Question about Whirlpool Refrigerators
Missing wire shelf bracket in whirlpool side by side freezer
Two types of brackets are missing from the right (refrigerator) side of the wire shelves. One type is essentially a post on which the front of the shelf rests while the other is a sort of small cup in which the exposed end of the wire shelf in back rests. Both types are white plastic and about 9/16 to 3/4 inch with square backs that slip over slightly smaller white plastic squares fixed into the wall of the freezer. These fixed plastic squares are shaped so as to provide male wings onto which the female slots on the brackets slip to hold the brackets in place. I need to find a few of each type of bracket but I haven't been able to locate them.
  • 770 Answers
SOURCE: Water Leak
pull the funnel tube out of the back wall and clean the drain that goes out the back wall of the refrig section
Posted on Feb 18, 2008
SOURCE: water leaking inside of refrigerator from freezer
The defrost drain is frozen, you need to take the cover off inside the freezer and there will be a drain hole probably coverd with ice, you will need to pop most of the ice out first then I use a turkey baster and a tub of hot water. Squirt the hot water in the hole over and over again untill it drains. Then just wipe everything down. Problem solved.
Posted on Mar 18, 2008
  • 979 Answers
SOURCE: Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Posted on Jan 14, 2009
  • 1136 Answers
SOURCE: water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Posted on May 30, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
Posted on Jul 01, 2009
Help to restore 1954 GE fridge door gasket. The gasket brackets are missing.
Hello Karen
Try somewhere like this
Refrigerator Parts
Gaskets for Antique or Vintage Refrigerators - YouTube
? 4:55
Jan 27, 2011 - Uploaded by AntiqueAppliances
... on two doors, no locks on the doors and not have the back cover. Do you have any pictures of this this ...
1954 GE fridge door gasket Google Search
Dec 01, 2017 | GE Refrigerators
I just got a whirlpool Fridge, yet21dkxdw03 without a manual, I have set up all the shelves, there is one shelf I dont have a clue how it operates, It has a roller hinge on not see anywhere it is...
Hi, Did you figure it out yet? We have same fridge. Compressor went on it a few months ago. Should have a metal bracket horizontal along the back. The wheels slip inside it. Lift front end as you insert back end of shelf.
Sep 30, 2011 | Refrigerators
I need a door shelf for my Frigidaire side by side refrigerator (# FRS6R5ESBFPN # 241691311)
  • You did not list freezer door or refrigerator so I will link you to all of them and you can choose the one you need. These are all for Frigidaire FRS3R5EMB
  1. Upper freezer shelf -
  2. This one is a replacement for the lower 3 freezer shelves
  3. This one is a replacement for the 2 bottom shelves of you refrigerator
  4. This part here is for the 2 upper shelves of your refrigerator
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 21, 2011 | Frigidaire FRS3R5EMB Side by Side...
How to get glass out of shelves for cleaning
most shelves have the glass attached to the side brackets,, empty the shelf, and at the back of the fridge,, you'll see slotted rails that go top to bottom,, tap the shelf bracket upwards and it should come right out,, be careful,, once off the glass may come out too,,
Jun 13, 2011 | Refrigerators
GSS25LGMCC Side-by-Side. On left freezer side, foam filled walls have contracted and top two wire shelves can no longer rest of molded side supports and fall. Need shelves about 1/2" wider
never heard of that happening,are you sure you're not missing a support that the shelf slides on or you have the wrong shelf for that spot.i'm sure you tried the shelves in all the slots,if the wall did push out like you say the only thing i can suggest is to buy another support and get longer screws and put the screw through both supports and hang them like a single support to make up the what caused this to happen,is the freezer staying cold?if you give a parts store your model number they will sell you the same shelves that you have.
Apr 30, 2011 | GE GSS25LGM Side by Side Refrigerator
Er FF. Have replacement fan. How to access
Unplug the refrigerator from power. Remove the rear cover in the freezer. You may have to remove shelf brackets or the ice maker. Pull the rear cover forward and out of the way and disconnect the wire harness to the fan. Should be 2 screws holding the fan bracket in place. Remove these screws and pull the fan assembly out. You now have access to fan.
Feb 20, 2010 | LG LRSC-26922 Side by Side Refrigerator
Replacing Defrost Heater and Bracket in Freezer Section of Fridge
I ended up having to remove things in this order: all shelves, ice maker insert, ice maker top ice tray, ice maker lower motor housing, shelving support rails (2), rear evaporator coil cover. This exposed the evaporator coils (which were already dry since the fridge had been off for two days) and most importantly, the defrost heater element below the coils. The heater element was easily unplugged from it's two connectors. I tested the unit with an ohm meter and it indicated it was open (infinity resistance). I then knew it was bad. I replaced it with a new unit and put everything back together in reverse order taking care to use the same screws. The fridge appears to be back in working order.
Oct 18, 2009 | GE Refrigerators
Freezer Shelves are too small for freezer and keep falling when I put food on them...
I did the tubing solution others mentionedand it worked great.. instead of the 1/2" OD 1/4" ID reinforced tubing. I bought Polyethylene tubing at 3/8" OD, 1/4" ID.
Cut the tubing into lengths that will fit between the rails, split with a utility knife down the whole length. Use a screw driver to force open the end and slip the tubing over the rail.
Pic attached shows the tubing cut along side and forced on to the rail along with a pic of the tag that was on the tubing in an inset. I bought a 25' roll because i was in a hurry and not paying attention. I did 2 shelves, needed something under 1' per side per shelf. so I used 4' total for the whole project.
Jan 20, 2009 | Refrigerators
Shelves that wont stay
I had the same problem. With the basket install empty I notice there was about ¼" gap from the bar the far most side of the side rail. SO I removed the left side rail and found a peice of laminate flooring and cut it to the same size of the the bracket (also predrill the holes so the screw holes match up). I had to buy 3 new screws that were ½" longer the orginal. I reassembled the wood and rail bracket . I then slid the basket in the rail, then started the load the backet up with frozen items. It works perfectly. The basket does not fall any more! Total cost... 3 screws ($0.15).
Nov 18, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
