Question about Dryers
MY DRYER WILL RUN FOR 5 MINUTES AND THEN TRIP CIRCUIT BREAKER. .....WHEN NO HEAT SETTING IS USED IT WILL RUN FOREVER......i CHECKED THE HEATING ELEMENT AND IT APPEARS TO BE FINE
  • 91 Answers
Make sure that there is nothing hitting the fuse or thermostats like a penny or change ,,,
Posted on Jan 03, 2009
Why does the circuit breaker keep tripping?
Need more information is it dryer,stove,ac ,heat, water heater,bathroom plug, garage plug ,outside plug, other
Lighting circuit with plugs
Oct 19, 2016 | Dryers
Breaker trips after bout 5 minutes
Breakers trip because of heat.
When heat from wire exceeds breaker rating, it trips.
Something is causing heat on the wire, wire is too small for the amp draw, there is short circuit, or breaker is bad.
Replace breaker and/or test wire.
Put amp-meter on wire and read amp draw through wire.
Amps cause heat. That's why high voltage lines from power station are high-volt-low-amp so there is no heat loss with long distance transmission, until transformer at home converts electricity to lower volts and high working amps with enough power to run electrical devices.
Same is true for AC and DC circuits.
If amp reading on wire exceeds rating on breaker for length of time, then breaker will trip.
The fact that the breaker lets current (amps) to flow for a period of time before tripping is because the breaker is probably rated for slow-acting, or it takes a while for amp draw to heat the wire.
Following image shows amp-meter that clips over wire to get amp reading.
http://waterheatertimer.org/pdf/Which-is-best-gas-water-heater.pdf
Oct 31, 2012 | Electrical Supplies
BREAKER TRIP AFTER 8 MINS .WORKED ONLY ON PERMANENT PRESS FOR A YR NORMAL ..WOULD TRIP BREAKER ON LOW AND HEAVY SETTING AFTER 5 MINS CYCLE.
This problem might be in your house electrical system rather than the dryer but it will take some troubleshooting to figure it out.
1. First make sure that you are connected to a 30 amp circuit breaker. If not then that is the problem!
2. Use a clamp on amp meter to see what the dryer is drawing from your electrical panel before it trips. If it is below the rating of the 30 amp circuit breaker when it trips, then your circuit breaker is defective.
3. If the dryer is drawing more than 30 amps it is in your machine and you will need to troubshoot that. Since you stated the times - is it always the same and does not vary? Then you have to figure out what you dryer is doing at the 8 minute mark and each machine is a little different. Soem machines go into a tumble air only mode for the first few minutes before kicking on the heating elecment. If yours is that was then it is the heating element, thermostat or something to do with the heating circuit.
Jun 20, 2011 | Dryers
My dryer still runs but does not heat up (just blows cold air), any idea how to fix? Will it be a thermostat or the heater element itself?
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Jan 04, 2011 | Whirlpool AWZ7303 Electric Dryer
My Maytag Bravo Steam Dryer runs for about 5 minutes and gets hot and then kicks the breaker in the breaker box. HELP!!
Hello there:
It blows fuses or trips the circuit breaker Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:It could be also wired backwardes so make sure to have this checked'
If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician. If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box.
May 21, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryer runs but does not get hot to dry clothes
Hello there:
There are a couple of things to check if the dryer does not heat properly
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Feb 27, 2010 | Dryers
Dryer stopped heating. Runs fine but no heat all of a sudden.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to
Jan 05, 2010 | Whirlpool Dryers
It runs but won't heat up.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Maytag Dryers
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
Apr 09, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
CIRCUIT BREAKER TRIPS AFTER 5 MINUTES RUNNING.......WHEN I RUN WITH NO HEAT SETTING IT WILL RUN FOREVER......I PULLED THE HEATING ELEMENT AND IT "APPEARS" TO BE FINE.
Hello dale210mile,
Based on your problem description, it is possible that your circuit breaker itself is on its way out.. ( they do go bad sometimes) but before going that route, I would make sure that ALL wiring connections are tight ( meaning shut off the circuit breaker and make sure every electrcial tie point is snug and that you don't have a 'high impedance junction' somewhere in the power feed to the dryer. When you say the heating element 'appears' fine.. not sure what that means exactly but depending on the model.. you should be able to measure its cold resistance with an ohm meter and it should fall within manufactures spec.. A visual check of the heating element really won't tell you much unless it has shorted and you see a burn mark on it.. The mere fact that it runs OK for 5 minutes and then trips the breaker leads me to beleive that it may not be ok..but it is important to rule out the other hardware ( wire terminations etc) before going that route. One test you can try.. if after you've checked all the wiring etc..try running the dryer with no laundry in it .. ( just to verify that the additional load that the motor adds to the entire current draw isn't taking it over the top...) Hope these suggestions help you zero in on the solution..
Good Luck
Rick
Jan 03, 2009 | Whirlpool Dryers
Open Questions:
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
