Modem settings error - Computers & Internet
720 error remote computer not established , correct settings ,so please tell me answer
Posted on Sep 08, 2013
I changed my internet modem and am not using the router I had been using. I have attempted to access Netflix and get error unable to connect to the internet.
Judit,
We need ore information. Does the new modem you are now using have a built in "router"? If not, you had better reinstall your old router as when you just use a plain old modem from either cable or dsl your computer will be visible to the "low life hackers" out in the internet and it will be so easy to gain access to your computer and files it will and should scare you! Are you now using a router with your new modem? IF NOT, reinstall your old router with your new modem! The reason your not getting Netflix could be that the port settings on your old router will not be the same as the modem and if your new modem does have a built in router, you will need to "reconfigure" your Netflix with the new modem/router. The ports that your old router allowed access to Netflix will not be the same in the new router. You need to set this up yourself. Good luck.
Mar 22, 2015 | Miscellaneous
My comp.says network error,thomson tg585v8,i cant access my comp.
Check your network settings
Start, control panel, networking and sharing center. Click on your connection, properties. Click on TCP/IPv4 and TCP/IPv6 and click on properties. Make sure the settings say to obtain IP address automatically and also for DNS, then reboot the modem and computer.
You did not specify if you are using a router.
Jan 29, 2013 | RCA Thomson Digital Cable Modem (DCM305R)
Verifone Vx570 given an error Modem Profile Not Set?
error modem profile not set appears when your Verifone VX 570 modem profile is not properly loaded or has been errased due to Tamper error or Bad RTC. Reloading back the modem profile will sometimes fix the error, but there is also a chance that your I/O module (form where you connect the power and telephone wire) is also bad, thats needs to be repaired or replaced. Call (775)358-2922 ask for Randy. Thanks.
Backside of the I/O module of VX 570
Jan 18, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
I am using zte usb modem FFF1 for internet access via reliance netconnect.whenever I connect the device to laptop it is shown as storage device but as soon as i install the driver software a driver not...
The ZTE modem when initially connected to any system loads as a storage device which contains the software necessary to install the modem. Connect the ZTE and open it in Explorer. Double click the setup file (.exe) to start installation. Follow instructions and allow installation to complete. The modem is automatically installed during this setup. Once completed restart and then your ZTE functions as a modem.
May 19, 2010 | Computers & Internet
Error 638 while connecting through modem on
Sir, error description is of "The request has timed out".
First, Try once by restarting the system
http://www.modemsite.com/56k/duns6xx.asp
Second, You can try diagnosing the modem if the diagnosis results some text. Then modem should be working. Else, check for proper cabling.
To diagnose modem
1.Click “Start” then “Settings > Control Panel” or “Control Panel”.
2.In Control Panel select the “Phone and Modem Options” icon.
3.Select the “Modems” tab in the top middle, of the new window that opens..
4.Then on the next screen select the “Properties” button in the lower right.
5.You should now select the “Diagnostic” tab in the top of the new window..
6.Then click on the “Query Modem” button in the middle of the window
Lastly, try unstalling an installing & reinstalling the modem driver
Hope this helps
May 19, 2010 | Microsoft Windows Vista Home Premium...
Error in installing modem driver
do this...
START.. SETTINGS ..CTRL PANEL...TEL/MODEM .. ADD new modem, but tick the box "I will select modem from a list"
Use STANDARD MODEM.....56000 and press OK
If the modem is connected correctly to a phone line it should be able to dial out.... Don't select your modem driver at all
Please rate my help++++Thanks for using FIXYA
Feb 27, 2010 | D-Link DSL 200 (DSL-200) Modem
Is there a chance that settings in the modem will keep some programs not to work ( Connect)?
Although it is difficult to say for "ALL" programs.
Keep in mind for windows machines the operating system uses the one modem connection for ALL applications.
Slim to no chance a modem setting will cause one program to not connect and the others will. They are all sharing the same modem and settings.
Now if the machine is slow and the application takes awhile to load.
This could cause the time out no connection error message.
Hope this helps!
Oct 04, 2009 | Arris Computers & Internet
Cannot get SBG900 MODEM TO CONNECT TO INTERNET
I can not connect to DSL using Cable One for provider and having a few problems with the wireless connection.I am using HP Pavilion.
Dec 30, 2008 | Arris SURFboard SBG900 (49402201900) Modem
No access to set up modem or router
you might have configured your lan settings wrongly.
If your modem was setup for DHCP then you configure your lan to receive IP address automatically, DNS automatically.
If DHCP is disabled on the modem, you have to USE static IP Address for your lan ip and default gateway should be your modem default ip.
the default IP for modem is usually 192.168.1.1
if DHCP is disabled on the modem the sys ip is 192.168.1.3
So Configure your LAN setting as follow and Type http://192.168.1.1 in the address url.
Lan Settings:
IP Address: 192.168.1.3
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1
click ok.
and type the above url, press enter the modem will ask you for username and password.
Good Luck.
Dec 27, 2007 | D-Link DSL 300G+ (DSL-300G+) Modem
Error message during installation of SBG 900
Please check if your modem and change the config to static IP.
Regards
Sep 03, 2007 | Arris SURFboard SBG900 (49402201900) Modem
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
