesit WIA102 keeps draining, even when washing
Try lifting the drain outlet higher than it is, if it is too low the water will syphon out as it is filling, there by causing the problem you are experiencing, if that does not solve the prob, then it sounds like the pump is on all the time, this being the case, then it would appear that it has a faulty programmer.
Plz rate my solution.
Thanks.
Jan 22, 2009 | Indesit W 123 Front Load Washer
Indesit WIA 101
to open do power off after 5 min open the door with power off
Jul 27, 2008 | Indesit W 123 Front Load Washer
Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Jun 25, 2008 | Indesit W 123 Front Load Washer
Indesit widl 102 extra rinse button always on!
Check that the button isn't stuck it if not remove top lid and check the PCB and see if the switch hasn't collapsed causing it to be on all the time. Also if you hold in the go button for about 5 seconds this resets the program try this.
Thanks J
Feb 07, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
