Question about Toshiba Tosvert 130g2 Transistor Inverter
Toshiba Transistor 130G2 OCA error
How can I rectify the OCA error on my Toshiba Transistor 130G2? Step by step if possible. If there's a short somewhere where should I start? Not sure if it ever ran, but this is the error that it keeps giving.
  • 512 Answers
Basically it is telling you that the inverter is bad. You can disconnect the output so there is only the power going to the inverter and see if it will come on with a no load situation but if it still fails, there is no fix other than to send it back to manufacturer.
Try this as your one and only "maybe":
Reset is press CLR and WRT at same time (I think).
Page 7-7 and 7-8
http://www.toshiba.com/ind/data/tag_files/G2%20Manual_559.pdf
Posted on Nov 06, 2012
How to reset coad c413 toshiba studio 2007
Step 1:- Switch off the machine
Step 2:- Press 0 & 8 and switch on the machine.
Step 3:- Now the machine comes to service mode.
Step 4:- Now press 2002 and then start button
Step 5:- See the current error value and change to 0.
Step 6:- Press ok .
Step 7:- Switch off and on to check if problem is solved .
Step 8:- if still you get c413 errror,you may have to remove the fuser unit and physically check for heater lamp broken, or thermistor abnormality, and corresponding connectors.
Mar 05, 2016 | Toshiba Office Equipment & Supplies
Toshiba e studio2007 error coad c413 how to reset coad
Step 6:- Press ok .
Mar 04, 2016 | Toshiba Office Equipment & Supplies
Control will not run motor
Power is present where circuit board is at, but motor does not run.
Nov 06, 2013 | Toshiba Tosvert 130g2 Transistor Inverter
I turn the power on push the ctrl button and push start, The unit turns on ready to start but does not start
Try reset first, If that does not resolve it, suspect the start switch as the culprit. You might be able to clean the contact surfaces with contact cleaner and rapid cycling of the switch.
Dec 28, 2011 | Toshiba Tosvert 130g2 Transistor Inverter
When run comand is enable I get an error OC1. I disconnected the load and still get the same error. The inverter has been working fine for the last three years
Overcurrent on acceleration is what the code is supposed to be. There may be a capacitor failing in the finals of the output stage, or a resistor has shifted value..
Sep 04, 2011 | Toshiba Tosvert 130g2 Transistor Inverter
How can i troubleshoot a transistor?
A transistor is a switching device. You can connect it with a bulb using wires and a power suppy along. You also need to be more specific as to what type of transitor do u have. as most of them have different characteristics.
May 13, 2010 | Toshiba Tosvert 130g2 Transistor Inverter
NO PICTURE
the tv is fault, there is a lekage to ground, cause 5 amps is avery high current. plse take your tv to a w/shop and have the following checked
i rectifier diodes
ii power transistor, driver transistors, diodes, zener diodes
iii fusable resistors near the power transistor
iv making sure that a 90-110volts is getting out of the power supply to a line transistor, near the line trasformer.
the problem will be over
Mar 23, 2009 | Toshiba CZ32V51 32" TV
Toshiba Tosvert 130g2 Transistor Inverter Logo
351 people viewed this question
Top Toshiba Electronics - Others Experts
Willem.
Willem.
Steve
michael auza
Level 1 Expert
Are you a Toshiba Electronics - Other Expert? Answer questions, earn points and help others
