Question about Max American Terminal 30 i Fuses
How do i know i need a whole new fuse box
I got a new battery and alternator and my car wont start is it the fuse box
  • 625 Answers
You don't mention the year, make and model of the vehicle so, my answer will be as vague as your question.
A gasoline engine needs four things to run: fuel, spark,compression and combustion.
When you turn the key does the starter engage? If no, check for power at both sides of the fuse when turning the key.. If there is no power at the fuse when turning the key, go to the ignition switch. You have isolated your problem.
If there is power at fuse then, go to the starter relay. If there is power going into and, going out of the relay then, check the starter. You have isolated your problem.
If yes, check for fuel, spark (plugs and wires), compression(block, pistons, rods, Intake and gaskets) and combustion (small scale explosion from compressed fuel and spark, thus pushing piston).
Your problem may be with a passive anti-theft system installed by the manufacturer. I wouldn't know because you didn't mention the year, make and model of the vehicle.
Your problem could be with a collision based fuel shut down system installed by the manufacturer but, I wouldn't know because you didn't mention the year, make and model of the vehicle.
Your problem could be with any number of common issues related to a specific vehicle; issues that may been discussed at length on this very site but, I wouldn't know because you didn't mention the year,make and model of the vehicle.
Posted on Oct 26, 2012
Trying to figure out alternator fuse number on 2010 Dodge journey sxt don't see the word alternator on fuse box have new battery and alternator but still goes click click when trying to start it
The alternator fuse has nothing to do with that . If starter solenoid is just clicking an you have a new battery it's more then likely battery cables or connections . To test the starter circuit you need to do voltage drop testing . The alternator doesn't start working till the vehicle starts an is running . Starter Voltage Drop
Oct 02, 2016 | 2010 Dodge Journey SXT
Wont charge, new battery and alternator
Is the battery symbol lit on the instrument cluster ? Check fuses F1.26 30amp in the battery junction box , fuse box near battery in the engine compartment . Also check F2.27 10amp fuse in the central junction box , inside passenger compartment under the dash . It won't charge without voltage on this fuses . Also the heavier gage wire on the back of the alternator should have battery voltage , 175 amp main fuse near battery connection .
Jan 17, 2016 | 2000 Ford Taurus
Audi a4 quattro
don't think fuse diagram will help , is the battery in good condition , may not hold enough charge to turn over engine , try jump start if engine starts then get a new battery then check alternator charge rate as may be reason battery went
Jul 15, 2014 | 1999 Audi A4
1995 dodge intrepid wont start. Battery is fully charge but no power to anything. Car wont start
The alternator would not come into play unless the battery was dead.
Could be corrosion inside one of the battery cables, or a blow maxi fuse for the fuse box. Or a bad ground connection.
You would need to take a meter or test light and check for power at the starter post, and the major fuses.
Dec 22, 2012 | 1995 Dodge Intrepid
Acura tl wont start after changing battery and alternator
check for blowed 80 amp fuse to battery in the battery fuse box.
Sep 11, 2012 | 1996 Acura TL Series
Alternator wont charge battery at all.
an easy way to fInd out how to fIx thIs Is one. wIl tue vehIcle start at all? If It wIll than start the car and carefully take the posItIve cable off the battery and see If the vehIcle dIes. If It does than you need to replace the alternator because the transformer In the alternator Is out. If the vehIcle does not start all the fuse may be In two places. check the fuse In the car at the fuse panel and or the fuse box under the hood.
Feb 23, 2012 | 1989 Nissan Maxima
Put in new alternator 98 ford taurus dohc car will start thn stop
Check ground wire from engine to frame and battery to body
Jul 23, 2010 | 1998 Ford Taurus
2003 jagure x type wont start unless jumped
check alternator . out put . sound like its not charging battery.
Apr 07, 2009 | 2003 Jaguar X-Type
94 Grand Cherokee wont start need help
there is a fuse box under hood, look in there, under the cover of fuse box will be a list that shows you by corresponding numbers, to fuses in fuse box witch one is for what, it will be the same for the fuse box in the car.
Jan 28, 2009 | 1994 Jeep Grand Cherokee
94 Jeep Grand Cherokee will not start
Sounds like the inline fuse popped. It is located in the wire that comes from the alternator to the battery. The alternator is sending out the juice, but it can't make it to the battery. I sincerely hope that this gets you on the road again. Best wishes and God Bless.
Bryon
Jan 27, 2009 | 1994 Jeep Grand Cherokee
Max American Terminal  30 i Fuses  Logo
71 people viewed this question
Top Max Car Audio & Video Experts
Don Malinowski
Don Malinowski
Level 1 Expert
Richard Warren
Richard Warren
Are you a Max Car Audio and Video Expert? Answer questions, earn points and help others
