Question about Janome Memory Craft 4000 Sewing Machine
When I use the zigzag stitch it will not do a consistent stich, it zigzags then straight stitches
What cause it to be inconsistent
  • Janome Master
  • 1,564 Answers
Needs timing. Take it in.
Posted on Nov 06, 2012
  • 323 Answers
SOURCE: stiching
It's very possible the bobbin is in upside down and the thread is coming out of the lower tension. Pull on the thread and the bobbin should turn counter clockwise if it is correct . If it turns clockwise, flip the bobbin over , put the thread through the lower tension and try it again. The topside stitch is loose either because the lower tension is loose(or non-existent) or the top thread is too tight.
sewman7
Posted on Jul 08, 2008
  • 3 Answers
SOURCE: Changing stitches
You probably have not adjusted you stitch width and length.
Also a manual for this machine is currently being sold on Ebay for $4+. Probably would be a good investment for you.
Posted on Mar 29, 2008
SewTechWayne
  • 186 Answers
SOURCE: Zigzag won't enlarge
See if there is a twin needle lock out setting, if it is on it will cause this symptom. Otherwise there may be a bind in the needle pivot or linkage system to the needle bar from the cam or stepper motor (I don't know if this is a mechanical or electronic machine).
Posted on Feb 01, 2009
  • 26 Answers
SOURCE: My machine skips stitches when zigzagging.
either out of time or re set your top tension, also install anew needle. if not you can ship to me and i can fix. keithat11@aol.com
Posted on Aug 06, 2009
SOURCE: Hello. I don't have an instruction or user manual
try these sites for a manual
sew usa
sewing manuals.com
ebay
Posted on Jul 31, 2010
Where can i get straight stich needle plate for singer 5430 or is there anything compatible?
You really do not need a straight stitch needle plate because you can sew straight or zigzag stitches with the plate that came with your machine. Biggest advantage is that you do not have to change the plate to sew. Many people forgot to change it and broke needles when sewing zigzag.
Jan 29, 2018 | Singer Sewing Machines
Tip
Sewing Machines How do I make a zigzag stitch
When it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
  1. Step 1 Zigzag Stitch. ...
  2. Insert your fabric into the sewing machine and depress the presser foot. ...
  3. Guide the fabric through the machine to keep the stitch straight
Zigzag Stitch iFixit
How to Make Zigzag Stitch Sewing Machine
Bernina 550 40 Triple Straight Stitch Zig Zag
Zigzag foot 0
https://blog.bernina.com/en/2017/01/useful-stitches-are-also-decorative-stitches
Bernina Sewing Machines How do make zigzag stitch Google Search
on Dec 13, 2017 | Sewing Machines
Can I go from straight stitches to zigzag stiches and back in the same seam?
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
May 14, 2014 | Singer 3116 Simple
Elna 3007 reinforces every stitch.
It is in Stretch Stich mode....(SS)
Check your manual to reset in normal mode
Apr 07, 2014 | Elna Sewing Machines
Why straight stitch will not work but zigzag and herringbone stitches work on my machine.
it sounds like the machine needs to be checked at a sewing
machine shop to see what's wrong with the cam's or gear
that makes the stitches
Aug 01, 2012 | Sewing Machines
When buying a sewing machine that has blind hemming feature .what does this mean./
it means there is a foot included that will straight-stitch a certain number of stitches then do a zigzag stitch to the left that will catch the fold of the fabric at intervals. The fold is made at the width of the hem you want. When you finish and straighten the hem out, the hem stitches will barely be visible on the top side unlike straight-stitching across the top of the fabric. There will be a "hem stitch" option on the machine and the foot will possibly have a movable guide that runs along the fold of the fabric to where your zigzag "catching the folded fabric" stitch is consistent.
Mar 21, 2011 | Sewing Machines
Setting Machine on Different Stich Patterns
Turn the dial for stitch length so that the black line that separates the stitch length numbers from the buttonhole functions is in the 12 o'clock position. This engages the gears that operate your red stitches.
Aug 19, 2009 | Singer Electronic Sewing Machine
How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Jul 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Sewing Machines Logo
206 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
