Question about Peavey Valveking Vk100 Guitar Head
Peavey Valveking head strange feedback.
The thing is that when I am playing even at a low volume, suddenly something like a sound punches in, and a strange feedback o like a train sound starts to sound on the amp. The thing is that when it enters into this status, if you either slap (of course no hard) the head, the cab, even the cable, it will sound on the speakers. If anyone else has this same problem or a solution please help, even though ill go fix it soon if it starts getting worse. Ps: I haven't played yet at loud volumes like rehersals and it only has had been used like 15 times.
  • Juanjo Ortiz
    Juanjo Ortiz May 06, 2013
    I had the exact same problem, and it wasn't the tubes. The technician I took it with told me that the welding was cheap and didn't supported the tube's heat, so he had tu re-weld with a more resistant material, he did with silver welding, it was $30.
    Good luck.
    Novelist:
    Champion:
  • 225 Answers
Sounds like one of your tubes going bad and becoming microphonic...
Google "Microphonic Tube" for additional info.
Posted on Nov 01, 2012
  • 5603 Answers
SOURCE: Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
Posted on Sep 22, 2009
  • 52 Answers
SOURCE: Wires to main speaker are, Yellow & Blue
Yellow should be the positive. Try plugging in and reversing. The louder of the two is the one in phase and the correct wiring. If the speaker is pushing out when playing , it is in phase and correct also.
The distortion problem could be a speaker going out. It may not be totally blown, but may be verging.
Holding your hand out as wide as you can push against the speaker lightly. If there is a rubbing or scratching sound, the speaker could be damaged.If it moves freely, and there is no scratching its okay.
Another possibility is the clean channel may have a channel volume set to high. Make sure the clean channel volume is set lower than the master volume otherwise you can get distortion on that channel too.
Good Luck.
Posted on Feb 21, 2011
  • 5603 Answers
SOURCE: i have a peavey valvenmaster head that was playing
You start by downloading the schematic here:
http://elektrotanya.com/peavey_valveking_100_212.pdf/download.html
Scroll down to the link "Get Manual" and download the schematic. Note that it has several pages of parts list preceeding the schematic.
Next, put a 150 Watt incandescent bulb in series with the power cord to act as a current limiting fuse. Now replace the fuse and proceed with testing. You may find that one or more filter caps have shorted. Also pay particular attention the the BIAS power supply. You should see about -35 to -40 volts. Note that the series lamp will come on if excess current is being drawn and voltages will be low if the lamp lights. If the BIAS supply has failed, it is possible your power tubes have been damaged.
Posted on Mar 31, 2011
  • 5603 Answers
SOURCE: Peavey Audition 110 Combo: When
The problem is LIKELY a broken solder joint right at where the leads of the volume pot come through the circuit board. The broken joint will ozidize overnight and then when vibration rattles it it will punch through the oxide. INSPECT all solder for the pot leads. Lood for a TINY grey line in the menicus of the solder where the lead comes through the board.
Posted on May 10, 2011
  • 5603 Answers
SOURCE: I Have A Peavey Valveking
The answer all depends on the impedance of your speaker(s). A single speaker can be plugged into either jack. Set the switch to the impedance of your speaker. If you use two speakers, set the switch to one half of the impedance of the lowest impedance speaker. Very few speakers are 16 ohm types. Most are 8 ohms and some are 4 ohms. You could plug an 8 ohm into each of the jacks and set the switch to 4 ohms for example.
Posted on May 28, 2011
I have a peavey VIP2 amp.Can I use my acoustic/electric guitar in the electric guitar setting
You can not only play it on electric guitar setting, you can play it LOUD. Its all about what YOU do and what YOU like. Dont accept it when somebody tells you that the music you're playing doesnt sound good to them. ITS YOUR MUSIC !
Do whatever you want. And NO it wont hurt guitar or amp. Rock on or whatever it is you do.
Oct 26, 2015 | Peavey Vypyr VIP 2 40W Modeling Combo...
Peavey problems
Numerous possible issues with your description. I would start with the tubes, and check if not one or more has faulted.
Jul 19, 2014 | Peavey Valveking 112 - Tube Guitar...
My reverb on my valveking head 100w is not working
first change tube 12at
if not help check the tank reberb (one spring is broken)
Jun 14, 2014 | Peavey ValveKing 100w All Tube Head Guitar...
No Power after Valves glowed bright
This could be a transformer failure. Take it to the repairs shop.
Jun 08, 2013 | Peavey Valveking Vk100 Guitar Head
HOW TO REPLACE BLOWN FUSE PEAVEY VAVALE KING 100 HEAD
Contact Peavey toll free at 877-732-8391 or by email at customerservice@peavey.com,
Jan 26, 2013 | Peavey Valveking Vk100 Guitar Head
Peavey speakers making no sound
Try connecting them to another amplifier...you can use the speaker output of a guitar amp as a quick test. If the amp (and mixer) check OK, it sounds like you are about to become good friends with your local speaker reconing shop.
Remember...Distorted Audio Can Kill Speakers even at low volumes. It happens because sine waves become square waves. Google it for additional information.
Oct 24, 2012 | Peavey PR15 400w PA Speakers
What ohm selection and which input do i use on peavey valveking head/ca
that depends on your cabinet(s). if you have an 8 ohm cabinet you want to use your 8 ohm out. if its a 16 ohm cabinet you want the 16 ohm out.. etc.. etc. etc.. owners manuals will tell you these specs
Aug 31, 2011 | Peavey Valveking Head
I Have A Peavey Valveking head and cab. I was wondering what inputs for the OHMS to put it on if i were to be playing in a band. 4, 8, or 16? and what input do i plug the speaker cable into on the cab, the...
May 28, 2011 | Peavey Valveking Head
I have a peavey valvenmaster head that was playing at very low volumes even when cranked up pretty loudly. i replaced all of the tubes with new matched groove tubes and the volume and tone improved. ...
Mar 31, 2011 | Peavey ValveKing 100w All Tube 212 Combo...
I have a peavey supreme xl head thats... well... OOOOLD. at one point i got SUPER pissed and kicked it across the room, causing one of the speaker ouput jacks to fall out. I put it back in and, for a...
Open the unit and inspect for damage and repair as necessary. It does no good to just look at it. Likely something has fallen into the speaker and damage could be worsened if you don't repair it before trying to use it,
Feb 11, 2010 | Peavey Music
Peavey Valveking Vk100 Guitar Head Logo
198 people viewed this question
Top Peavey Music Experts
Ben Armstrong
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
