Question about Panasonic Televison & Video
Lightning affected Lcd tv
Hi.I have panasonic LCD 32lnch Mod.Tx-32LXD7oA,the tv now has no life due to a bad lightning strike/power surge,I cannot see any burnt boards or blown fuses not even a standby light,my question is a repair possible and will it have a long and reliable life span regards Bob Sydney Australia.
Panasonic 32"LCD Mod,TX32LXD70A
Posted on Jan 03, 2009
Plasma Panasonic TV stopped working
Lightning-damaged electronics are a gamble to repair. Sometimes the problem is a single component, but more often multiple components are damaged, and even if you get it working, something else may die shortly thereafter. If you are lucky, only one board was damaged. My recommendation, if you have homeowner's or renter's insurance, is to put in a claim for the TV and get it replaced.
Having put forth that caveat, the blinking red LED hints that you may have enough left of the set for it to be repairable, especially given that much of a plasma set is already built to cope with high voltages. Try downloading a service manual and following the troubleshooting procedure. Here's the link (it's a Hungarian site, but there's enough English available to find things):
Service manual eprom result list ElektroTanya Service manuals and repair...
Jun 26, 2015 | Panasonic TH-50PZ850U TV
Is the module of lg tv 32ld330-mb affected when theres a lighting strike???is there a chance to be fix??
The damage from a lightning strike tends to be random. Sometimes it's minor, and only a few parts are affected. Other times, many parts are ruined, or destined to fail soon as a result of the current surge.
If the strike came over the power line, the input surge protectors in the power supply should be replaced, even if they look good. It would be prudent to replace the entire power supply. If you had the set plugged into an external surge protector, that should have taken most of the hit and should also be replaced. (Some surge protector manufacturers will pay up to a certain amount for repair or replacement of equipment plugged into their products if it is damaged by lightning.)
If the lightning came over an unprotected input cable, fixing the set would be a gamble. You could end up changing a lot of modules, beginning with the main board.
Jan 30, 2015 | LG Televison & Video
MY SANYO LCD TV MODEL 24 K 50 WAS OFF WHEN LIGHTNING STRUCK NEAR OUR HOUSE AND SINCE THEN IT DOES NOT TURN ON
Replace or have the powrer supply tested and eventually serviced.
Lightning strikes affect two types of boards in televisions - the power supply by means of entering through the AC line and main boards by means of entering from the external signal sources. External antennas are worst and can totally toast the main board whereas a signal entering through HDMI cable from another device is less likely to be affected by a power surge.
So naturally you start your quest with the power board , which is the usual suspect.
As of right now I do not believe we have an announced service for the power supply board of Sanyo LCD-24K50, but if you do not have any other options you can always try and send the power board for examination/repair through
http://www.coppelltvrepair.com/newservice.
Sep 29, 2013 | Sanyo 42 in. LCD TV
Power supply failed due to lightning srike.
Hi
The first parst affected by the lightning strike are the reservoir capacitor, a big cylindrical component in the high voltage section of the tv, which normally blows up, opening the top cap, and the NTC. Please, check these components and replace the damaged ones.
Sully
Sep 28, 2013 | Televison & Video
Does Panasonic TX-37LX80M 32" Widescreen LCD Multi-System HDTV with HDMI come with a safety gear which blocks the lightning from striking the television?
Please understand, that a lightning will have trillions of volts, when it hit the earth. Do you thing any material or circuit made by a human being can withstand it? All are only mere saying. Not the truth.
Jul 12, 2013 | Televison & Video
Power surge caused by lightning strike, TV is dead, any Thoughtd/ does this damage every components?
Lightning can cause serious damage. You will surely want to get a professional diagnoses. What is damaged depends on where the surge came in at, and the intensity of the surge. If the surge came in through the power cable, most likely your power supply board has damage. But I have seen situations where the surge came in though an HDMI or coax connection and just take out the main board. But the moral of the story is to get a proper diagnoses, you could have several boards damaged.
Nov 24, 2012 | Astar LTV-2701 27 in. HD-Ready LCD...
Sony Bravia KDL-46S5100 There was a lightning strike and we lost power for a few minutes. When power came back on the only thing we have is a black screen and no sound. Is there something on our tv that...
Your Sony Bravia KDL-46S5100 might have been affected and damaged by the lightning strike. You cannot fix it without the help of qualified technician. It must be brought to your nearest service center.
Nov 03, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Power surge due to lightning strike today. Comp...
Unplug it and then blow a hairdryer at the power supply for 3 minutes. Leave the lid on, just blow the hairdryer at it from the outside. Craziest trick I ever saw.
After that, turn off hibernation. And eventually, replace your power supply.
May 20, 2010 | HP Compaq Presario SR1300NX (PP195AA) PC...
No power (dead after a lightning storm hit the house. Tried replacing the two power circuit boards and have a current going in and all around all circuit boards. Still no sign of life when plugged in...
If its after a lightning storm, it really could be anything. Your mainboard could quite possibly be shot. In fact almost anything in the TV could be damaged by a big surge. It could even be that your backlights went out from the surge too.
Does your power LED come on? What is it connected to? Directly to the power board or is it connected to the mainboard? If you have current through all the circuit boards, you may have a burnt tuner or chip on the mainboard.
Might not be worth fixing depending on the size/model. If its a big LCD, you could probably get a good deal on a working one of the same size with a broken LCD panel (~$100). Then you can just replace the broken LCD panel with yours and you have a fixed TV.
Aug 15, 2009 | Panasonic Televison & Video
19 in blue screen only sound works great
un plug the tv for 3 minutes to reset it, then plug it back in. if this dont fix it, please get back with me and tell me if you had any power outtages or surges. some times lightning strikes can burn out the tuner when it strikes the cable line.
Oct 19, 2007 | Westinghouse LTV-19W3 19 in. LCD...
Televison & Video Logo
468 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
