Question about Miele Touchtronic W1113 Washing Machine
Replace a bearing on a w1113
Manuals and detailed steps required
  • donny Oct 28, 2012
    I need help in order to replace the bearing in my washing machine. Disassembly instructions or a video showing how it's done.
I need the big end torque on the Rocam engine please
A cheap shop manual will have this and much more. If you are in this deep you probably need one.
Sep 05, 2016 | 2000 Ford Ka
How do i replace the steering stem on a 93 dyna
Hi Anonymous, there is no short answer I suggest purchasing a service manual, it has detailed step by step instructions, special tools required and how too's especially for setting the preload on neck bearings, which is extremely important to insure safe handling characteristics. Good luck
Jun 25, 2014 | 2000 Harley Davidson FXDX Dyna Super Glide...
Miele w1113. Washer drum won't spin during wash cycle
I assume you are saying the machine is working except the drums not turning? - you need to see if the belt has come off because thats what i would check first if you hear the motor start/stop after it fills up with water.
May 30, 2011 | Miele Touchtronic W1113 Washing Machine
How do you replace hub bearings on a 2004 gmc envoy
I think you will find that post 90s vehicles have bearings sealed in hub units which are replaced. take a look on youtube and there will be someone you can watch doing this procedure, it is not a job for the first timer, but is much easier than replacing bearings the old way. parts can be had at any parts store or eBay. you can get a service manual with detailing, steps, and photos for about 10 bucks on eBay. better take a long look before you start it on your own.
Dec 29, 2010 | 2004 GMC Envoy
Miele w1113 Dreum made squeking noise. Tech said to replace door gasket and shocks with spring. Replaced parts and it started to smoke after a first spin cycle. Tech says it is either a belt or the...
Hi
Thanks for using FixYa. It seems to be the belt that has gone bad and to resolve this it should be replaced. From what you have dont think the bearings and belt both can go bad, you can unplug the washer completely and then try to turn the drum with your hand, if it spins like this then the belt is fine and you need to get the bearings replaced. However, if it wont turn then it is the belt that is bad, $925 is too high for bearings. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 11, 2010 | Miele Touchtronic W1113 Washing Machine
Removing fwd passenger side wheel bearing
to detailed to try to explain. best thing to do is buy a haynes auto manual from local autoparts store 17$ it will give you step by step instructions.
Aug 04, 2009 | 2001 Ford Focus
Front Wheel Bearings for 91 Tempo
You'd have to take the car to a shop, the front bearing have to be pressed in unlike the rear bearings.
I've had the driver side bearing go out, and now the passenger side is GOING out. But yeah, unless you have the machinery at home to do it, you'll need to go to a mechanic.
No fun I know. I've got a 92 Tempo
Jan 09, 2009 | 1993 Ford Tempo
Wheel bearings bad in front 2001 Ford Escape, any hints on repairing this myself?
I have a 2004 Escape 4x4 that I replaced a front wheel bearing myself last fall. It was not "easy", but it was doable. First thing I did was subscribe to Alldatadiy.com online to get detailed parts and service directions. For about $25 it gave me exact directions and steps to take. It did require some mid range automotive repair skills as well as a large hammer and a hydraulic press to reassemble. About $30.00 for the bearing and about 3-4 hours of labor...although next time I could probably do it in 2.
Good luck,
Pete
Aug 20, 2008 | 2004 Ford Escape
Miele w1113 alarm buzzer
do you have 3 dashes across the dispaly?? you need to get into service mode to access the fault
Aug 17, 2008 | Miele Touchtronic W1113 Washing Machine
Bearing noise
rear bearing is pressed into outer drum never changed bearing only usually requires entire drum replacement instead..also shaft on rear of inner basket is probably scored bad and needs replacement too
Mar 20, 2008 | Maytag Neptune Washer
Miele Touchtronic W1113 Washing Machine Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
