The garage door has a buckle in it it's not going straight up-and-down I'm not sure what the problem is. It rolls up and down fine but it's not straight up-and-down
  • 7 Answers
Rick
I was trying to see in the video just what you were talking about it not being straight up and down. i think you may be refering about the top panel of the door. If that is the case the top left and right rollers may have to be ajusted down a inch or two. This is only the case if the door is all the way down to the floor.
Posted on Oct 25, 2012
Previpus owner didnt supply 4 digit cide to sears garage door opener keypad
Simply call a local garage door service center and take your keypad into them and they will be happy to show you how you can do it. It usually involves having to push a button up on the back of the garage door closing unit so the device can pick up what is a "rolling code" instruction and the unit will work just fine for you. Just remove it and be sure to know the model number of the opener too before you go.
Dec 20, 2013 | Building Materials
How to program a garage door
You have a rolling code system.Rolling code program requires you push a learn /program button on the GDO reciever at your home. Its located on your garage door reciever under the light cover. on you garage door unit. Use the garage door manufacture instruction to program the learn to recieve and accept home system for the garage door opener in your car
Mar 02, 2012 | Cars & Trucks
My Craftsman 1/2 Hp garage door opener doesn't stop going down despite (quite forcefully!) applying pressure in the opposite direction. It would buckle (and did) if I don't let it continue unhindered...do...
YOU NEED TO ADJUST THE DOWN FORCE.
YOU WANT TO TURN IT COUNTER CLOCKWISE TO THE STOP (THIS ADJUSTMENT IS ONLY ABOUT 3/4 TURN FROM MIN. TO MAX.). THEN TRY THE DOOR IF IT REVERSES TURN IT ABOUT 1/16TH TURN CLOCKWISE. CONTINUE THIS VERY MINOR INCRAMENT ADJUSTMENT UNTIL THE DOOR CLOSES WITHOUT REVERSING. THEN GO 1/16TH TURN FURTHER.
YOU SHOULD BE ABLE TO STOP THE DOOR AND REVERSE IT BY GRABBING THE BOTTOM OF THE DOOR AS IT GOES DOWN AND LIFTING SLIGHTLY. IF YOU CAN'T GET THE DOOR TO BOTH CLOSE AND REVERSE WITH MODERATE PRESSURE YOU MAY NEED ADJUSTMENT TO THE DOOR / SPRING / ETC.
- I DO NOT RECOMMEND ADJUSTING THE DOOR YOURSELF - CALL IN A PRO FOR THAT.
IF THE ADJUSTMENT IS SUCCESFUL ADJUST THE OPEN SENSITIVITY / FORCE IN THE SAME MANNER.
HOPE THIS HELPS
Jun 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Car windows will not roll down. garage door opener does not work.
I DON'T KNOW ABOUT THE WINDOW PROBLEM - SOUNDS LIKE A FUSE.
FOR THE DOOR OPENER GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
PLEASE NOTE: NOT ALL BRANDS/MODELS OF OPENER WILL WORK WITH THIS SYSTEM.
HOPE THIS HELPS
Apr 16, 2009 | 2006 Lincoln Zephyr
Craftsman Garage Door Opener Can't Use Multiple Remotes!
THE UNIT CAN WORK WITH EITHER ROLLING CODE OR NON ROLLING CODE, NOT BOTH.
I WOULD GUESS THE CLICKER IS NOT ROLLING CODE.
I HAVE NEVER HAD GOOD LUCK WITH THE CLICKER REMOTES - GO AND GET ANOTHER REAL REMOTE - THE SAME SERIES AS THE ORIGIONAL.
GET A REFUND ON THE CLICKER - OR HAVE IT BRONZED FOR THE MANTEL.
HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Gaarage Door
Have you looked on both sides of the door at the bottom there should be cables. If they are not tight you probably have a damaged spring. Look up between the door and where the roller mounts are, there should be a tightly wound spring. This is what keeps the door up, if tension is lost then it will come back down. If it is broken it needs professional attention.
Jan 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Opening theGarage door manually
two problems. why aren't inner and outter trolley connecting. did you leave rope is disconnect position. Second problem is door springs do not seem balanced. you should be able to lift door halve way up and let go. it should pretty much stay there; go up or down slowly ok. fly up or crash down; need to adjust springs/cables or maybe wrong springs.
Computers & Internet Logo
186 people viewed this question
David Payne
David Payne
