Question about KitchenAid Dishwashers
Dishwasher Cycle light glowing and pad not responding
My model is KUD802FRSS1. It's Normal button light glowing repeatedly and pad is not responding for other buttons
  • 111 Answers
SOURCE: Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Posted on Dec 18, 2008
  • 127 Answers
SOURCE: kenmore dishwasher ultra was quiet guard 3 model
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
SOURCE: electrolux dishwasher all lights blinking and wont
Remove the toe kick by loosening 2 screws. There is a panel there with little lights that correspond to specific problems. The light that is on will correspond to the problem that the dishwasher has detected. Correct the problem and you should be good to go. I have no idea why this is not in the instruction manual. A common one is that there us a leak that the dishwasher has detected, normally in the drain pipe.
Posted on Dec 12, 2009
SOURCE: My Maytag steam dishwasher # MDBH980AWS won't do
My Maytag dishwasher # MDBH950AWW wont turn on no light but it has power in the outlet no power to the control board
Posted on Jan 21, 2010
  • 1382 Answers
SOURCE: dishwasher won't start
The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched
The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate.
It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch.
Posted on May 17, 2010
How to program the safety lock on and off model 66517039402
From Page 15 of the complete owners manual available here:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0409033.pdf
Lock On
Use the Lock On to prevent unintended use of the dishwasher.
You can also use the lock feature to prevent unintended cycle or
To turn on the Lock
flashes 3 times.
Sep 24, 2015 | Kenmore Dishwashers
How do i get my kenmore dishwasher to change from light wash to any other cycle, its kenmore ultra 13449k900 model, runs fine on light duty
Well, if you can't change the cycle by pressing another cycle button, yet you CAN press Start or Cancel and it responds, then you probably have a bad control console. If nothing responds, then you may just have the control-lock (or child-lock) feature turned on.
Oct 20, 2014 | Kenmore Dishwashers
Kenmore Dishwasher locked up
Sounds like the washer CPU is defective, have it diagnosed by a local repair technician.
Jul 28, 2017 | Dishwashers
Whirlpoool model du920pfgb3--touch pad is not responding and no lights or nothing are on??
Control panel. Try to push cancel button to see if it resets.if not google it and they will walk you through it.
Mar 28, 2013 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher start button has no effect: Whirlpool DU1100XTPS1
This is a problerm caused by the main control circuit board that is behind all the control buttons, the part is about $150.00 and about 1 hour to replace it.
Feb 09, 2012 | Cars & Trucks
Hi, I have a brand new quiet partner 2, the model number du1055xtvq3, it stopped during the normal cycle and the normal and cancel lights flash at the same time. None of the buttons respond when pushed.
Unfortunately, the touch panel has experienced a failure. You can try disconnecting the power for a bout 5 minutes to see if it resets, but I doubt it will. The touch pad will likely need to be replaced. I will need the rest of the model number to give you the correct part information.
Kelly
May 25, 2011 | Whirlpool DU1055XTV 24 in Builtin...
Pots &pans normal sani cycle lighs fashing..wont start lights wont go off..help!
If it is a slow blink on the start button it's something to do with your door switch. If it's a rapid continous flashing it's prob a short in your key pad. If it flashes 7 times, pauses and then repeats you have a fault with your heating element.
If it's a short with your key pad and the unit has water in it - stopped mid cycle you can cut the power to the unit at the breaker, open the door controls up and disconnect the 14 pin key pad connection. There should be a wiring diagram in the toekick cover (at the floor). This diagram will tell you how to do various tests, disconnect the key pad. If your not a handy type person call a repair man and tell him you think youhav a short in your key pad.
Mar 11, 2010 | Whirlpool 24 in. DU1100XTPS Built-in...
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
Lock On
To turn on the Lock
flashes 3 times.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
Nov 15, 2008 | GE Profile PDW8400J Built-in Dishwasher
Dishwashers Logo
37 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
