Where is reset switch on tempstar sp80
Tempstar sp80 will not turn on
Had a power hit in my city and my Tempstar AC blew only hot air, is there a reset switch on the unit? Sam
Do you know where your breaker box is? Flip all the switches off and then on and see if that resets it.
Jun 28, 2017 | Heating & Cooling
Just installed a used tempstar nulk075dg03 turned on power and the blower fan wont shut off. turn the thermastat asking for heat the blower motor goes off and the glow comes on the fire lights for a c
its wired up wrong somewhere try to bypass the thermostat wires at the unit and confirm the unit works
then youll know more
other than this i would consult the installation guide and user manual first ...!!! get them from the makers site some makers manuals are not on the general google type search but readily available from the makers site
Dec 21, 2014 | Fasco Intercity Heil / Tempstar Furnace...
Tempstar Door model keeps overfilling
The sensor is a plastic pipe (vacume) / and a ajustable switch. The rise in water causes the air pressure in the pipe to increase and at the set level this stops the water inlet valve. You could disconnect the pipe and blow into it slowly and should hear the switch click. Most faults are the plastic sensor pipe blocked / obstructed and or the switch terminals (inside switch) burnt. This means that the switch must be replaced and should be set for the correct water inlet.
Jan 21, 2010 | Jackson 25 in. TempStar HH Free-standing...
I have a tempstar combine air conditioner and furnace. the furnace will run fine then the manual limit switch trips. i can reset the limit switch and it will operate a couple of cycles then trip again, any...
If the unit is around 6 years old then it could be the combustion air motor. If the unit is older then you need to inspect the heat exchanger for signs of cracks. Take the top off the unit to inspect. Check to see if the metal around the reset is hot and if it is then the switch is doing it's job. If the heat chamber is cracked then turn the gas off, because your home will have CO. This can kill you.
Jan 05, 2010 | Heating & Cooling
Gas furnance would only operate for about 3-5 minutes then turn off. Replaced gas valve on furance for a Rudd comerical A/C 4 ton unit model UKKA-A048JK10E. Now the blower fan turns on but the igniator and...
the rollout switches will be located at the ends of the burner assembly and will have a manual reset. they must be manually reset to ensure that the problem has been corrected. Most units will go into a soft lockout for a time and eventually a hard lockout if the problem persists. Go to tempstar.com and go to their troubleshooting section for a gas furnace. the codes they give are pretty common for alot of furnaces and see if they help
Dec 10, 2009 | Ruud UAKA042 Air Conditioner
Need info. on a Tempstar Comfort 2000 unit.
This is a 2 speed condenser fan control board, the tempstar part number is
1086071, if you google tempstar 1086071 you will receive 1 listing for the part for something like 44 bucks, but if you go to sears parts direct and enter the part number they have a factory authorized substitute part number 1088977 that you can order from them for $17.49, some tempstar units were shipped without this control unit and the 2 speed fan just runs off the contactor on high speed only to do that disconnect the control unit and connect the black and orange wires that ran from contactor to the control unit previously together, and then the fan should come on in high speed when the condenser is on. there is a kit that they shipped these control units http://icpindexing.mqgroup.com/documents/086477/48201222001.pdf, (just for you to look at) so all you really need to do is get the new part from sears or run the motor in high and get rid of the part all together, hope this helps.
May 30, 2009 | Heating & Cooling
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
