Question about Sportcraft Exercise & Fitness
Sportcraft treadmill TX 5.0 RC E7 light on. How to fix this?
Treadmill will not operate
5 Suggested Answers
  • 15 Answers
SOURCE: TX 4.9 sportcraft treadmill
Info from PDF files located on Sportcrafts website under manuals.
E3 – No speed sensor reading. Unit shuts down. This is the most difficult repair diagnose. The speed
sensor is connected to the frame of the treadmill near the drive pulley on the front roller. There is a
small magnet on the side of the pulley wheel. The sensor tip must be no more than 5mm from the
magnet. If for any reason the distance is greater than 5mm the treadmill will shutdown
Adjust or replace speed sensor.
Treadmill: Speed Sensor Replacement
1. Make sure your treadmill is unplugged before you begin.
2. Remove the motor cover located in the front of your treadmill, it is held on by a few screws.
3. Locate your speed sensor; it is the small T shaped part with a red and black wire coming from it.
4. Remove the 2 screws in the speed sensor and remove the old sensor.
5. Place the adjustment holder on the frame with the open holes facing the pulley wheel, the prongs facing
up and way from the pulley wheel. Insert the screws but don’t tighten fully.
6. Now place the speed sensor over the prongs with the square part facing the pulley wheel and the red and
black wire to the far right.
7. Plug the treadmill back in and slide the speed sensor until it is 5mm from the magnet inside the pulley
wheel, you may have to do this several times until you can position it so it no longer shuts down. Use 2
nickels to figure out the spacing. The width of 2 nickels is 5mm.
8. Once you find the correct position tighten the screws all the way; being careful not to touch any of the other electronics
9. Place the motor cover back on and enjoy your machine.
Posted on Oct 17, 2009
SOURCE: Sportcraft TX 2.5 treadmill - error code 3 - stops
Sorry I dont have the solution but I have the same problem.
Read somewhere that Sportcraft control boards had
a design flaw.
Posted on Dec 20, 2009
  • 26 Answers
SOURCE: Where can I find a replacement sensor wheel for a
Try Icon Service Group. You can google them and find the web address. They are an excercise equipment warranty provider but will also see you parts.
Posted on Jun 16, 2010
  • 33 Answers
SOURCE: My TX 5.0 RC Sportcraft
You will have to unscrew that part out of the treadmill and take it out, and then put it back in to see if that makes any difference. If for some reason that does not work, you may have to contact the company to get a replacement on your treadmill, or to see if they wil fix it for you. Since each treadill is different, defects are inevitable, so a person will have to use consider going this route if all else fails.
Posted on Jul 13, 2011
Motor Control Board
go to www. fitnessrepairsparts.com and get it.
God bless you
Jun 11, 2013 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
Treadmill speed varies with or w/o load. Belt not loose. Led speed indicator constant.
0ed98914-d0ff-4c07-aa5a-486eca10f03f.gif1) adjust the speed sensor see the diagram, clean the sensor very well, tight the connector very well.
2) LUBE the deck belt with silicone or wax READ your owner manual,
God bless you
Jun 03, 2013 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
Tx 5.o rc sportcraft treadmill varies in speed with or w/o load.
1) adjust the speed sensor, see the diagram attached, test for open or faulty. clean it very well. tight the connector very well
2) LUBE the treadmills very important . do it with silicone or wax. Read your onwer manual for verification.
Tx 5.0 rc treadmill by sportscraft, manual
Did u find out the problem? Mine just started doing the same thing.
Apr 13, 2013 | Sportcraft Exercise & Fitness
Sport trac treadmill shuts off after a few seconds
1) LUBE the deck belt, this produce enough friction, by lack of LUBE
2) Lube the roller bearing, very well
3) Test the input voltage motor, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
See the block diagram. God bless you
May 27, 2012 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
How do I turn on my tx 5.0 rc sportcraft treadmill if I can't find the key
DEAR SIR:
Go to any Hardware and to buy any small magnet, since the key is smal magnet, Do it by small pennies.
sincerely. God bless you
Apr 22, 2012 | Exercise & Fitness
My TX 5.0 RC Sportcraft Treadmill stops and show in the screen a #3... Start normal, but in seconds stops... I want to know how to fix it... Thanks...
Jul 13, 2011 | Exercise & Fitness
Where can I find a replacement sensor wheel for a Sportcraft Tx 5.0 RC treadmill?
Jun 14, 2010 | Epic 425 Mx Treadmill EPTL88105 !
Exercise & Fitness Logo
Top Sportcraft Exercise & Fitness Experts
John
Are you a Sportcraft Exercise and Fitnes Expert? Answer questions, earn points and help others
