Question about Beverage-Air Beverage Air DW49-S Horizontal Bottle Cooler
Beverage air deep well bottle cooler smells - Beverage-Air Beverage Air DW49-S Horizontal Bottle Cooler
SolutionGuy
  • 331 Answers
SOURCE: bev air cooler
Bill, the main reason I've noticed for higher than normal temps in these boxes is filthy condenser coils (this will affect pressures in your sealed system). Remove the front lower panel and inspect your coils. Use a coil brush or a dust broom to thoroughly clean them up, don't use water. You can also pick up some condenser coil cleaner in a spray can from your local appliance parts store, but it's not necessary (the fumes are strong and may be objectionable to your customers... it gets 'em really clean, though!) After cleaning the coils, allow 24 hours for temps to stabilize. If they don't, here is a site for Beverage-Air, contact your local servicer with you exact model and serial number for pressure specifications. http://www.beverage-air.com/technical.service.html Hope this helps! Let us know, will ya?
Posted on Aug 13, 2007
SOURCE: DRIPPING OLD BEVERAGE AIR FAUCET
I have a beverage aire counter top size. It works but it does not get cold. I am looking for a place to repair it here in killeen texas. I called alot of the local repair and they don't repair it. Thank-You
Nora Long
Posted on Feb 12, 2008
  • 1037 Answers
SOURCE: Beverage air cycling off/on
not sure what you mean by "Continually"? Unit should cycle off when set temp is reached. If it is cycling otherwise, may be an issue with the compressor running hot or high amperage.
Posted on Jul 11, 2010
derrickbohan
  • 90 Answers
SOURCE: My beverage air MT45 is
bad thermostat sound like its not shutting off.
Posted on Dec 17, 2010
aaronbeth
  • 110 Answers
SOURCE: I have a Beverage Air
You'll need to check the back-pressure on the low-side of the system, you have a faulty compressor. If there is a condenser fan motor make sure it is running when the compressor is on.
Posted on Jan 28, 2011
How do you change a evaperater fan on a Beverage air bottle cooler?
Its a pain but reach down in there and pull the screws out and remove the panels. Its in there honest! Hope this helps good luck.
Jul 12, 2014 | True TD-50-18 Beverage Cooler
Sparks coming from compressor, smells like burnt rubber
Sounds like the wiring has shorted that connects to the compressor. Shut the power off and remove the cover to the compressor terminals. You should see what you are looking for.
Feb 26, 2014 | Beverage-Air MT27 Beverage Cooler...
Beverage-air DW freezes
Try turning thermostat knob all the way to left or counter clockwise. This should shut the compressor off. If the compressor continues to run the thermostat is stuck closed & bad. If the compressor remains off with thermostat turned all the way to the left try turning it slightly to the right (warmest setting). See if it stops freezing. If it continues to freeze set at warmest setting replace the thermostat. Try pricing a thermostat out at Refrigeration Hardware. Link attached. Refrigeration Hardware Supply
Oct 05, 2013 | Beverage Air Refrigeration Deep Well...
Beverage cooler making noise
There are small fans that they incorporate in those. If you can get to it put a drop of 3 in 1 oil on each end of the motor.Some of those little bottles of oil have a telescoping straw like piece that extends out a couple inches.
Feb 15, 2013 | Refrigerators
I need the Haier 18 bottle wine cooler instruction manual.
Hi There,
I was able to find two 18 bottle wine coolers on the Haier site.
The first is model number HVTM18DABB
http://www.haieramerica.com/wine-beer-beverage/wine-cellars/hvtm18dabb
The second is model number HVTSM18DABB
http://www.haieramerica.com/wine-beer-beverage/wine-cellars/hvtsm18dabb
On either product page the manual can be downloaded from the "product support & downloads" tab
Have a great day!
Jul 18, 2012 | Refrigerators
Hi My Kelvinator Beverage Cooler fridge has packed up due to power surge. If possible please could you email me a quotation as i need to purchase another one. Description: 1 door which is glass and its...
Hi.
The price depends on the model and on the internal volume. Here a UK seller: Commercial Beverage Coolers & Commercial Bottle Coolers. Here a SA distributor of beverage coolers. The choice includes Kelvinator.
About the fault. If the problem happened after a power surge it is often possible to repair the cooler replacing the starter relay mounted on top of the compressor. The part is not expensive. Call the Kelvinator number listed on the owner manual to know more about the possible repair or to purchase the part.
Regards.
Ginko
Sep 13, 2011 | Kelvinator Refrigerators
Clogged drain in a beverage aire mod# dw49
I like to use compressed air, sometimes a wire may work to clear the drain line. It will require some dissassembly of the unit to gain good access to the drain. Clean everything once dissassembled, it will save you trouble later. Hope this helps.
Dec 24, 2008 | Beverage-Air Beverage Air DW49-S...
Looking for age on Beverage Air Horizontal Bottle Cooler
Call Beverage-Air and provide both model and serial # to the parts department and they should be able to identify the year the unit was manufactured - 800-845-9800
Matt - coolergaskets.com
Dec 09, 2008 | Beverage-Air Beverage Air DW49-S...
Cooler`s Spare Parts
Coca Cola does not manufacture these coolers. They are manufactured by another company for Coca Cola. Model number MT45 is a "Beverage Air" product.
Some parts for these units can be ordered through a company called "Case Parts" that are on the internet.
Jul 30, 2008 | Beverage-Air Refrigerators
Refrigerators Logo
18 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
