Question about Janome Memory Craft 9000 Computerized Sewing Machine
When I turned on my MC 8000 and stared sewing it was stitching fine but very slow. I tried cleaning the bobbin and resetting the machine but it is still slow.
  • Janome Master
  • 1,564 Answers
Time for servicing... (Lube, oil, adjust) $$$
Posted on Nov 06, 2012
  • 84 Answers
SOURCE: The bobbin grinds when I start to so
Sounds like a bobbin case related problem. Unplug the machine, then remove the needle plate to get access to the black bobbin case. Inspect the underside of it  VERY carefully for ANY marks or roughness. You can expect very fine 'scratches', but no chunks or rough bits.Now check the metal rim that the bobbin case sits on is PERFECTLY smooth. particularly look for any tiny burrs on the top or inside edge of the rim, or any sign of a needle hit. Should not be any! If there are, the mechanic shoul fix it at no extra cost cos he missed the problem. Whilst checking the bobbin case, look for ANY marks on the top surface of it. The SLIGHTEST mark WILL upset the sewing.
Hope this assists!
Posted on Oct 22, 2007
bargainbox
  • 1388 Answers
SOURCE: Janome MC 9000 Embroidery/Sewing Machine
This is the diagnistics routine for Janome 9000.
Run each test in sequence from 1 - 13, or until you find error
The results of this may not be what you want to hear, and may be why no-one has yet replied....I hope for an easy resolution for you
If you are having trouble reading this here, simply send a request via the "contact us" page on:
www.bargainbox.com.au
Martyn
Posted on Feb 16, 2008
bargainbox
  • 1388 Answers
SOURCE: bobbin thread bunching
I agree with brodering about the damage to your bobbin case, it should be smooth all over, as the thread travels across the top surface to form a stitch, and the small step on the underside locates it as the hook spins underneath.
Needle strikes often compromise the surface, as will the hook colliding with the under surface... and although it is possible to gently polish off the damage with fine grain wet & dry (black) sand paper (emery paper) there are limits to the success depending on the degree of damage.
While on the subject, ensure the bobbin case and hook race beneath are clean and free of lint or thread.
For a guide as to setting tensions and the rest, look here
Posted on Feb 24, 2008
  • 323 Answers
SOURCE: Bobbin winding message
Under the top cover, on the right hand side where the bobbin winder is, there is a small switch which is activated when the bobbin is being wound. You will need to remove the cover and reposition the switch (it's located towards the front of the machine) to make it work properly.
sewman7
Posted on Nov 25, 2008
Mongo32
  • 111 Answers
SOURCE: my machine is not stitching
needle in backwards?
Posted on Jun 13, 2009
Memory craft 8000 how do you take it apart to replace light
When your Memory Craft 8000 or MC 5700 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the LCD screen, or buy a new machine.
Janome no longer stock this item direct, but there is an affordable replacement available.
Full Access and Installation instructions are provided, so you can DIY or have someone else do the replacement for you.
Check this Link
Also includes advice, links & contacts to be able to Reset your screen and do a Self Diagnosis Routine to test your machine BEFORE you purchase a replacement LCD backlight for either the Janome MC 8000 or MC 5700, so you can check that there are no other troubles.
Jun 22, 2010 | Janome 8080 Computerized Sewing Machine
The upper tension will not tighten on my Janome MC 8000. I have had it since '93 with no problems and all of a sudden when I was stitching the tension became loose on top (it was looping and making a mess...
Check for lint or thread in the top tension unit.....try "flossing" (as you would teeth) with a clean cloth.
Symptoms indicate top tension is being kept slightly open by debris.
Playing with the screw inside the cover on left of tension unit is not a great idea, it is designed for fine adjustment when tensioner is clean, so try to reset back to what it was before fiddling if you can remember how may turns you made.
If you continue to have problems, send a quick email (please mention the model and issue, we get a LOT of requests) and I shall see what else we can do to get you back on track.
CONTACT email
Jun 05, 2010 | Janome Memory Craft 9000 Computerized...
Sewing slowed and then stopped
If you are unable to move the wheel then something is locking up the mechanism.
Please try removing the bobbin and the bobbin case and try turning the wheel.
If the unit does not jam, try reinserting the bobbin and the bobbin case. You might need to consider replacing the bobbin case if the unit jams again.
If it still jams without the bobbin case in, then the mechanism might be broken and you should bring the unit to be looked at by a brother tech. Brother techs will look at the machine and diagnose the issue free of charge and will only charge you if they have to do any out of warranty repairs.
Thanks,
Pat
May 12, 2010 | Brother CS-80
Sewing machine LCD display not lighting up
Check this Link
Sep 18, 2009 | Janome Sewing Machines
Memory Craft 8000 LCD almost non-useable. Are replacement screens available?Is there any way to repair the display?
Yes, they can be replaced, we have them in stock. But first there are some questions about whether there are also issues with stitch selecting IN ADDITION to the dark screen, to ensure you would actually benefit from the repacement.
To find out, I can send you instructions to Reset the Touchscreen and also how to run the Self Test Routine, simply... Contact me. ALSO... Please just be sure to mention specifically what you need, as we do get quite a number of enquiries of various types each day.
This is a Link to LCD Replacement Screen to suit Janome MC 8000 and Janome MC 5700
Sep 09, 2009 | Sewing Machines
Why is my screen showing the 'bobbin threading' icon??
Perhaps the bobbin winding mechanism is stuck. Probably needs service.
Also, check the bobbin and bobbin case. Perhaps there is some thread stuck or it is not securely threaded through the tensioner.
Mar 31, 2017 | Euro-Pro 9125 Computerized Sewing Machine
Skipping stitches
Rule of thumb: Fast needle, slow hands. This should help. GiGi
Feb 19, 2009 | Janome 1600P-DB Mechanical Sewing Machine
The sewing advisor screen on a Janome 8000 is getting dim.
Check this Link
Jan 26, 2009 | Janome Memory Craft 9000 Computerized...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
155 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
